Isabella Coq: problem solved Entry posted by Guest June 14, 2005 1,058 views Share More sharing options... Followers 0 Hi folks I found the problem. AGI loads the whole view even if one loop is used. The solution is simple. I just put some sprites in the new view. So the old view is smaller and fix the problem. Here a new screenshot. See you later Robin Gravel
