Is a 5200 Gauntlet possible?
14 replies to this topic
#1 RangerG OFFLINE
RangerG
  • 2,898 posts
Posted Tue Jul 2, 2002 12:44 PM
I love that people are making new games for the 5200. One of my all-time favorite games is Gauntlet (not the obscure 2600 one). I know the Atari 8 bit computers play Gauntlet (but I believe it is a disk). Could this be ported to the 5200 or could a 5200 Gauntlet be programmed or could Dark Chambers be made and hacked into Gauntlet? The Atari 5200 4 port could have all four characters playing at once just like the arcade (or would this be impossible on the 5200)?
#2 Cafeman OFFLINE
Cafeman
    cheap koffi maker
  • 6,585 posts
Posted Tue Jul 2, 2002 1:04 PM
I never played the Atari 8bit version, but I say that a direct port should be possible. After the game boots up, is there ever any more loading from the disk?
#3 Jetboot Jack OFFLINE
Jetboot Jack
  • 1,788 posts
  • Making Games
Posted Tue Jul 2, 2002 1:55 PM
8bit Gauntlet loads every level from disc - its a 2 disc (or a flippy) game...
sTeVE
#4 Cafeman OFFLINE
Cafeman
    cheap koffi maker
  • 6,585 posts
Posted Tue Jul 2, 2002 2:03 PM
Wow. Then forget a direct port, even a 32K cart wouldn't hold enough memory. I need to fire up this game on Atari800win tonight and check it out, assuming the ROM is around. That means that every level has full use of the RAM. It'd have to be trimmed.
#5 Albert OFFLINE
Albert
  • 34,452 posts
Posted Tue Jul 2, 2002 2:08 PM
How big is each level? I can't imagine that you'd really need two-discs to hold this game if you were compressing and optimizing the hell out of everything. It's just a fairly simple tile-based game that uses a ton of sprites for the player(s), enemies and shots. :)
..Al
#6 RCorcoran OFFLINE
RCorcoran
    Dragonstomper
  • 526 posts
Posted Thu Jul 4, 2002 1:46 PM
Check here if you want to see various Gauntlet versions as well as the data disk:
http://homepages.par...nz/atari/g.html
#7 ziggystar OFFLINE
ziggystar
    Dragonstomper
  • 565 posts
Posted Thu Mar 29, 2012 5:06 PM
It's possible, but there will not be a lot of levels like the floppy disk version. I'll be using every trick in the book to get the 32 levels I have for a goal.
#8 CPUWIZ OFFLINE
CPUWIZ
    Commander
  • 34,006 posts
  • I am the one who knocks!
Posted Thu Mar 29, 2012 6:24 PM
Ten year long answer, coming right up. LOL
Can't wait to see where you are going with that. :)
#9 walter_J64bit OFFLINE
walter_J64bit
  • 5,126 posts
Posted Fri Mar 30, 2012 4:36 AM
I can't wait to see the game up and running, I'm not much of a fan of the A8 version Gauntlet, It's always seem to me that the game was rushed out the door! :spidey:
Edited by walter_J64bit, Fri Mar 30, 2012 4:37 AM.
#10 Wrathchild OFFLINE
Wrathchild
  • 1,952 posts
Posted Fri Mar 30, 2012 6:31 AM
Having squeezed the original into a 128KB cart for the A8 I can say a 5200 port wouldn't be so straight forward as you'd need to relocate most of the RAM memory usage to the lower 16K and also I'd think that working RAM required maybe > 16K.
#11 Charlie_ ONLINE
Charlie_
  • 2,892 posts
Posted Fri Mar 30, 2012 7:19 AM
I look forward to Ziggy's game.
Couldn't the original gauntlet be made to work with Atarimax SD cart? Seems like a great project for it.
#12 RosenbumThe3rd OFFLINE
RosenbumThe3rd
    Space Invader
  • 24 posts
  • I beg your pardon?
Posted Fri Mar 30, 2012 9:25 AM
Gauntlet on the 5200. That sounds marvelous! I honestly can't tell you how many quarters I plopped into the arcade version during my youth. At the time, the wizard was my favorite character then, later the Barbarian and eventually the Valkyrie.
Such memories are a thing to treasure.
I should also like to see this on the 7800.
#13 littleman jack OFFLINE
littleman jack
  • 1,363 posts
  • One day I will build tube amps.
Posted Thu Apr 12, 2012 6:54 PM
Take a look at this thread in the 5200 forum:
http://www.atariage....rsary-surprise/
#14 Cafeman OFFLINE
Cafeman
    cheap koffi maker
  • 6,585 posts
Posted Thu Apr 12, 2012 9:28 PM
I have no memory of this discussion from 2002!
#15 fernando marrin OFFLINE
fernando marrin
    Dragonstomper
  • 599 posts
Posted Fri Apr 20, 2012 7:18 AM
john,
hope with this release you work things out with steve,
put some Drm on them ,
and sell all your roms for the ultimate sd cart ! :mad:
