Space Patrol (1962) Encyclopedia-Part 1
(Taken from "Slim's Encyclopedia" on a website currently in the Internet Archive, added here to help with discussion.)
Originally:
http://homepages.tesco.net/~space.patrol/SpacePatrol/SlimA.htm
Now:
A
Aba Bird
Rare, flightless bird from the area of Mars, resembling a two legged rhinocerous with a single white eye. Only twenty are known to exist in the year 2100 and they are a protected species. They lay three eggs a year - one ovoid that contains its young and two square ones that contain additional food for it when it hatches. They can be very protective and ferocious protecting their eggs, goring people with their tusk. The protein from the square eggs was used to synthesise a cure for the condition known as 'the floats'. They were apparently tame once and, if tickled, can be calmed down (HI). The eggs can also counteract the rapid hair growth caused by fruit from the Toohera Jungle (HM).
Action Call
Order given by General Smith in emergencies, such as the rocket launch against Dr Duncan on Ganymede (ES).
Aeronautics Museum
Complex which stores and maintains examples of obselete air and space vehicles. They still have a fully working 1980s rocket that is used to repel an Neptunian attempt to get Earth slaves (FX).
Alpha Centauri
Star system over four light years away, containing the planet Delta and home to Yria. It would take a Galasphere about 3000 years to travel the distance but with a Delta Unit built by Yria, the journey only takes about four months (MS, DS).
Antibiotic
The Saturnian plants are described as having an antibiotic effect on the fungus that is destroying crops (MTS).
Anti-plastifoam Gun
Never seen and only refered to once, it would suggest a weapon or device that projects a solvent capable of dissolving plastifoam (MTS).
Anti-Dazzle Glasses
Husky's eye-saving solution to Professor Haggarty's hideously colourful jersey! (TVC05).
Anti-Missiles
Defensive interceptor projectiles alledgedly carried by Galaspheres but never seen in use (TS).
Ants
Haggarty is trying develop a machine to translate the language of ants. We never discover whether it works but an offshoot of its development is the transmission of heat via radio waves (FM).
Arizona Desert
Where Colonel Raeburn orders Galasphere 347 to land, to confine a battle area when blue aliens declare war on Earth (TVC05).
Artificial Planet
Large world made by the Neptunians in an attempt to cause a collision between Earth, Mars and Venus and once again blackmail the UGO into sending human slaves to their planet (DW). Vast deserted worldship of unknown origin on a collision course with Earth until the crew of Galasphere 347 divert it (left). The fate of the inhabitants is unknown but may be linked to a strange energy on the ship that disintegrates lifeforms (AN02)
Asteroids
Belt of minor planets the majority of which are found between the orbits of Mars and Jupiter. Pallas is located in the main belt (SS), while others wander the solar system (UA)
Astral Projection
The ability to send ones mind outside the body in spirit form. The Duo plant creatures have a similar ability, with their 'spirits' being able to enter other species and control their will. The 'spirits' are just visible and refered to as smoke-like, and if they are destroyed - by electricity, for example - the body of the Duo dies and dissolves (II). The 'spirits' are also able to observe and act as spies, reporting back when the 'spirit' returns to its body (JW).
Atlantic Sea Farm
Subaquatic agricultural colony, presumably just off the east coast of America. It is overseen by Jim Barratt and an army of some five thousand robots (RR, MTS, PT, JW)
Atmosphere
Thin envelope of gases surrounding most planets. The atmosphere of Earth is oxygen (about 20%) and nitrogen (about 80%), and it can be assumed that the atmospheres of Mars and Venus are similar enough to Earth for it not to cause breathing problems between the three major races. Venus has a higher oxygen content (GS) while Mars may have some areas where it is necessary to wear a molung (HM). The atmospheres of Jupiter, Saturn and Uranus are poisonous to humans, making molungs a necessity when outside, but the Saturnian caves are 'air-conditioned' and confortable for humans (RS, MTS). The atmospheres of Mercury (FM) and Pluto (BS) are too thin to breathe and molungs or space helmets are required. The same applies to the moons of the planets, as none have atmospheres (MM, GT, ES, SD, WB), with the possible exception of Callisto (TS). Earth-like atmospheres can also be found outside the solar system, with a tenth planet beyond the orbit of Pluto having a breathable atmosphere (NP). The atmosphere of the planet Delta in the Alpha Centauri system is also Earth-like. The atmosphere of planet Lumen in the Sirius system lacks oxygen (PL), while that of Humida is believed to be poisonous but apparently has life preserving properties (TVC03)
Atom(ising) Gun
Weapon on board Galasphere 347 used to divert the whirlwind from its collision with Earth (DW). Fendoe has an 'atomising gun' on a tank-like vehicle at the mining base on the asteroid Omega (TVC04)
(N.B.. The Solarscope ship of Paul Starr is also armed with a weapon called the Atom Gun, which actually causes a powerful atomic explosion.)
