Hi there!
This is going to be the worst "Playing..." game by far:
This is such a badly designed game. I'm only forcing myself to try again, since I owned it as a kid. Of course I knew even then that it sucked, but maybe now I can at least find a trainer or cheat to finally see the end
It has a map with about 250 rooms. Your mission is to kill the Alien Queen in the last room at the very other end of your starting point. No matter what I ever try, about 15-20 rooms into the game the whole team from Ripley to Bishop is slaughtered.
If I have a lucky run, I can sometimes get 1-2 members alive to the Armory room (#28). There you get your ammo refilled and then I can occasionally make another 10 rooms until it's Game Over again.
I played another 5 rounds tonight just to confirm all of that just once again. It's just totally unplayable trash as is.
BTW: It's not a matter of mapping the game or so: AFAIR, did my original tape already come with a complete map!
Well, after failing to play the game once again, I continued with researching. There's this very cool thread at Lemon64 where some true masters of the game reveal a lot of tips, tactics, exploits and secrets regarding the game, so I will try playing tomorrow again, using all this valuable information:
http://www.lemon64.com/forum/viewtopic.php?t=13112
Second I found that the cracked version from Hokotu Force has 3 optional trainers, so in the worst case I may resort to these as well
Greetings,
Manuel
7 Comments
