Case Sensitivity
Posted by Willsy, in TurboForth V1.x 30 April 2012 · 158 views
A few days ago I added case insensitivity to TurboForth. When you are working on a real TI, you tend to engage the Alpha Lock key and leave the keyboard in upper case mode. However, if using via emulation then you normally have your caps lock switched off (in lower case). It always annoyed me that the system couldn't recognise load but could recognise LOAD. I mean, it's the same word!!
So, I finally added the code so that it doesn't matter anymore. Basically, as text is entered from the keyboard or compiled it is converted to upper case (except stuff in strings) so it doesn't matter any more.
Anway, another day, another "Hmmm" moment. I decided I would add a switch to make it selectable. So you the system can be case sensitive if you want it to be.
I added a variable called CSEN. Write TRUE to CSEN, as in:
TRUE CSEN !
and your system is case sensitive. Write a false and it isn't. The default is false.
There. Sorted!
May 2013
S M T W T F S
   1234
567891011
12131415161718
1920212223 24 25
262728293031
Recent Entries
