    36
    32
    73,360
Bookmarking code
jwierer
As your code grows it can difficult to easily navigate it. Bookmarks provide a convenient way to mark sections of code so you can quickly jump to that location. Here is a quick guide to using bookmarks:
  1. Highlight a section of code.
  2. Right Click, Select – Add Bookmark.
  3. Bookmarks will be added to the new bookmark section within the Project Explorer
Alternatively, you can manually enter a search term and use the add to place it into the bookmark list. Bookmarks are saved so when you reopen a project they will automatically be loaded. Additionally, as you switch between different programs the list of bookmarks will change based on your previous settings. You can also right click on bookmarks to jump to, remove, or reorder the bookmarks.
If you want to test this out you'll need to download this build of VisualbB.