Auntie Min
Relative of Professor Haggarty, with a penchant for gifts of gaudy coloured knitwear (TVC05).
Automatic Course Control
As the name implies, a system for automatically correcting the course of Galaspheres, while the crew are in the Freezer Cabin.
Automatic Pilot
Used to control the lead freighter of convoys (ES).
Automatic Time Control
System on Galaspheres that controls the length of time the crew are in the Freezer Cabin. It can be overridden or countermanded by the Zergon Ray.
Azsom
Tara's aide at his palace on Callisto (TS)
B
Bandits
Raiders of unknown origin who periodically terrorise the inhabitants of the tiny world of Larta (TVC11).
Barking Disease
Saturnian term for a cold, and the sneezing it causes. It proves fatal to Saturnians if untreated (MTS).
Barratt, Jim (right)
Head of the Underwater Sea Farm, where a percentage of Earth's crops are grown by robots (RR, MTS, JW).
Bats
Small flying mammals native to Earth, often alluded to when the ultrasonic communication of the Uranian Duo plants is discussed (DP, EVT). Large bat-like creatures inhabit the planet Humida, and are capable of flying for short periods in space (TVC03)
Berridge
Criminal who, with two accomplices, attempt to blackmail Earth by using a laser to target cities on Earth. He and his men are presumably killed when the beam is reflected back at their hidden base on the Moon (MM).
Beryllium
Element which, when introduced to the surface of the Sun, causes vast explosions and climatic changes on Venus and Mars. It has other applications, one would hope, as a convoy of forty freighters full of the stuff was on its way to Pluto before being hi-jacked by Doctor Duncan. Unless the Martians there were hoping to pull a similar stunt in an attempt to warm their colony, that is (ES).
Betelguese
Star system 190 light years away from Earth. It is home to a race of benign, bell shaped creatures (TB).
Betelguesians
Bell shaped aliens of indeterminate nature from a planet in the Betelguese system. They are refered to as being neither flesh & blood, metal or plastic, suggesting they are closest to plants in our terms or wholly alien. They have a single extendable leg and another extendable antennae which can transfer their life energies (left) or, in the case of cheeky Gabblerdictums, used to meter out physical punishment! Betelguesians can decode alien languages in their head in a very short space of time, and are extremely moral with 'Mr Bell' willing to sacrifice his life energies to sustain Dart during a rescue attempt (TB).
