Minikernel - Player Scores
102 replies to this topic
#76 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Sun Aug 19, 2018 9:43 AM
I tried some experiments with the multisprite kernel, and I saw in Stella that it overcycles with the 4 scores option as well as two scores plus the main score.  I'm not sure what the difference is other than perhaps the multisprite kernel just uses more visible scanlines than the standard kernel does.
#77 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 401 posts
Posted Sun Aug 19, 2018 3:51 PM
Could you publish that kernel? It would be cool for 4p stuff indeed.
#78 ZackAttack OFFLINE
ZackAttack
    Dragonstomper
  • 760 posts
Posted Sun Aug 19, 2018 6:46 PM
A common problem is page boundary crossing. If you have a branch statement that gets moved because some code is inserted before it you could end up losing a cycle if the branch target is in a different page because of the routine being relocated. Stepping through in stella debugger should let you easily see if this is the case or not.
#79 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Sun Aug 19, 2018 7:09 PM
Yes - I just need to test it more, document it, and make a sample program that uses it.  I'll start a new topic for it when it is ready.
#80 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Sun Aug 19, 2018 7:11 PM
That can throw off cycle counts on individual scanlines, but I don't think it has anything to do with the multisprite kernel specifically going several scanlines past overscan.  I think it may be a side effect of turning off the score, but I would have to investigate more.
#81 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 401 posts
Posted Sat Aug 25, 2018 8:58 AM
Another question, is it possible to change the new score fonts into icons without changing the main score?
http://atariage.com/...re-graphicsasm/
#82 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Sat Aug 25, 2018 10:02 AM
It looks like you found the thread I was about to link to.  I use RevEng's custom score_graphics.asm in every project.  It doesn't take up any more ROM, but allows choosing of different fonts as well as symbols for digit values 10-15.  You can modify one of the available fonts to give you the icons you want, or create your own new font.
#83 MemberAtarian OFFLINE
MemberAtarian
    Moonsweeper
  • 252 posts
Posted Mon Sep 17, 2018 10:53 AM
I just tried to make it compatible with the multisprite kernel, and WoW, after so many years, there is an attempt to do it. :) I'm gonna check it right now, I need at least two standalone digits for my next games Choplifter and Distopia. :)
#84 MemberAtarian OFFLINE
MemberAtarian
    Moonsweeper
  • 252 posts
Posted Mon Sep 17, 2018 12:03 PM
Unfortunately, it's still incompatible with multisprite kernel. The testprogram gives blank screen. The older version runs, as a test program, but including it into a complete code it seems to be rewriting something.
#85 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Mon Sep 17, 2018 12:08 PM
I haven't spent much time looking at this with the Multisprite kernel, but I'll see what I can figure out.  There's a separate issue with the Multisprite kernel when noscore is set, so I'll look at this, too.
#86 MemberAtarian OFFLINE
MemberAtarian
    Moonsweeper
  • 252 posts
Posted Mon Sep 17, 2018 1:44 PM
Okay, I changed a prev. version of you kernel, these two variables are now equal to an address that has no name in the memory map, they seems to be fine.
temp1digit1 = $9e
temp1digit2 = $a0
I'm using a bit modified version of multisprite, but I did only change it so the scoretable is always black and there is a line of the original PF color so you it looks better to the eye.
I have to admit, I did not test it with noscore and 4 numbers, but I will do it with my next game, Dystopia, it will be a strategy game and I will need four number on display as money, population, steps left, turns left.
#87 MemberAtarian OFFLINE
MemberAtarian
    Moonsweeper
  • 252 posts
Posted Mon Sep 17, 2018 1:47 PM
Oh, and I have to say, standard kernel is easy to modify and read, it's well polished, but multisprite seems a bit chunky to me.
For me, the perfect kernel would be one with:
-Non-mirrored playfield
-2 p0+ 2 p1 (so I can make larger, more detailed sprites by pairing them)
-2 piece of 2 digit numbers (like in this kernel)
-6 digits score
#88 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,285 posts
Posted Sat Sep 22, 2018 5:26 AM
temp1digit1 = $9e
temp1digit2 = $a0
Seems to work so far.  Have not stressed it for going overcycle and real hardware yet.
