Bee Ball - 2600
146 replies to this topic
#126 LS_Dracon OFFLINE
LS_Dracon
    Dragonstomper
  • 701 posts
Posted Tue Nov 27, 2007 4:39 PM
It's easy port to SECAM, if you have a PAL version, as stella programming guide say, both had same screen format, just needed change the colors.
I don't know about colors limitations, but secam had a good looking black and white image... If it's intentional, secam consoles give priority to B/W televisions, maybe make sence in end of 70's.
Edited by LS_Dracon, Tue Nov 27, 2007 4:40 PM.
#127 kenfused OFFLINE
kenfused
  • 1,314 posts
Posted Tue Nov 27, 2007 11:13 PM
At any rate, why is SECAM limited to so few colors? That sure is quite a contrast from the PAL and NTSC versions!
..Al
If it is like the 8-bit computers I think they use the 3 bit brightness to actually select colors (hue is ignored). I am guessing one bit is R, G and B which can then be mixed for 8 colors. Probably similar to a CGA type color in its capabilities. Of course I might be completely wrong in my understanding. I am guessing it was cheapest to do it that way.
#128 Albert OFFLINE
Albert
  • 32,787 posts
Posted Wed Nov 28, 2007 9:32 PM
I just played the latest version and it looks and plays great! However, I ran into an interesting bug while playing. At one point, and I'm not sure how it happened, the computer's racket became "detached" from the computer player, in a fixed "x" position on the screen. I happened to have my camera setup, and was able to take some video of what happened. Eventually the computer fixed itself, after I finally took a stab at getting the ball over the net (looks like when the computer raised his racket in defense).
The game was playing the racket "swooshing" sound repeatedly while the racket was screwed up. It stopped once I finally took a swing. You can hear this in the video:
http://www.atariage..../beeballbug.avi
..Al
#129 LS_Dracon OFFLINE
LS_Dracon
    Dragonstomper
  • 701 posts
Posted Fri Nov 30, 2007 4:47 PM
And here's the new roms. Fixed (I hope) this raquet bug.
If you find bugs, please let me know ;)
Edited by LS_Dracon, Sat Dec 1, 2007 3:10 PM.
#130 Nathan Strum OFFLINE
Nathan Strum
  • 6,726 posts
  • Enjoying a sandwich
Posted Fri Nov 30, 2007 10:04 PM
Two things:
First, I found a bug. Sometimes, the ball will pass right between your racquet and head. Shown here, as the computer hits it right through my bee:
http://muse2.calarts...quetbug_web.mov
Second, the AI is excellent now - except you can still bounce the ball off your paddle, and stroke it past the other bee during a serve. But just barely, and not all the time.
At 27 seconds and 59 seconds, the AI successfully defends against this. It's almost there! If he could just respond a tiny bit quicker, you'd have it!
http://muse2.calarts...lserve3_web.mov
The game is great fun! And, apart from that one AI issue, nicely challenging. :thumbsup:
#131 LS_Dracon OFFLINE
LS_Dracon
    Dragonstomper
  • 701 posts
Posted Sat Dec 1, 2007 3:08 PM
Tanks for help, Nathan. :)
-Incremented by 1 pixel the head butt tolerance.
-Fixed the block code, I need work in it more, becouse now is the upper area the problem...
-Title screen in PAL version get a downgrade, sadly, I need use that bytes for AI.
Edited by LS_Dracon, Sat Dec 8, 2007 7:26 AM.
#132 rheffera OFFLINE
rheffera
    Dragonstomper
  • 563 posts
  • Mr.Data Set course for planet Stella
Posted Sun Dec 2, 2007 5:01 AM
Fair enough dracon. I will test it shortly
#133 LS_Dracon OFFLINE
LS_Dracon
    Dragonstomper
  • 701 posts
Posted Sun Dec 2, 2007 3:09 PM
Ok another update :
- AI fixes
- Net is 2 lines lower
- 100% of rom space used.
People, as no more rom space, the game is finished!
Sorry to not use all of ideas posted here, I'm novice programmer, and don't have a good skill to explore at maximun the 2600.
Originally this game was to be single player, with no button use.
Entire game was re-coded 2 times, and every single code (movement, collisions, button moves, animations, ball, kernal, AI etc...) was rewrite at least 3 times!
90% Of codes in this game I never use before, the true only sprite draw and a bit of animation I already had study. The fractional movement, 48 bit sprites, repositioning multiple objects, music, AI etc... is completly new for me.
I need say thanks for everyone who tested this game, and give-me feedbacks.
Thanks to Albert, Nathan Strum, SpiceWare, Impaler_26, BlackJack, rheffera, Alex_79, R-Type2600, Cybergoth, espire8 and all people from Atari Age forum :)
Special thanks to Michael (SeaGTGruff) he post nothing in this topic, but help-me in the first bug I fond, in prototipe version. This game I started to code in Dez/06 so 1 year working on it, I need some days of vacation :P
Just for curiosity, in fist post I told this game was created by one friend. He create the main game concept (that is, bee using raquets). This port to Atari 2600 is very different, in original the bee don't use button, you can't do a stroke or block. Don't have a Bee Judge serving balls and other things. But the interesting, this friend create this concept based in a mosquito character I create in 2003. I draw some sprites and he use some elements in his game. I don't have the original game anymore, I lost it, but I found a SnapShot, see the image below. :)
#134 Nathan Strum OFFLINE
Nathan Strum
  • 6,726 posts
Posted Sun Dec 2, 2007 4:26 PM
Outstanding work! The AI is vastly improved, and very challenging now. (In fact, it just beat me 8-10 and was ahead of me 6-1 at one point.) :thumbsup:
#135 rheffera OFFLINE
rheffera
    Dragonstomper
  • 563 posts
Posted Sun Dec 2, 2007 6:43 PM
I will test this final version on pal hardware. Do you have any plans to produce it in cartridge form, dracon?
#136 Nathan Strum OFFLINE
Nathan Strum
  • 6,726 posts
Posted Tue Dec 4, 2007 12:20 AM
I have one final suggestion. :)
Out-of-bounds markers, at either end of the court:
Not sure if that can even be done or not, but I thought I'd mention it.
I know it's already implied that if the ball goes offscreen, it's out-of-bounds. But sometimes, it seems to hit right at the corner, and still be counted out of bounds.
I think with a marker there, it would be a little easier to see exactly where that point is, since if it hit on the marker, it would be considered in-bounds.
Edited by Nathan Strum, Tue Dec 4, 2007 12:21 AM.
#137 rheffera OFFLINE
rheffera
    Dragonstomper
  • 563 posts
Posted Thu Dec 13, 2007 1:35 AM
PAL version works perfectly
#138 Gateway OFFLINE
Gateway
  • 2,165 posts
  • Trotter Atari Globetrotter now on Facebook!
Posted Mon Dec 17, 2007 2:44 AM
Hi Dracon,
I only recently have been following your progress on this game and finally tried it out tonight, playtesting your final version. I wanted to give a perspective of a player who hasn't been "getting good" at this game through each update to the bin file( though their comments and suggestions were all valid and some good ideas ) :)
It took me a few games to understand the mechanics of the bees and how the judge bee works. Most of my losses of the ball were just missing the serve from the judge bee until I got a hang of his pattern.
The opponent AI if very fluid and, as somebody else mentioned, moves likes a human opponent might move his bee. I found the funnest part of the game is setting up a block of the opponent's shot and counterstriking his "spike" against me. Also, the ball bouncing off the top of the net is cool especially if it happens after bouncing off the "headbut" by my bee or the opponent's bee. :D
I tested the ntsc version through z26, so I am sure I would have better scores using a joystick on the real hardware, but I still find the gameplay fun and exciting! The graphics are great, especially the hovering effect of the bees and their wing animation. I can't comment on the sound FX as I don't have working speakers at the moment, but all in all, I would like to see this game make it onto a cartridge in the AA store or sold another way. I would buy this game!
Weston :cool:
#139 Albert OFFLINE
Albert
  • 32,787 posts
Posted Mon Dec 17, 2007 10:17 AM
Posted Image
..Al
#140 Mark2008 OFFLINE
Mark2008
    Star Raider
  • 87 posts
Posted Mon Dec 17, 2007 10:35 AM
Ok another update :
- AI fixes
Looking at your screenshot, makes me think you really need a colecovision port!
I do a little bit colecovision coding...pm me, if you want to talk about it...
#141 LS_Dracon OFFLINE
LS_Dracon
    Dragonstomper
  • 701 posts
Posted Mon Dec 17, 2007 5:24 PM
Thank you Weston, the sound fx is my weakness, but I hope people get fun playing this game.
The manual and cart looks better than I was figured. :)
PM sent Mark. ;)
Edit : Here's a new video, for you watch the evolution of this game.
Bee-Ball Final Video
Edited by LS_Dracon, Mon Dec 17, 2007 7:31 PM.
#142 Gateway OFFLINE
Gateway
  • 2,165 posts
Posted Tue Dec 18, 2007 1:56 AM
Posted Image
..Al
:lust:
#143 Nognir OFFLINE
Nognir
    Dragonstomper
  • 761 posts
Posted Tue Dec 18, 2007 4:54 PM
Congratulations to your game LS_Dracon!
It will be a pleasure to write a review about it on my page :)
Hope to get it very soon!
#144 LS_Dracon OFFLINE
LS_Dracon
    Dragonstomper
  • 701 posts
Posted Wed Dec 19, 2007 5:41 PM
I'll be glad Nognir, let me know when the review is done ;)
#145 Tom_Explodes OFFLINE
Tom_Explodes
    Moonsweeper
  • 419 posts
  • Pooping in the hamper
Posted Thu Jan 3, 2008 12:29 AM
Whew! I just played the rom of this for the first time. Man, was that hard. I started getting the hang of it after the first game, though, and I did a little better the second time. This is really very good. I might have a complaint or two about the movement speed of my player, but, that's probably just my own suckage. Hehe. Seriously, this is great. Good work!
#146 tremoloman2006 OFFLINE
tremoloman2006
  • 1,735 posts
Posted Wed Jan 9, 2008 10:09 PM
Very nice work! This is an EXCELLENT title! I can't wait to purchase one!
#147 LS_Dracon OFFLINE
LS_Dracon
    Dragonstomper
  • 701 posts
Posted Thu Jan 10, 2008 2:24 PM
Thanks Tom and Tremoloman, the latest binnaries posted here is exactly same you find in a cart. ;)