Betelguesian Mothership
Slender craft with projecting handles, it is parked in orbit close to Neptune while scout ships were despatched to other solar planets (TB)
Betelguesian Scoutship
Never seen but presumably fairly small, it ferries 'Mr Bell' to Earth from the Mothership near Neptune and is blasted down accidentally by Colonel Raeburn while on a shooting trip with Haggerty (TB)
Biological Department
Section of the UGO Scientific Headquarters, which Professor Haggarty wants to examine the planet from Uranus (DP)
Bird Song Translating Machine
Device invented by Professor Haggarty to understand the language of birds. It is used to teach Gabbler to speak English and alluded to many times, usually with regret (SN)
Birdbrains
What Larry Dart thinks Husky and Gabbler also have in common, besides an owner and pet relationship (SN)
Blackpool
Large northern English town, known for its entertainment and tourist trades during the 20th and 21st centuries, and presumably still in existence in 2100 (MS)
'Blue Creatures' (right)
Small inhabitants of a newly discovered world on which the only colour known is blue. They are wary of planet to planet salesmen and believe the crew of Galasphere 347 to be them. When warning them off leads to a misunderstanding, they declare war on Earth, only to be shocked into retreat by the hideously bright colours of Haggarty's bright jersey. A likely story! (TVC05)
'Blue Planet'
Newly discovered world which on exploration by Galasphere 347 was found to coloured only in blue - an effect of atmospheric light absorbtion. A misunderstanding with the creatures who inhabited it nearly led to a war which was avoided by Professor Haggarty's brightly coloured jersey... or so he would have us believe! (TVC05)
Blister Plants
Form of flora on the planet Lumen in the Sirius star system. The large 'blisters' contain oxygen which is lethal to the native crystalline Lumina but which fortunately sustain Dart when his backpack is damaged. Dart also brings some seeds and crystalline soil from Lumen and is able to glow a blister plant on Galasphere 347 by exposing it to light. Their usage in providing oxygen in space travel is incalculable (PL)
Bloxine Fuel
Propellant of the Betelguesian spacecraft (TB)
Boost Speed
Ability to increase meson power on Galaspheres, allowing them to travel in the region of a million miles per hour. It is considered dangerous and only used in emergencies (TS, TB). Freighters and colony ships have a similar capability, presumably with speeds equivilant to a Galasphere (SN).
Boots, Spiked
The special boots worn by the crew of Galasphere 347 on Mercury have spikes on the underside. These prevent the boots from coming into contact with the boiling surface and burning (FM).
Borra, Professor
Clever, absent-minded and regrettably late inventor of the mechanical eye intended to protect the Venusian capitol Cresta from alien attack by destroying any craft not constructed of metals found on Venus, Earth and Mars. He was, according to the President of Venus, the most gifted scientist on Venus (EVT) but forgot Galaspheres were constructed of Plutonite, from Pluto, and the destruction of the approaching Galasphere 347 was only just averted. It would be amusing, though disrespectful of the dead, to suggest the hoverjet he was riding to inspect and adjust the Eye afterwards was also constructed of Plutonite and the cause of his death - but we just don't know... (EV)
Borse, Doctor
Scientist aiding the renegade Tirig and developer of the nerve gas used to blackmail Mars (SD).
Brig
Member of Marog's gang, with an eyepatch and brisque attitude (WB).
Brog, Commander (far right)
Level-headed leader of the Martian mining colonists on Pluto (BS, FM).
Brog's Aide (right)
Martian assistant on the Mining Colony on Pluto. He has only been there a short while and has to have the function of the heat transmission towers explained to him (BS).
Brown, Doctor
Scientist at the Jupiter Scientific Headquarters (SS, TB, SG), who discovers water from a newly discovered lake causes inanimate objects to move. He is abducted by his own spacesuit when the wateris accidently spilt on him and has to be rescued by Larry Dart and Husky (WJ)
'Busy Lizzie'
Type 2 robot modified by Haggerty to recieve orders by thought from Colonel Raeburn. It has striped patterns on its body with an 'R' on its chest (presumably for Raeburn). The first order Raeburn gives is for it to water his flowers, but while on the Galasphere for tests Lizzie he tries to kiss Husky. Quite what Raeburn was thinking is anyone's guess! Affected by Raeburn's delirium while suffering from a virus, Lizzie distracts the crew of Galasphere 347 while investigating a new planet occupied by the Neptunians, though was able to redeem herself by rescuing them once Raeburn had recovered (TR).
Buzzer
The vacuum doors on Galaspheres apparently have a calling device for when crewmembers want to get back in! (DP, SW)
C
Callisto
Moon of Jupiter and home to the art treasure thief Tara. The flight time from Earth is 21 days (TS).
Carbon Dioxide
Gas that is purportedly vital to the Saturnians, instead of oxygen (GS)
Cassiopeia Haggarty
Petite, dark haired daughter of Professor Haggarty, who prefers to be known as Cassie. She helps out in his laboratory at the Scientific Research Building at Space Headquarters and would also appear to look after him at home.
