    17
    28
    32,096
Hex to BCD conversion (0-99)
Omegamatrix
I can't sleep. I'm consumed by this problem and I keep thinking about it...
Tonight I discovered some of Batari's solutions for hex to bcd conversion here and here. They are very compact solutions, and neat. I started to wonder if a constant (un-looped) cycle approach could be found without using tables. Then the insomnia crept in. :) I decided to have a go at translating hex values of 0-99 (BCD range for a byte).
The approach I took was to modify my divide by 10 routine so that the result was multiplied by 6, and then added it to the initial value. From there I optimized it so that some of the shifts could be cut out, and removed the correction value (adc #13) from the divide routine, because that is only required for values 130 or more (and we are just doing 0-99).
Here is what I came up with:
;Hex2Bcd (good 0-99)
;24 bytes, 39 cycles
;You can also use LSR for all ROR's here...
  sta  temp
  lsr
  adc  temp
  ror
  lsr
  lsr
  adc  temp
  ror
  adc  temp
  ror
  lsr
  and  #$3C
  sta  temp2
  lsr
  adc  temp2
  adc  temp
I wrote a real short verification program. Basically just a macro that pumps out all the results and stuffs them into zero page ram, which can easily been seen in Stella's debugger. I did a visual verification.
hex2bcd.zip
  • Like 4
3 Comments
Very nice! It's one of those routines that looks like magic if there isn't an explanation.
Do you mind if I add it as a utility function to 7800basic?
Yeah, absolutely go ahead. :) The caveat is that it does no checking for numbers 100-255, so it is up to the user to ensure the starting number is 0-99.
Thanks!
Understood about the lack of range check. I'll document that and leave it up to the end-user. That way the routine can stay nice and lean.
