Hex to Ascii String
I saw a topic on 6502.org about converting byte to hex string. I remembered Lee Davison's code shorts about converting 0 to 15 to ascii 0 to 15 by using decimal mode. I know Lee passed along this year so RIP Lee, I didn't know you but you seemed like a genius to me.
Using his basic code I came up with this for converting a byte:
;HEX to ASCII ; A = entry value sed ;2 @2 tax ;2 @4 and #$0F ;2 @6 cmp #9+1 ;2 @8 adc #$30 ;2 @10 tay ;2 @12 txa ;2 @14 lsr ;2 @16 lsr ;2 @18 lsr ;2 @20 lsr ;2 @22 cmp #9+1 ;2 @24 adc #$30 ;2 @26 cld ;2 @28 ; A = MSN ASCII char ; Y = LSN ASCII char
I ran a short test program for all values and it passed. Twenty eight cycles is not too bad. It's kind of a cool way to convert a byte like this. This could make for a nice project for communicating out of the 2600 I/O port and displaying to a LCD panel in useless but fun way. Maybe you could have two 2600's with the LCD in between them to see the bytes fly by.
Just need to make a conversion routine from ASCII back to hex.
Edit: Came up with this off the top of my head. Tested it for a few values and seems to work. It can only handle ASCII '0' to '9', and 'A' to 'F' (capitals).
;ASCII to HEX ; A = MSN ASCII char ; Y = LSN ASCII char cmp #$39+1 ;2 @2 bcc .highNybble ;2³ @4/5 sbc #7 ;2 @6 .highNybble: asl ;2 @8 asl ;2 @10 asl ;2 @12 asl ;2 @14 sta temp ;3 @17 tya ;2 @19 cmp #$39+1 ;2 @21 bcc .LowNibble ;2³ @23/24 sbc #7 ;2 @25 .LowNibble: and #$0F ;2 @27 eor temp ;3 @30 worse case, 28 best case
- 1
