Code Snippets & Samples for bB Beginners
51 replies to this topic
#26 Mordekai OFFLINE
Mordekai
    Combat Commando
  • 9 posts
Posted Sat Jul 18, 2009 7:50 PM
These samples are fantastic! Thanks for making these available.
M.
#27 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Thu Jul 23, 2009 4:46 PM
Can anyone show me how to make a scrolling playfield?
Horizontal or Vertical Scroll?
#28 Animan OFFLINE
Animan
  • 2,391 posts
  • Just some guy who plays Atari and watches Anime.
Posted Sat Jul 25, 2009 9:48 AM
Nevermind, i know how it's done.
#29 disjaukifa OFFLINE
disjaukifa
  • 2,125 posts
  • Berzerker In Training
Posted Fri Sep 18, 2009 9:56 PM
I know this is probably going to be complicated, but I am making a Galxian/Space Invaders game called Earth Invaders, and I have my ship, I have the play field, I have the missile . . . well I don't have the missile working yet but hope to soon.
Here is what I have yet to figure out, how exactly do I make the enemys??? Also if someone could send me a link that explains frames that would be helpful!!!!
Thanks
Disjaukifa
Edited by disjaukifa, Fri Sep 18, 2009 9:56 PM.
#30 endrien OFFLINE
endrien
    Chopper Commander
  • 184 posts
Posted Sat Oct 3, 2009 5:34 AM
This might sound a fair bit "Noobish" but how can you combine these codes? Any time I try add missiles to movement it doesn't work..
#31 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
  • 10 PRINT CHR$(205.5+RND(1));
Posted Wed Mar 10, 2010 8:22 AM
I know your post was 5 months ago, but I can work on combining a few of the samples, yes. I just posted another sample that demonstrates how to use bankswitching.
Steve
#32 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Wed Mar 10, 2010 2:23 PM
Steve
As requested, I added another demo file (#14 in the first post) that shows how to combine a moving animated player sprite with the ability to fire in any direction, including diagonally.
Steve
#33 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Fri Mar 12, 2010 6:01 PM
I added another sample to the first post (#15). This one demostrates collision detection for a player sprite inside of a room from all directions. It's really simple and efficient. The code was actually pulled from the old "move around rooms" demo from SeaGtGruff - it's great code and I've used it in several of my games.
Steve
#34 Cliff Friedel OFFLINE
Cliff Friedel
    Dragonstomper
  • 603 posts
Posted Wed Mar 17, 2010 10:43 PM
Anyone happen to have an example of a sound system subroutine that can be called from a main loop? The only way I can think of doing this would be to have the sound registers, a duration, the voice it belongs to (0 or 1)and then having it do something like
subroutine
if a = 1 then read data : load sound registers for voice
if a=duration variable then turn off audv0 or audv1 : a = 0 : return
a = a + 1
return
This seems like it would work, but I figured I would ask before trying it and wasting time (and bytes). Any other ideas?
Cliff
#35 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 28,952 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Thu Mar 18, 2010 4:52 PM
subroutine
a = a + 1
return
Cliff
You mean like the kind of thing that the Music and Sound Editor can create? Right now it creates code using sdata, based on the Music Starter using sdata, but after the next update it will also create code that uses regular data if you want that will look like this:
rem  *****************************************************
   rem  *
   rem  *  Music Starter using data
   rem  *
   rem  *  Based on code posted in the Ballblazer thread at AtariAge:
   rem  *  http://www.atariage.com/forums/index.php?s=&showtopic=130990&view=findpost&p=1615280
   rem  *
   rem  *  Code adapted by Duane Alan Hahn (Random Terrain)
   rem  *
   rem  *  Explanation:
   rem  *  This has a 256-byte limitation.
   rem  *
   set smartbranching on
   rem  *  Create aliases for variables
   dim duration=a
   dim rand16=z
   rem  *  Variable descriptions
   rem  *  duration - how long each note plays
   rem  *  x - data counter
   rem  *  rand16 - makes better random numbers
   rem  *  Volume off
   AUDV0=0
   AUDV1=0
   rem  *  Initialize duration and data counter
   duration = 1 : x = 0
   rem  *
   rem  *  Main game loop starts here.
