    657
    2,692
    898,668
Updated assembly-6502 and batari BASIC mode files
DPC+ registers have been added to the assembly-6502.xml mode file for 2600 development.
The zero and hex problems have been fixed and DPC+ registers have been added to the batari BASIC.xml mode file.
See the prior blog entry for how to add the mode files. The assembly entry for the catalog file is:
<MODE NAME="assembly-6502"      FILE="assembly-6502.xml"
                                FILE_NAME_GLOB="*.asm"
                                FIRST_LINE_GLOB="*PROCESSOR 6502*"/>
Mode files:
assembly-6502.xml.20140928.zip
batari BASIC.xml.20140928.zip
Catalog file, for reference:
catalog.zip
JEDIT NAVIGATION
<PREVIOUS> <INDEX> <NEXT>
4 Comments
Thanks to some prodding by iesposta, I figured out how to use jEdit to compile assembly code and run the resulting bin via Stella!
I'll post a blog entry detailing the configuration changes in the next day or two.
I have a question, though I've done this in linux now I'm trying it on windows but I can't get the batari Basic mode file to work and instead it shows vbscript, am I the only that has had this problem?
In jEdit do this:
  • Select Utilities menu
  • Select jEdit Home Directory submenu
  • Select Modes menu entry
  • Select catalog from the list of files
  • Locate the following lines:
    <MODE NAME="vbscript" FILE="vbscript.xml"
    FILE_NAME_GLOB="*.{vbs,bas,cls}" />
  • then either change it to this to disable vbscript recognition:
    <!-- MODE NAME="vbscript" FILE="vbscript.xml"
    FILE_NAME_GLOB="*.{vbs,bas,cls}" / -->
  • or change it to this to disable just the recognition of bas files as vbscript:
    FILE_NAME_GLOB="*.{vbs,cls}" />
You'll probably need to quit/rerun jEdit after saving the change.
