    39
    57
    124,771
Procedure Calls 1
DanBoris
Let's take a break from looking at Action! math and take a look at procedure calls. We will start up with something that is trivially simple:
Proc test()
Return
Proc main()
  Test()
Return
0E61: 4C 64 0E    JMP  $0E64
0E64: 60          RTS
0E65: 4C 68 0E    JMP  $0E68
0E68: 20 61 0E    JSR  $0E61
0E6B: 60          RTS
Our main procedure starts at 0E68 and it begins with a call to procedure Test using a JSR. The procedure Test starts at 0E61 which immediately jumps to the RTS since the procedure is empty. What I haven’t been able to figure out is why the JMP instruction is there since it doesn’t jump over anything. I have yet to find a case where it actually jumps over something.
Next let’s look at how simple parameter passing is done:
Proc test(byte I)
Return
Proc main()
Test(1)
Return
0E88: 	  .BYTE #$00
0E89: 4C 8C 0E    JMP  $0E8C
0E8C: 8D 88 0E    STA  $0E88
0E8F: 60          RTS
0E90: 4C 93 0E    JMP  $0E93
0E93: A9 01       LDA  #$01
0E95: 20 89 0E    JSR  $0E89
0E98: 60          RTS
This is the same as the first example, but now we pass a single BYTE parameter to the procedure. Here is an area where Action! does a good job at optimizing. Since there is only a single BYTE being passed it uses the most efficient way possible, it just passes it in the accumulator. At 0E93 the value 1 is loaded into the accumulator then the procedure is called. At 0E8C that value passed is stored in the local variable I. You will notice that space for this variable is allocated before the start of the procedure code, so this doesn’t answer the mystery of the JMP instruction.