'Cat'
Small crystalline lifeform given to Larry Dart by the Lumina. It purrs and is refered to as a cat but it starts to fade not long after entering the Galasphere and is dead upon arrival on Earth, leaving only dark fibrous matter. Considering how much emphasis was put on how deadly oxygen is to the Lumina, one would assume that the crew of Galasphere 347 would have put two and two together but sadly for the late 'cat', it was not to be... (PL)
Cattle
The drought situation on Mars is so bad that cattle have had to slaughtered (BS).
Central Control
Division of Space Patrol at Space Headquarters that deals with pre-launch checks on Galaspheres. This would appear to be the job of the secretary of the Colonel in charge.
Chair
Punishment of the alien space raider Voltek, into which he was strapped forever unless someone agreed to take his place (TVC10).
Charlie
Type One Robot foreman at Jim Barratt's undersea farm (RR, MTS).
Cloning
Never mentioned per se in the series but the plethera of reoccuring faces brings one to wonder if it isn't common or even rampant by 2100 !
Cloud
Vast belt of electronically charged Zenton particles, three hundred and fifty thousand miles above the Earth, placed to deflect the solar heat and blackmail Raeburn into providing Neptune with slaves (CD).
Cloud Dispersal
By 2100, weather control has been established and is strictly controlled (CD).
Cloud Dispersal Officer
In charge of Weather Control, in the New York area at least (CD).
Coal
Compressed carbon formed from ancient animal and plant life. The fact there is carbon coal on Pluto indicates the planet may once have supported life millions of years ago (BS).
Code
To have been allocated to all metals made on Earth, Venus and Mars to prevent them from being destroyed by the Eye invented by Professor Borra (EV).
Colony
Martian settlement on the planet Pluto, refered to on several occasions though we only see the mining complex (SN, BS, FM). There are also colonists on Ganymede (ES)
Colony Ship
Tapered end cigar shaped ship, used to transfer a thousand colonists to Pluto (SN). It is similar in shape and size to a freighter, and may be converted from one (VV).
Comet
One knocks an asteroid out of orbit on a collision course for the Martian capitol of Wotan (WA). Another is responsible for reviving the crew of Galasphere 347 on the limits of the Solar System when it nearly collides with the ship (NP).
Common Cold
Curable by the year 2100 by an inhalant of unspecified nature and origin. It is still prevailent though, and nearly becomes an epidemic on Saturn where it is fatal if untreated (MTS).
Communications Tower - see Radio Tower
Computer Centre
Refered to many times, and implied that there is at least one each on Earth (MM), Mars (WA) and Venus (NP).
Contamination Control
Used by Galasphere crews, and presumably at other points where interplanetary contact is possible, to prevent germs or infections from being passed from planet to planet. It may use ultraviolet light although this is never directly stated. It is presumably powerful enough to prevent the common cold (MTS)
Coney Island
Large amusement park near New York of the 20th and 21st centuries, and presumably still in existence in 2100 (MS)
Control Tower
Tower close to Space Headquarters in New York that bears more than a passing resemblance to the Post Office Tower (now Telecom Tower) of the late 20th and early 21st century, which monitors space flight, presumably in conjunction with Space Headquarters. At other times it seems to be refered to as the Radio or Communications Tower.
Coryza
Old fashioned term for the common head cold but seemingly back in popular usage by 2100. It can be cured by an inhalant (MTS).
Cosmic Radiation
Responsible for mutating the Tula Fish on Venus (HF) and possibly the large scale of life on Planet Ten (NP).
Cosmonauts
Generally what the men of the Space Patrol are referred to as (EVT)..
Crackle
What the Gabblerdictum birds refer to paper money as (TF)..
Cresta
Capitol city of Venus, ringed by a range of dormant volcanoes, on the east coast of the Magda Ocean (VV, HF, ES, EV, SF).
D
‘Danger Speed’
Term by which Galasphere crews refer to ‘boost speed’, and with good reason (TB)..
