STING: Atari to PC
Posted by Christos, 17 December 2007 · 2,798 views
Guides
Here is a new version of a null modem TCP/IP connection between the atari and a PC this time
with the use of the STING stack. I don't see a reason why it wouldn't work with an ST or Mega
STE but as usual some things are beyond us.I only have a falcon to test.
Setting up the Atari:
First it is imperative to install and install properly the HSModem serial port drivers. To do
that we place DRVIN.PRG in the auto folder late in the running order but before the drivers
and the stack. After that we install the serial drivers. Depending on our machine this should
be:
SCC.PRG for ST, Falcon or MegaSTE modem 2
MFP.PRG for ST, Mega STE modem 1 [1]
* I use SCC for my falcon but without an ST to test I am not really sure about this. I read
the manual but I couldn't really understand it TBH. It's trial and error.
Next we go to setting up the stack. STING 1.26 has been used.
We place sting.prg and sting.inf in the auto folder, after the serial port drivers. We also
create a c:/STING folder where we put the sting modules and all accompanying software. The
modules need to be placed in the sting folder and not a subfolder. We also need to add the
cpx serial.cpx, stingprot.cpx, stingport.cpx and sting.cpx in our cpx folder to be loaded
by the control panel.
Serial port settings:
Modem 2, 38400, RTS/CTS, 8bit none parity, 1 stop bit.
Sting port settings
General, PPP, van jacobson compression
Addressing: MTU 576, ip address appropriate
Sting internals
Sting Protocols
Resolver: 192.168.1.1 routers ip
Windows:
We set up windows to accept incoming connections as described in my previous entry.
Important: The sting prt file needs to be placed in the auto folder next to sting (but I wasn't sure so I've placed it all over :D).
That's about it. You reboot and you are connected with internet. I've also changed my route.tab and default.cfg
according to this.
The connection is more stable than the pppd connection with mintnet and I don't know why. I just accept it.
On a related note, my falcon's floppy broken down while I was trying to take some screenshots...
March 2019
S M T W T F S
     12
3456789
10111213141516
1718192021 22 23
24252627282930
31
Recent Comments
0 user(s) viewing