I got the impression the developer of batari BASIC was having trouble finding the cycles for further features on the multi sprite kernel.  If you think you can do better I'd test the heck out of a new multi sprite kernel :)
#89 MemberAtarian OFFLINE
MemberAtarian
    Moonsweeper
  • 252 posts
Posted Sat Sep 22, 2018 5:45 AM
A new multisprite kernel would be really useful for people who wouldn't like to use DPC+. I have seen nowadays a lot of games those could be just std kernel games.
Don't know if it would be possible to keep the "non-mirrored pf", add an extra p1 and p0 and remove the gaps between pf blocks that makes the original std kernel look awful with no sacrifice of missile0.
Btw. that maze looks really cool!
#90 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,811 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Thu Oct 4, 2018 5:35 PM
Another revised version.  Once all of the obvious bugs have been ironed out, I will bundle it in a zip with updated documentation for any others that may benefit from these changes.
Anyway, give this version a shot, and let me know how it works for you.  You will define the variables with something like this:
 dim player0score = y ; Define a variable for this only if pfscore1 is used
 dim player1score = x ; Define a variable for this only if pfscore2 is used
attachicon.gifplayerscores.asm
Does anything special have to be done for it to work with more than one bank? Right now I get this with "inline playerscores.asm" in the last bank:
--- Unresolved Symbol List
onedigitscore            0000 ????         (R )
#91 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Thu Oct 4, 2018 5:39 PM
I don't think so. As normal, minikernels get put in the last bank. Let me know if you see any issues in a multi bank game, though, because I don't think I ever tried it.
#92 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Thu Oct 4, 2018 5:40 PM
Oh I misread that - I'll take a look.
#93 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Thu Oct 4, 2018 5:49 PM
temp1digit1 = $9e
temp1digit2 = $a0
I'm late getting back to this, but these are not unused variables:
$9d    SpriteGfxIndex
$9e
$9f
$a0
$a1
These 5 variables correspond to the 5 virtual sprites.
#94 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Thu Oct 4, 2018 6:10 PM
Looks like that version had a typo.  Those responsible have been sacked.  Here's the latest version.  Maybe I should start putting numbers on these.
Revised playerscores minikernel version 0.1:
Attached File  playerscores.asm   5.57KB   17 downloads
Attached File  playerscores.bas   607bytes   15 downloads
#95 MemberAtarian OFFLINE
MemberAtarian
    Moonsweeper
  • 252 posts
Posted Thu Oct 4, 2018 9:19 PM
$9d    SpriteGfxIndex
$9e
$9f
$a0
$a1
They may be, but using them has no effect on my game somehow. :D It's called luck I guess.
Edited by MemberAtarian, Thu Oct 4, 2018 9:19 PM.
#96 Gemintronic OFFLINE
Gemintronic
  • 9,285 posts
Posted Mon Nov 12, 2018 9:15 AM
I noticed only the combination of these exact files allowed enough time to execute normal game operations - otherwise even a call to the rand command would cause things to go over cycle.
I tested this with both "multi sprite" and "pfcolors no_blank_lines" without going over cycle.  I have not tried the 4 score option (mainly because the below screenshot is what I need.)
I also used the variable z for player1scorecolor as I intend to use the pfscore bars as well.
Attached File  playerscores.zip   3.22KB   14 downloads
Edited by Gemintronic, Mon Nov 12, 2018 9:21 AM.
#97 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Wed Nov 21, 2018 8:18 PM
I like the use of the minikernal to display dice, and I'm rather pleased that this little project I did years ago is being updated and still in use.
#98 bjbest60 OFFLINE
bjbest60
    Chopper Commander
  • 109 posts
Posted Tue Nov 27, 2018 4:32 AM
Repeating a request that was made earlier in this thread:  is it possible to have two six-digit scores?  I'm willing to sacrifice variables!
#99 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Tue Nov 27, 2018 7:36 AM
As a minikernel? Definitely feasible, though I would make it a separate code base than this minikernel. I'll give it a try.
Edit: One limitation to keep in mind is that you will need to have your own functions for changing the value of the second score.  You won't be able to do e.g. score2 = score2 + 100 and have it work the way you would expect.
#100 Karl G OFFLINE
Karl G
    Dragonstomper
  • 648 posts
Posted Tue Nov 27, 2018 7:44 AM
Also, do you want to be able to set the color of the other score dynamically via a variable, or just set it to a static value with a const statement?