Danta
Asteroid on which the Sonar Beam Transmitter for Venus is based, twelve days and three hours from Earth. It is damaged by interstellar debris from an ancient exploded star and has to be repaired by the crew of Galasphere 347. (TVC01).
Dara
Aide to the President of Venus (ES).
Dart, Captain Larry (left)
Over the duration of the series, we learn very little about Larry Dart. He would appear to be in his thirties and a veteran of Space Patrol and the UGO. Sporting 'Viking' blond hair and a goatee beard with blue eyes (EVT), he is a consummate professional. We learn little of his private life, assuming he has one after the long periods of time spent in space, or family. When he was seven, he used to go 'bird nesting' for eggs (HI). He looks forward to leave but on more than one occasion seems restless and in need of something to do, whether it be fishing (RR, TVC02), investigating a mystery on Mars (TF) or rock climbing on the Moon (DS). This zeal for action sometimes makes him volunteer for the most dangerous missions (EV), something Colonel Raeburn is aware of but rarely takes advantage of (WA)
Dawlish
Owner of a Lunalt Mining Complex on the Moon who discovered the Termoids and was blackmailed into smuggling them to Earth (TVC09)..
Dectium
Rare metal once found on Earth and used in atomic reactors but when supplies were used up, a source was found on the asteroid Omega. It is also found in a liquid form on the asteroid, and these can form geysers on the surface (TVC04)..
Deelya
The Dell capitol on Northern Jupiter (SW)
Deep Water Reservoirs
A suggestion by Marla in response to the rapid temperature rises caused by Dr Duncan, but it would take too long to implement before the heat became critical (ES)
Defence Ships (right)
Glimpsed rising from Earth to counter John Magnum's attack with giant alien bats, these are slender white, winged ships with red livery that belong the Space Army (TVC03)
Dells
Tall emaciated aliens who occupy Northern Jupiter. Despite their fragile appearance they are immensely strong and war-like, especially their leader, and have been in conflict with the planet's other race, the Miocells, for years (SW)..
Delta
Habitable Earth-like planet of the star system Alpha Centauri and home to Yria (MS, DS)..
Delta Power Unit
Device constructed by Yria and installed in the meson power unit of Galasphere 347 to enable it to travel faster than light (MS, DS). The jouney to Alpha Centauri is made in about four months, which would mean a velocity in excess of twelve times the speed of light.
Deltees (left)
Inhabitants of the planet Delta in the Alpha Centauri star system, or at least that is what Professor Zeffer dubs them. Pulsating, floating bodies with a banded head and a single glowing eye, they can teleport over vast distances and communicate telepathically (MS). The Deltees develop computers so advanced they can create living matter but as they did not want to increase the population a giant brain was made. This unfortunately turned malevolant and had to be destroyed (DS)
Dictum Forest
Forest on Mars which the Gabblerdictum came from (TF, HI, HM), and also home to the Aba bird (HI, HM) and the Glook (TF). It is a Wildlife Preserve and weapons are not permitted on the territory (TF)
Dictum Tree
Large growths on Mars, the leaves of which form the favorite food of Gabblerdictum birds, including Gabbler (TF)
Duncan, Doctor
Scientist who used to used to work for Professor Haggarty but was fired for trying to steal an invention. He tries to extort resources from Venus and Earth by causing explosions on the Sun which raise the temperature on the inner planets to unbearable levels (ES)..
Duos
Indigenous, intelligent and belligerent plant life from the planet Uranus. One small specimen was brought back by an expedition was found to be able to walk and communicate ultrasonically. This resulted in Galasphere 347 being despatched to make contact when it was theorised the small plant might only be ‘a child’. The plants reacted hostilely to the visit but ultrasonic recordings were made in an attempt at future communication (DP). Before this was possible the plants, who refered to themselves as Duos, launched a subversive invasion plan by taking over the minds of key members of Space Headquarters who would allow a fleet of craft to land unopposed (II). When this was defeated, a further more direct attempt was made by sending radio waves to cause localised earthquakes on Earth. This, too, was repelled and the feedback destroyed the Duo base (JW). Despite the high regard for life - alien or otherwise - Space Patrol usually has, the Duos seem to be the only species to be subject to a ‘destroy on sight’ policy. When the Duo ship is discovered after their first invasion attempt, it is blown out of the sky without so much as a by your leave (II). The same punishment is metered out to a second ship despatched to spy on Space Headquarters (JW).
