DCP+ Build Environment
Tonight I installed the development environment for DCP+, I will fiddle around with it and hopefully be able to suck some additional cycles from my scan lines.
Ubuntu 14.05 - Check
Shared Folders - Check
ARM Compiler - Check
Test Source Build - Check
Using the DCP+ tools, I'll probably implement a horizontally scrolling broomball pitch... and dynamically build the scan line data (color, sprite, playball) using the ARM processor in the 4K of Display Ram.
Hopefully this will give me the ability to render a more detailed goal area, in addition to removing the need of displaying 4 sprites on a scan line in the center section of the broomball pitch.
Once I have a handle on that, I'll hopefully be ready to use CDF in the future.