   rem  *
MainLoop
   goto GetMusic
GotMusic
   drawscreen
   goto MainLoop
   rem  *  Music
GetMusic
   rem  *  Check for end of current note
   duration = duration - 1
   if duration>0 then GotMusic
   rem  *  Retrieve channel 0 data
   temp4 = musicData[x] : x = x + 1
   temp5 = musicData[x] : x = x + 1
   temp6 = musicData[x] : x = x + 1
   rem  *  Check for end of data
   if temp4=255 then duration = 1 : x = 0 : goto GotMusic
   rem  *  Play channel 0
   AUDV0 = temp4
   AUDC0 = temp5
   AUDF0 = temp6
   rem  *  Retrieve channel 1 data
   rem  *  Play channel 1
   AUDV1 = temp4
   AUDC1 = temp5
   AUDF1 = temp6
   rem  *  Set duration
   duration = musicData[x] : x = x + 1
   goto GotMusic
   rem  *  Music Data Block
   rem  *  Format:
   rem  *  v,c,f (channel 0)
   rem  *  v,c,f (channel 1)
   rem  *  d
   rem  *
   rem  *  Explanation:
   rem  *  v - volume (0 to 15)
   rem  *  c - control [a.k.a. tone, voice, and distortion] (0 to 15)
   rem  *  f - frequency (0 to 31)
   rem  *  d - duration
   data musicData
   8,12,29
   0,0,0
   15
   2,12,29
   0,0,0
   0,0,0
   15
   2,12,19
   0,0,0
   0,0,0
   15
   2,12,17
   0,0,0
end
   goto GotMusic
#36 Cliff Friedel OFFLINE
Cliff Friedel
    Dragonstomper
  • 603 posts
Posted Thu Mar 18, 2010 10:34 PM
subroutine
a = a + 1
return
Cliff
   rem  *
   rem  *
   rem  *
   rem  *
   rem  *  Explanation:
   rem  *
   dim duration=a
   dim rand16=z
   rem  *  Volume off
   AUDV0=0
   AUDV1=0
   rem  *
   rem  *
MainLoop
   goto GetMusic
GotMusic
   drawscreen
   goto MainLoop
   rem  *  Music
GetMusic
   AUDV0 = temp4
   AUDC0 = temp5
   AUDF0 = temp6
   AUDV1 = temp4
   AUDC1 = temp5
   AUDF1 = temp6
   rem  *  Set duration
   goto GotMusic
   rem  *  Format:
   rem  *  d
   rem  *
   rem  *  Explanation:
   rem  *  d - duration
   data musicData
   8,12,29
   0,0,0
   15
   2,12,29
   0,0,0
   0,0,0
   15
   2,12,19
   0,0,0
   0,0,0
   15
   2,12,17
   0,0,0
end
   goto GotMusic
Thanks. This will definitely do what I want. I was hoping to maybe reduce the data size per note to 5 being v,c,f,voice,d, but I can see potential issues with syncing the voices if I do that. Better to do it the way you have.
Have you thought about posting this to the front of the thread? This is definitely something people could use. Thanks again.
Cliff
#37 rpgfaker OFFLINE
rpgfaker
    Moonsweeper
  • 489 posts
Posted Wed May 26, 2010 11:03 AM
Steve
Steve
Hi Steve I was playing around with this code and made an alternate version
  rem *******alternative move and fire in 8 directions + animation, variable cost = 7
  rem modification saves 18 bytes adds 1 variable & fixes player reflection
  rem ------------------------------------------------------------------------------------
   rem Demo for moving an animated sprite that can fire a missile in any direction
   rem
   rem   You can move around your sprite and fire in any direction.
