    39
    621
    147,889
Tunnel game
Something I wrote this weekend inspired by the arcade game'Tunnel Hunt'. You can control the speed with the joystick (up/down).
Maybe I'll make a game out of this. Or maybe not. :)
EDIT: Here is how a turn may look like. Now fixed (v0.03)!
Tunnel__v0.01_.bin Tunnel_001.zip Tunnel__v0.03_.bin
21 Comments
Nice work - the faster speeds look particularly impressive :) It is clearly one of those effects which looks simple to produce, but is actually quite a challenge on the 2600!
Chris
Very awesome! I was just wondering the other day if Tunnel Hunt would be possible on the VCS! It is a fun game.
Is there any possible way that the tunnels will eventually twist and turn like the arcade game?
Up and down is no problem, but left and right, though possible, will become quite tricky and limited. But I am working on it.
If no game comes out of this, at least the code can be used for a good warp sequence in other games.
Hi there!
Looks cool! I hope you get it moving.
Would a brute force solution work, with 40 different kernels, one for each possible center square?
Greetings,
Manuel
Yes, that would work. I already have 4 different (partial) kernels, which are executed in RAM, so creating "a few" more would be possilbe.
But currently I am pondering about a kernel generator, which only gets the correct cycles as input and then automatically creates the kernel. There are 4 writes, which have to be cycle exact, plus 2 writes which have to happen before and after the center.
Sounds like an interesting challenge. :)
Hi there!
You mean a generator in ROM, which is creating the desired kernel in the RAM on the fly? :)
That certainly sounds like the next level of 2600 programming ;)
Greetings,
Manuel
Nothing shows up in Stella. Bummer. ;)
Hm, except for some illegal opcodes, there is nothing special hidden inside the code. :)
If you do continue this game... please add attack waves to it. The arcade game is just too monotonous as-is.
We'll see. I am not even sure, if I will try to redo Tunnel Hunt. Maybe I'll just do a simple 3D-racing minigame (with separate and different tracks of course ;)).
Since it seems impossible to attach anything to comments (is it?), I have added the lastest changes to the initial entry.
Well, that's better. Now I'm seeing a couple of lines at the top of the screen. :)
Hi there!
Is this the "yet to be announced project" that Manuel mentioned in the Ladybug - 2600 thread?
There I meant Juno First from Chris. Of course from the blogs you already knew about that :)
Greetings,
Manuel
Well, that's better. Now I'm seeing a couple of lines at the top of the screen. ;)
I'll try to find out what's wrong with Stella.
EDIT: I tried both binaries with Stella 2.01. Sometimes they run and sometimes they crash. :)
Hi there!
I think it'd be cool if it'd fully cover Tunnel Hunt and just had all other stuff like 3D-Race, 3D-Kaboom, 3D-Cave, etc as extra playmodes :)
Greetings,
Manuel
Well, it worked for me in Stella finally (then crashed after about 30 seconds). I just kept re-loading it until it worked. It looks great!
Good idea. But first I will try to find out how much space a minimal solution requires. I suppose that will be more than 1k anyway, so then there will be plenty of space for variations and add-ons.
Glad it finally worked for you (somehow). So I won't have to look for the problem now.
Maybe it will eventually disappear... :)
Maybe it will eventually disappear... ;)
Had little time this weekend, but enough to fix several problems, which caused Stella to crash. Fixed version attached above.
My brick-basher kernel is constructed with something like that. It'll take some coding to allow the game to generate the proper kernels at the start of each level, but it shouldn't be terribly complicated--just output the proper instructions and patch a branch. Could be pretty powerful, though.
