Perfect Atari ST/XE color match!
37 replies to this topic
#26 MEtalGuy66 OFFLINE
MEtalGuy66
  • 2,774 posts
  • If it aint broke, fix it anyway!
Posted Wed Sep 26, 2007 7:46 PM
This is My friend's "Eddie Van Halen Signature Series" A500 that he painted back in about 1989..
Notice the area where you rpalms rest when typing..
(also notice where his girlfriend scratched her name into it.)
This was done with Spray-can paint.
If you are going to paint a machine, unless your never going to use it, your better off leaving it alone, then using paint from a spray can.
If they ever figure out how to make a 2-part chemically activated spray can, where it mixes activator and base as it sprays, then that might be ok.
But the way things are now, save the spray can paint for the barbecue pit, or the lawn mower...
Cool paint job!
Well I doubt back in 1989 they had special spray paint for plastics, and even if they did, did your friend use this type? I doubt it.
I used Testors model spray paint which is designed for plastic. It should be good. If not just spray it again, LOL
Heh. Ill say this again. NO PAINT that is not mixed as a two part, meaning the base is the actual paint, and a catalytic "activator" is added the time that you mix/apply the paint... NO PAINT that is not chemically hardened is anything resembling durable.. Im sure the testors paint has excellent properties for adhesion to plastics. Unfortunately, that has nothing to do with the paints resistance to wear, or resistance to chemicals.. Models are not designed to be handled frequently and extensively. Even the stuff that they have NOWADAYZE that is advertised and sold for use on car interior plastic pieces and comes out of a spray can doesnt last. Its great if you plan to sell the vehicle soon.. Otherwise, take it to a trim shop where they can use a professional (once again, chemically activated) product.
Edited by MEtalGuy66, Wed Sep 26, 2007 7:48 PM.
#27 Beetle OFFLINE
Beetle
    Dragonstomper
  • 515 posts
  • Atarian at 8, 16, 32 and 64 Bits
Posted Thu Sep 27, 2007 4:42 PM
I'll double that. I have to handle my spray can painted 1250XLD and 1001 like raw eggs, so the don't get scratched.
The 1001 is always wrapped in a towel when going to shows, the 1250XLD has a false leather cover and a big cardbox with a styrofoam mold.
I think my laptop will go to a car paint company or something alike for its final paintjob.
#28 wood_jl OFFLINE
wood_jl
  • 6,910 posts
Posted Sat Apr 17, 2010 8:29 PM
Here is a SF354 I modded with a 720K mech. It was also very yellow, so I decided to paint it with Testors Light Sea Gray. Turned out nice!
BUMP TO AN OLD THREAD!!
I was really wondering about this and glad you pointed to it from the XF551 thread, as I have recently had bad luck with the un-yellowing of an extremely yellowed SF314.
So I am going to look for a hobby store that carries yours and Wgungfu's paint. I was thinking of posting a question about this. Belated thanks for the info.
Question about the drive mech: What kind is it? Where did you get it? Did you have to solder in a new (longer) cable to flip it?
How did you get it to mount "behind" (slightly) the position of the original mech? I mean, if the faceplate of the original mech is embedded in the front wall of the drive case, and the new mech (with faceplate attached) is "behind the wall" then did you have to drill new holes in the bottom of the case for the screws to line up?
They do the same thing to an internal ST drive in this picture:
Posted Image
.....which is from this auction....
eBay Auction -- Item Number: 150431598076
.....from "atarifreakz" in the U.K.
Thanks for any info!
#29 tjlazer OFFLINE
tjlazer
  • 2,143 posts
  • Retro Atari Addict
Posted Sat Apr 17, 2010 9:39 PM
It's a Chinon FZ-357 1.44MB drive. I chose it because I did not have to use a longer floppy cable or power cable. It fit perfectly. Other mechs had to have the cable "flipped" and extended.
Posted Image
I did nothing, it just lined up by itself! I may have used some spacers to set the drive level but that's it!
I actualy just got a really yellow XF551 drive with a broken mech that I converted to a Bob Woolley 720k drive! I will be performing Retro brite on it and painting the white drive face gray with the Testors Gray paint...
Edited by tjlazer, Sat Apr 17, 2010 9:42 PM.
