    657
    2,689
    897,748
He shoots*, he scores
* but only asteroids and mines.
Collision handling's going to be a bit different for Draconian as it's not feasible to check against all 150 sprites. One handy thing I can take advantage of is how the asteroids and mines are positioned. The screen's divided into horizontal bands that are 32 pixels tall. 4 stationary objects (combination of asteroids and mines) can appear in each band, and they're positioned so they never straddle multiple bands. Sprites 22-25 are in the first band, 26-29 are in the second band and so on.
Based on that knowledge I can limit the collision checks for shots by doing the following:
#define PLAYER_SPRITE           8
#define FORMATION_SPRITE        9
#define FIRST_STATIONARY_SPRITE 22
#define STATIONARY_DENSITY      4
for(i=0;i<4;i++)
    for(j=0;j<8;j++)
        // not yet written, player shots and station collisions
    for(j=FORMATION_SPRITE;j<FIRST_STATIONARY_SPRITE;j++)
        // not yet written, player shots and enemy ship collisions
    height = shot_height[i]
    start = ((shot_y / 32) * STATIONARY_DENSITY) + FIRST_STATIONARY_SPRITE
    end = (((shot_y + height) / 32) * STATIONARY_DENSITY) + FIRST_STATIONARY_SPRITE + STATIONARY_DENSITY
    for(j=start;j<end;j++)
        if (Collision(shot_shape, shot_x, shot_y, j)
            // process collisions
So instead of checking for collisions against 150 sprites I only have to check against 25 or 29 sprites. That's 8 stations + 13 enemy ships + either 4 or 8 stationary objects (depends if the shot straddles 2 zones).
Also added some temporary sound effects (borrowed from Space Rocks) and revised ship graphics (the 45° images).
ROM
draconian_20140419.bin
Source
Draconian_20140419.zip
Aiming at the non-45° 45° angles takes a little getting used to, but seems to be working fine.
The vertical/horizontal/diagonal speeds need some tweaking. Vertical seems a bit too slow, horizontal seems a bit too fast, and diagonal is much too fast.
When I slowed down the horizontal speed we got that fugly judder problem. That's is why I decided to just ignore the non-square pixel issue.
Maybe making vertical faster would work OK, though I suspect it'll just reintroduce the judder.