   rem
   rem  In trying to keep this code as short as possible, I left out the following:
   rem   There is no collision detection
   rem   There are no enemies to shoot at
   rem   player movement is not restricted, you can move off of the screen
   rem   There is no defined playfield
   rem  Variables
   rem
   rem     I set the inital direction of the joystick to RIGHT, so when you start
   rem     the game for the first time you're able to fire the gun before you move
   rem
   a=76   : rem player1x location
   b=50   : rem player1y location
   c{1}=0 : rem Turned on if the last location of the joystick was UP
   c{2}=0 : rem Turned on if the last location of the joystick was DOWN
   c{3}=0 : rem Turned on if the last location of the joystick was LEFT
   c{4}=1 : rem Turned on if the last location of the joystick was RIGHT
   c{5}=0 :rem Turned on if the last location of the joystick was UP+LEFT
   c{6}=0 :rem Turned on if the last location of the joystick was UP+RIGHT
   c{7}=0 :rem Turned on if the last location of the joystick was DOWN+LEFT
   c{0}=0 :rem Turned on if the last location of the joystick was DOWN+RIGHT
   e=20   : rem Counter for limiting travel of fired missile
   w=1    : rem Used to determine player reflection (REFP1)
   rem y is the animation counter
   rem t replaces the still function from original code
start
 rem reset animation control flag
 t = 0
 rem if reflection is switched 'on' by the w variable this keeps it in place
	if w=0 then REFP1 = 8
	if w=1 then REFP1 = 0
   rem This section sets a value for the last direction the joystick was pushed
   rem
   rem  This determines the direction the bullet will be fired later, and also
   rem  allows you to keep firing the bullet in the same direction after you
   rem  have stopped moving.
   rem
   rem  Each time you move, each of the eight possible directions of the joystick is
   rem  marked as on or off with a bit variable.
   drawscreen
   if joy0up then                c{1}=1:c{2}=0:c{3}=0:c{4}=0:c{5}=0:c{6}=0:c{7}=0:c{0}=0
   if joy0down then              c{1}=0:c{2}=1:c{3}=0:c{4}=0:c{5}=0:c{6}=0:c{7}=0:c{0}=0
   if joy0left then              c{1}=0:c{2}=0:c{3}=1:c{4}=0:c{5}=0:c{6}=0:c{7}=0:c{0}=0
   if joy0right then             c{1}=0:c{2}=0:c{3}=0:c{4}=1:c{5}=0:c{6}=0:c{7}=0:c{0}=0
   if joy0up && joy0left then    c{1}=0:c{2}=0:c{3}=0:c{4}=0:c{5}=1:c{6}=0:c{7}=0:c{0}=0
   if joy0up && joy0right then   c{1}=0:c{2}=0:c{3}=0:c{4}=0:c{5}=0:c{6}=1:c{7}=0:c{0}=0
   if joy0down && joy0left then  c{1}=0:c{2}=0:c{3}=0:c{4}=0:c{5}=0:c{6}=0:c{7}=1:c{0}=0
   if joy0down && joy0right then c{1}=0:c{2}=0:c{3}=0:c{4}=0:c{5}=0:c{6}=0:c{7}=0:c{0}=1
   rem  Set color of player sprites and missiles
   COLUP1=28
   COLUP0=28
   rem  Set initial location of player sprite
   player1x=a:player1y=b
   rem  Increase 20 to a larger number to make the bullets travel farther
   e=e+1
   if e>20 then e=0
   rem  Player Movement
   rem t control variable added to advance animation counter, w ties to reflection
   if joy0up then b=b-1 : t = 1
   if joy0down then b=b+1 : t = 1
   if joy0left then a=a-1 : t = 1 : w = 0
   if joy0right then a=a+1 : t = 1 : w = 1
   if !joy0fire then missile0x=0:missile0y=0:e=0
   rem diagonal shots
   if joy0fire && c{0} then missile0x=player1x+7+e:missile0y=player1y-3+e
   if joy0fire && c{5} then missile0x=player1x-e:missile0y=player1y-7-e
   if joy0fire && c{7} then missile0x=player1x-e:missile0y=player1y+1+e
   if joy0fire && c{6} then missile0x=player1x+7+e:missile0y=player1y-7-e
   rem left and right shots
   if joy0fire && c{3} then missile0x=player1x-e:missile0y=player1y-5
   if joy0fire && c{4} then missile0x=player1x+8+e:missile0y=player1y-5
   rem up and down shots
   if joy0fire && c{1} then missile0x=player1x+5:missile0y=player1y-10-e
   if joy0fire && c{2} then missile0x=player1x+5:missile0y=player1y+3+e
   rem if not moving go to player1 standing position
   if !joy0up && !joy0down && !joy0left && !joy0right then y=10
   rem t is the keytrap tied to joy0 directional movement if active advances animation
   if t = 1 then y=y+1
   rem Player Animation
   rem   Y is the counter for the player animation.  You can change the
   rem   animation rate by changing the 30,20,10 to a different
   rem   sequence of numbers.