#30 frogstar_robot OFFLINE
frogstar_robot
    Dragonstomper
  • 754 posts
Posted Sat Apr 17, 2010 9:57 PM
They probably did. My Dad and I used to rehabilitate faded car dashboards with paints specifically designed for automotive plastics. The first time we did this was 91 or so and I didn't have the impression it was spiffy new tech then. This stuff was a bit different from the Testor's model paints. You clean the interior parts first then spray a fast drying pre-treatment which just provided a good surface for the paint that was designed for it.
I drove one of those cars for a few years and didn't have any problems with the paint fading or coming off.
#31 mimo OFFLINE
mimo
    Preppie!
  • 6,826 posts
  • It's easy living in a bubble
Posted Sun Apr 18, 2010 3:04 AM
Krylon fusion is supposed to be really good for painting plastics as it bonds to the plastic rather than sit on the top like regular paint
#32 UNIXcoffee928 OFFLINE
UNIXcoffee928
  • 1,177 posts
Posted Tue Apr 20, 2010 9:56 PM
Now THAT is cool! That is a One of A Kind piece of Amiga User History, right there! Badassed!
#33 monzamess OFFLINE
monzamess
    Dragonstomper
  • 575 posts
Posted Fri Nov 3, 2017 6:08 PM
I recently saw a suggestion that Rust-Oleum Painter's Touch Stone Gray Satin is a good match for XE Gray:
https://www.homedepo...49855/205585746
I tried some on the monitor/TV I use with my XE and I do think it's a good match.
Before:
After:
#34 tjlazer OFFLINE
tjlazer
  • 2,143 posts
Posted Sat Mar 31, 2018 11:41 AM
Looks good!  Does it match well in person?
#35 monzamess OFFLINE
monzamess
    Dragonstomper
  • 575 posts
Posted Mon Jun 11, 2018 12:36 PM
Yes, matches as well in person as in the picture.
#36 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Jun 11, 2018 11:32 PM
Just to preventief any wrong informatief: No Atari computer case ever was painted in the factors. All have their color mixed into the plastic. This false conclusion of ST cases being painted is caused by the fact that the inside of some ST computers had a red painted coating on the inside. This is conductrice paint used as a cheap and dirty alternatieve for the metal shield.
I've tried painting a SM125 monitor but the dolor I used turned out to be not a perfect match....although it did improve the looks of it greatly. This was a case beyond Retrobrighting. I would always try Retrobrighting first. I've had excellent results with both XL and Xe and ST. Only this SM125 came out totally blotched,.....but then again it had the worst case of yellowing.....actually more browning I've ever seen.
I feel paint takes away a bit of the structure of the plastic. Definitely do not sand I feel not absolutely necessary as this will take away even more of the structure.
Painting another device like a TV or monitor is of course a great idea....looks really nice!!!
I always felt it a big shame that Atari never released matching monitors to its 8 bit computer lines and this is a great idea to compensate.
Sadly the listed paints here are usually US only....although I do know that rustoleum painters touch is available here as well, but the cans look different and the color names or codes might differ too.
We use the RAL color system mostly here.in Europe,...anyone has a RAL code that really matched the XE/ST color ?
Edited by Level42, Mon Jun 11, 2018 11:38 PM.
#37 KLund1 OFFLINE
KLund1
    Dragonstomper
  • 633 posts
Posted Tue Jun 12, 2018 4:04 PM
Sometimes painting is the last resort. Back when I was learning how to retro-brite I got several ST cases with terrible case of 'blooming'. The only thing left to do was to paint them back to ST gray. I used both Testors colors above, and their IMOP was a perfect match. though a huge improvement to a bloomed case.
knowing that this a model paint is not meant for handling, a few coats a good quality lacquer will solve that trouble. In fact, after a good retro-brite, a couple lacquer costs should keep the case from yellowing again in our remaining life times.
#38 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Thu Jun 14, 2018 3:30 PM
Doesn't lacquer make the result shiny ?
I actually found out that Rustoleum Painters touch is readily available, at least over here in The Netherlands so probably in the rest of Europe too.
http://www.rustoleum...painters-touch/
Looks like they have the same colors too.... Steen grijs = Stone gray
By the way....4 bucks for a spray paint like that is amazingly cheap....I bet I'll pay at least twice that amount in Euros.....
Anyway.....gonna look to find one of those.
Edited by Level42, Thu Jun 14, 2018 3:37 PM.
