    657
    2,692
    898,354
DPC+ARM - Part 3, VirtualBox update, Ubuntu update, disable Screen Lock
NOTE: This blog series is obsolete.  Head on over to the Harmony/Melody Club where you'll find information on the new Linaro compiler and the new CDFJ coprocessor/bankswitch scheme that has many improvements over DPC+.
VirtualBox update
VirtualBox has an update, it's now at version 4.3.22. Go ahead and install it.
Ubuntu will encounter an error when you log in after updating VirtualBox. Just acknowledge it. After that, VirtualBox will notify you that the Guest Additions need to be updated, do so. That will take care of the Ubuntu error.
Ubuntu updates
Periodically Ubuntu will have updates to install. When this happens, you'll see the Software Updater icon in the Launcher.
Software Updater in Launcher
Let's go ahead and run it - if you don't see the Software Updater you can use the Search icon to manually run it.
search
search update
Either way, you'll see this the following, click Install Now
install now
Enter your password when prompted
authenticate
The updates will start to install.
installing
You can click on details to view the detail if you'd like
details
Some updates require a restart
prompt for restart
Click the icon on the left
restart
Disable Screen Lock
By default, Ubuntu will lock its screen after 5 minutes of idle time. That can become annoying, so let's turn it off.
Open up System Settings
system settings
Select Brightness & Lock
brightness & lock
Set Turn off screen when inactive for: to never and toggle the Lock setting to off.
lock setting
To close the settings, move your mouse pointer to where it says Brightness & Lock to reveal the hidden window frame GUI.
hidden GUI
