The Creative Atari Part 2
1440 PRINT "2. 'A' TO CHECK ALL FILES;"
1450 PRINT "3. 'D' TO SEE DIRECTORY LIST AGAIN"
1460 PRINT "NOTE: ERRORS SHOW UP ON DIR LISTING "
1470 PRINT "AFTER THEY OCCUR IN SEARCH."
1480 INPUT N$
1490 IF N$="A" THEN FILE=128:GOTO 1690
1500 IF N$"D" THEN GRAPHICS 0:GOTO 1070
1510 ON ERROR 1540
1520 FILE=VAL(N$)
1530 GOTO 1560
1540 PRINT "ERROR. RE-ENTER."
1550 RESUME 1420
1560 REM --- PROCESS. CHECK.
1570 IFFILE>FNUM OR FILE<0 OR FILE<>INT(FILE) THEN PRINT "ERROR.":GOTO 1420
1580 REM SINGLE ENTRY HANDLER
1590 PRINT "TRACING=='SELECT' TO ABORT."
1600 SS=INFO(FILE,2) ! STARTING SECT
1610 SC=INFO(FILE,1) ! SECTOR COUNT
1620 RSECTOR=SS
1630 REM GO TRACE IT ...ARROR=RETURN
1640 GOSUB 1850
1650 IF ARROR=1 THEN PRINT "***BAD FILE***"
1660 IF ARROR=1 THEN DEAD(FILE)=1 ELSE DEAD(FILE)=-1
1670 GOSUB 2110 ! MARK FILE NAME
1680 GOTO 1350
1690 REM ALL ENTRIES HANDLER
1700 FOR FILE=1 TO FNUM
1710 CLS
1720 PRINT "TRACING FILE #";FILE
1730 IF LP=1 THEN PRINT #3,"TRACING FILE #";FILE
1740 PRINT "PRESS 'SELECT' TO ABORT."
1750 SS=INFO(FILE,2) ! STARTING SECT
1760 SC=INFO(FILE,1) ! SECTOR COUNT
1770 RSECTOR=SS
1780 GOSUB 1850
1790 IF ARROR=1 THEN PRINT "***BAD FILE***" **"
1800 IF ARROR=1 THEN DEAD(FILE)=1 ELSE DEAD(FILE)=-1
1810 GOSUB 2110
1820 NEXT FILE
1830 PRINT "COMPLETED."
1840 GOTO 1350
1850 REM TRACING SUBROUTINE
1860 ARROR=0
1870 PRINT
1880 PRINT "---SEC CNT=";SC;" READING SEC ";RSECTOR
1890 POKE &D01F,0 ' CLEAR BUTTONS
1900 GOSUB 70 'READ
1910 REM CHECK BUTTONS
1920 IF PEEK(&D01F)<>7 THEN RETURN
1930 IF DSTATS=1 THEN 1960
1940 PRINT "***ERROR. DSTATS=;DSTATS;" ON SECTOR ";RSECTOR
1950 GOTO 1900 !RETRY
1960 IF SC=0 THEN RETURN
1970 SC=SC-1 ! DECR S COUNT
1980 REM GET FORWARD POINTER + FNUM
1990 FWD=(PEEK(BUFF+125) AND 3)*256
2000 FWD=FWD+PEEK(BUFF+126)
2010 FN=INT((PEEK(BUFF+125) AND &FC)/4) ! WENCE, SWIFTED 2 BITS RIGHT
2020 FN=FN+1 ! (DISK STARTS AT 0)
2030 PRINT "---DATA: FILE NUM=";FN;" FWD SEC =";FWD
2040 IF FN<>FILE THEN PRINT "FILE NUMBER ERROR.":ARROR=1
2050 IF FWD>720 OR FWD<0 THEN PRINT "FORWARD PTR OUT OF RANGE,ABORT.:ARROR=1:RETURN
2060 IF FWD=0 THEN 2090
2070 RSECTOR=FWD
2080 GOTO 1870
2090 PRINT "COMPLETED."
2100 RETURN
2110 REM MARK A FILE AS BAD IN NAME.
2120 REM SET HIGH BIT SO IT SHOWS
2130 REM UP IN INVERSE VIDEO..
2140 IF ARROR=0 THEN RETURN
2150 Z$=NIME$(FILE)
2160 NIME$(FILE)=""
2170 FOR Z=1 TO LEN(Z$)
2180 NIME$(FILE)=NIME$(FILE)+CHR$((ASC(MID$(Z$,Z,1)) OR &80)) !SET HIGH BIT
2190 NEXT Z
2200 RETURN