Dynamite
Still used as an explosive in 2100 (WA, WB)
[/url]E
Earrings
Telepathy protecting fashion accessory, made from the filaments of Haggarty’s brain wave protectors (PT).
Earth
Third planet from the Sun in our solar system and home to the human race. Little is known of Earth in 2100 but there appear to be no wars even though military organisations are evident to overcome threats from hostile aliens or renegade movements within the UGO (MM, SD). There are still individual nations and countries, such as Asia and France (MTS, TS). There is strict weather control (CD) and a population explosion means that farming for food supplies is now on the ocean floors by robots (RR, MTS, PT, JW).
Eggs
Professor Haggarty has been trying to get hens to lay square eggs, which are easier to pack, without considering the consequences for the poor hens in trying to lay them. When he eventually succeeds though the eggs have no yoke! It is interesting to speculate whether the idea was inspired by the eggs of the Aba bird (HI, HM). A large egg containing a brilliant luminescent fluid that could be used to light Martian homes and save energy is found on Titan but found to be the offspring of strange creatures Slim dubs ‘humming dogs’. What happens to them is never revealed (GT)..
Elektran
Electronic Translator, a large disc like device worn on the chest of members of Space Patrol and scientific expeditions to other planets, which automatically translates the various languages into your own tongue. Set the dial ('V' for Venus, 'M' for Mars, 'J' for Jovian) and the language is broken down into microdots. These dots are then imprinted onto a mechanised roller giving a vocabulary of a thousand words - more than enough for comprehension (SJ, SS, WJ). The ultrasonic language of the plant life forms of Uranus is recorded during a visit there (DP) but never seems to be translated. Saturnian language is recorded, translated and added to the Electran after the first visit by Larry Dart (RS, MTS, GS).
Electric Charge
Powerful weapon used by alien raider Voltek to disable ships and steal their cargo (TVC10)..
Electric Discharge Guns
Devices used to counteract the effects of the 'walking water' from Jupiter (WJ)..
Electromagnetic Field
Supposedly a by-product of the Galasphere’s interplanetary overdrive, the flickering bubble of energy that surrounds it in flight. It can be switched on or off, but when on will block the Galasphere’s own scanners and communications. It can also block telepathic influence, act as a defence against missiles and be expanded to encompass other ships, if need be (SN, TR)..
Energy
Strange orange light that hunts down and disintegrates life forms on a vast artificial worldship encountered by Galasphere 347. It destroys one of the wild quadrapeds, allowing enough time for Dart, Slim and Haggarty to escape, and may have been the cause of the disappearance of the occupants (AN02)
Exclaimations
Language is very polite and expletive free in 2100 but occasionally characters have cause to exclaim their surprise or disbelief. Phrases like “Space Help Us!” (Brog - BS), “Space Around Me!” (Raeburn - GT) and "Space Race!" (Raeburn - TB) seem the favourites, though the Irish Professor Haggarty uses his own particular brand of native phrases such as "Bejabbers!" and "Shivering Shamrocks!"
Explosives
Dynamite is still widely used in 2100 (WA, HF) although nuclear devices still exist (HF, ES). All Galaspheres reputedly carry a small supply of explosives, according to Colonel Raeburn (ES). The Deltees of Alpha Centauri have an similar explosive they call tynite (DS)
Eye
Defensive device invented by Venusian scientist Borra. It can detect any craft not made of metals from Venus, Earth and Mars and destroy them. Regretably Borra forgets that Galaspheres are made from Plutonite, from Pluto, and the destruction of Galasphere 347 is only just averted during a test. Borra is killed under unusual circumstances travelling to adjust the Eye, and when it prevents anything from approaching it has to be destroyed (EV).
