Pain sucks.
I went to the doctor today. As it turned out, my last blood test was in May, so I didn't have to do it this time. Which means I fasted for no reason. I had to wait a half-hour to see the guy. It was horrible. Afterwards, I got a milkshake from Carl's Jr. And then my eye hurt. It was a bad one this time. But I eventually vomited a whole bunch (triggered by a poke in the throat), knowing that vomiting helps me end the eyeaches I get. It got better. Before I left I was working on Pineapple 64. I was having trouble with the trees. But when I came back and started work on it again, about 30 minutes later, I had solved the problem I was having. I think the trees look better, what do you think?
I also ran into a problem about running into the tree trunk. If you did it the correct way, he got stuck and couldn't move. I tried with the latest version to do what I did before, but I think I might have fixed it. I had been meaning to make the trees look better. The reason they look this way is because I would need four more separate tiles to make the trees rounded, and I don't want to work that hard. And it would mean making more collision code for the four separate tiles, which I don't want to do. So the next time I work on this, I will make the level bigger. I know I've said that before, but I don't think I can perfect what I have so far any more, unless someone runs into a bug...