   if y=30 then player1:
        000110
        100100
        110100
        011000
        000000
        %10011110
        %01100100
        010000
        011000
        111100
        011000
end
  if y=20 then player1:
        %01000000
        %01100011
        110110
        011100
        101000
        111100
        100100
        010000
        011000
        111100
        011000
end
  if y=10 then player1:
        011100
        011000
        011000
        100000
        %01011010
        %01111100
        100100
        010000
        011000
        111100
        011000
end
 rem if animation counter reaches 30 reset it
   if y>30 then y=0
 rem repeat loop
 goto start
#38 esplonky OFFLINE
esplonky
    Moonsweeper
  • 442 posts
  • Kinetic, Not synthetic.
Posted Mon Jun 13, 2011 11:31 AM
can someone show me Completely how to do sound with more than just a source code file? (like show me where to put things and how they work and stuff) i looked at the sound source code from RT but it was confusing.
#39 Jr. Pac OFFLINE
Jr. Pac
    Dragonstomper
  • 775 posts
  • 1/4 of the fun with an Atari cart is cleaning it.
Posted Tue Jul 26, 2011 9:43 AM
Thanks!!!
#40 esplonky OFFLINE
esplonky
    Moonsweeper
  • 442 posts
Posted Mon Apr 30, 2012 11:11 AM
You should do a thread that has code snippets for intermediate programmers, like ones that use includes and Bit operations etc
#41 Rabbit 2600 OFFLINE
Rabbit 2600
    Dragonstomper
  • 745 posts
Posted Sat Oct 13, 2012 11:37 AM
Could you do a snippet about making enemies following the player in a well documented way?
#42 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Mon Oct 29, 2012 10:01 PM
Yes, I could make a sample program that demonstrates that, it's pretty easy to do, but it may be a little while before I could put it together and post a well documented example. I never seem to have time for Atari related projects any more. :( I did post a sample of an enemy following a player with a very rudimentary AI here: http://www.atariage....78934-enemy-ai/ , although the source isn't as well documented as the other examples in this thread. I'll keep it in mind and try to do a more basic, well documented example soon.
Steve
#43 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Wed Oct 31, 2012 7:48 AM
I posted a very simple example of how to make an enemy sprite follow a player sprite in the first post.
#44 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Wed Oct 31, 2012 7:49 AM
That's a good idea, I may start doing something like that when I get some time.
#45 Udonge OFFLINE
Udonge
    Space Invader
  • 31 posts
  • Moon Rabit of Insanity
Posted Sat Mar 30, 2013 9:15 PM
I'd like a sample that demonstrates the use of the Game Select switch for game variations. Seems there's everything here but that.
#46 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,314 posts
Posted Sat Mar 30, 2013 9:19 PM
My last game M.M.S.B.C. II has a difficulty select feature:
http://atariage.com/...6-mmsbc-2-done/
You can see the relevent code starting in the select_level label
This isn't an example. Should at least give you in idea of what working code looks like :)
#47 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Sat Mar 30, 2013 9:31 PM
Thanks for pointing out your MMSBC code, loon, that is a very good example. I'll work on a simple standalone example for this thread as soon as time allows.
Steve
#48 DemonoidTentacle OFFLINE
DemonoidTentacle
    Moonsweeper
  • 453 posts
Posted Wed Sep 18, 2013 3:56 AM
I just had to let you know, you are amazing for sharing all those files with us. I'm working my way through them, and your structure of showing us beginners is excellent!
#49 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Sat Jun 14, 2014 8:26 AM
I should have added these links to this thread a long time ago and I put them in the first post too (along with a few others).  Here's some excellent tutorials from other AA Members.
From CurtisP:  Programming Tutorial
From SeaGtGruff:   Tutorial Session 1 | Tutorial Session 2 | Tutorial Session 3
#50 freshbrood OFFLINE
freshbrood
    Star Raider
  • 81 posts
Posted Wed Mar 8, 2017 1:41 AM
Would someone please offer me some .bas examples of playfield resolutions? I can't figure out how to change the size of the playfield blocks, and I know it should be quite simple. Also some DPC+ .bas examples/tutorials would be much appreciated. Thanks.