F
Faster Than Light Travel - see Delta Power Unit and Ruminov Metal.
Fendoe, Doctor (left)
Boss of the Dectium mines on asteroid Omega, who attempts to blackmail Earth into paying whatever price he wants for the rare metal (TVC04).
Fishing
Still in evidence on Venus, though the evolving Tula Fish took umbrage to the business (HF). It is still a relaxing recreational, and Marla suggests it as a break for Colonel Raeburn (DW). It is also a favourite holiday pasttime of Larry Dart (WA, RR) though it does occasioally get him into trouble... (TVC01, TVC02)
Floats, The
Muscular wasting condition, caused by continual living in low or zero gravity environments such the Moon or artificial satellites. The muscles atrophy to such a degree that the body shuts down, killing a person. It is cured by a protein, or synthesised version of it, found in the square eggs of the Aba Bird from Mars (HI).
Flora
World which is home to advanced and potentially hostile plant life and where contact with two Galaspheres had been lost. It is discovered the plants had enslaved the native humanoids and also the Galasphere crews (TVC08).
Flying Saucer
Getaway craft used by a gang of crooks to leave Earth with stolen gold bullion (TVC02).
Fowler, Captain
Space Patrol officer in overall charge of a two Galasphere mission to newly discovered planet M17. He is court-martialed when his second-in-command Lieutenant Roget lands his Galasphere despite there scenes of strange alien monsters there (HS01).
Franc
Unit of currency on both Venus (UA) and Mars (SF).
Freezer Unit (right)
All Galaspheres have freezer units, to send the crew into hibernation for the long transit times involved in traversing the solar system. There is also a freezer unit in the Space Headquarters hospital (SS). Dart sometimes refers to the Galasphere unit as ‘the freezer locker’ (UA, WB)..
Freezer Unit, Portable
Sealed container resembling a clear sleeping bag, used to transport Husky to Professor Zeffer’s observatory on Mars in an attempt to cure him of his invisible condition (HI).
Freighter
See Husky's Technical Manual: Freighters
Freighter denied the latest shipment of the rare metal Dectium from the asteroid Omega (TVC04).
Presumably another term for the United Galactic Army (SJ)..
Possibly another term for the United Galactic Organisation (TVC11)..
Galasphere despatched by Space Headquarters to divert the freighter convoy back to Ganymede (ES)..
Galasphere ordered to return to Earth by Robot Control during the Duo invasion (II).
One of two Galaspheres sent to explore planet M17, and commanded by Lieutenant Roget (HS01).
Galasphere in the vicinity of Mars that gives a bearing on the escaping criminal saucer (TVC02).
An accurate of a Galasphere is difficult to determine, as even the scale and size is questionable when seen in relation to its crew. Entry is usually via the vacuum door (or doors - it is unclear whether there is more than one) in the ring. Given the size of a door on the outer ring, which is used by the docking facility at Space Headquarters, the ship could be about 60 feet (18 metres) high with a ring diameter of about 65 feet (20 metres) but this would make it rather small especially when seen in relation to a colony ship supposedly housing 1000 people (SN). Even the size of the control room and other areas of the Galasphere seem incongruous with its external size.
The Venusian Tara controls all the gold mines on Callisto, and inspects them every day (TS)
Apparent still considered a relaxing pasttime in 2100, though not necessarily by Larry Dart (RR)
Gabblerdictumese for pencil (SN).
Haggarty, Professor Aloysius O’Brien O’Rourke
See Husky's Technical Manual: Hover Jets
See Husky's Technical Manual: Interceptors
Some freighters have jet engines for atmospheric flight (VV).
It is openly stated that two other warring cultures, the Dells and the Miocells, inhabit the northern hemisphere of the planet in the Secret Weapon storybook. While this is feasible, as Jupiter is still being explored in the series and ionospheric storms may have delayed their discovery, it does seem to contradict what is seen on-screen.
A hobby, Husky implies, among lonely Martian crewmembers (MM)
Proper name, apparently, for the common cold germ (MTS)
Early description of the Uranian Duo plant creatures (DP, EVT).
