Atari Eagle parts library
Posted by ivop, 08 January 2010 · 3,489 views
electronics eagle
I finally compiled all the different Eagle parts I had drawn over the last year into a single Eagle library and adjusted them to be more or less uniform in look. While I was at it, I also added all missing chips and connectors. Currently, it contains the following parts:
74LS08
74LS14
74LS51
74LS74
74LS138
74LS158
74LS375
4050
4051
4164
6502C/Sally
6520A/PIA
27128/OS PROM
ANTIC
BASIC ROM
Cartridge
Cartridge Socket
EP8212
GTIA
Joystick Port
Keyboard Socket
LM358
MMU
Monitor Jack
Parallel Bus Interface
Parallel Bus Interface Device
POKEY
Power Jack
RF Modulator
SIO Jack
Basically, it's everything you find on an 800XL motherboard.
Update 2014-04-29: added conversion to Eagle 6.5.0 (XML file format).
Thanks for that, it's great!
  • Report
Just tried to load this in 6.1.0 and it fails with errors, must need to be updated to work with newer versions of Eagle.
  • Report
missing 6507 and 6532riot
I know not atari 800xl but would be REALLY useful for 2600...
  • Report
Awesome, THANKS !!!!!!!!!
  • Report
HI Ivo, is there any reason why the Vcc and Vss pins are missing on all the chips ?
  • Report
Yeah, figured that out quit a while ago....
Would be cool if you could add FREDDIE Ivo ;)
  • Report
They should be there. Probably hidden or automatic pins. Haven't used Eagle in ages as I have long since moved to using KiCad.
  • Report
