AV mod for 5200
62 replies to this topic
#26 Jess Ragan OFFLINE
Jess Ragan
    Phanto of the Opera
  • 10,236 posts
  • Keys and Thank You
Posted Mon Oct 1, 2007 7:05 PM
Now if I can only convince this guy to make video kits for those of us who never want to be too far from our systems!
#27 mimo OFFLINE
mimo
    Preppie!
  • 6,828 posts
  • It's easy living in a bubble
Posted Tue Oct 2, 2007 2:24 AM
? you mean make the board so you can fit it?
Thats what he is doing for me. No way am I shipping 3 systems to the US and back!!
#28 Prodos8 OFFLINE
Prodos8
  • 2,261 posts
  • Where is John Galt?
Posted Tue Oct 2, 2007 7:53 AM
Just curuious, but are they gonna be solderless (well except the 7800 one) like 8bitdomain's mods? Or, will you need to solder them in yourself?
#29 mimo OFFLINE
mimo
    Preppie!
  • 6,828 posts
Posted Tue Oct 2, 2007 7:59 AM
they will have to be soldered I believe, not a problem for me I don't think
#30 Shawn OFFLINE
Shawn
    As Above
  • 18,982 posts
  • So Below
Posted Tue Oct 2, 2007 8:33 AM
Very basic solidering skill is required. Hell a blind monkey with no hands could do it.
#31 mimo OFFLINE
mimo
    Preppie!
  • 6,828 posts
Posted Tue Oct 2, 2007 8:56 AM
Thats me stuffed then :D
#32 Longhorn Engineer OFFLINE
Longhorn Engineer
    Dragonstomper
  • 927 posts
  • The Engineer of all things Awesome.
Posted Tue Oct 2, 2007 9:18 AM
I am currently working on some PCB designs for 2600, 5200, and 7800 mods should be ready in a couple weeks I hope. This way I can get mods out even faster.
As Shawn said the mods require some basic soldering. Nothing more complicated then attaching some wires to leads. Also you must have a drill to attach the jacks to the back of the case.
Once the PCBs are done I will be making a how to video of how to install each mod.
I would like everyone currently thinking about asking for a video mod to wait till I get the PCBs ordered and in (dont worry Djpudda/mimo). Designs are almost done.
Edited by Longhorn Engineer, Tue Oct 2, 2007 9:24 AM.
#33 Prodos8 OFFLINE
Prodos8
  • 2,261 posts
Posted Tue Oct 2, 2007 9:53 AM
Since they're all basically the same you should be able to design some sort of universal board. Unless, of course, your mods are radically different then the published ones.
#34 mimo OFFLINE
mimo
    Preppie!
  • 6,828 posts
Posted Tue Oct 2, 2007 11:13 AM
Does that mean I am waiting for the boards to arrive.
OK, no worries :D
#35 Longhorn Engineer OFFLINE
Longhorn Engineer
    Dragonstomper
  • 927 posts
Posted Tue Oct 2, 2007 11:55 AM
Correct. Each mod requires different values for resistors and the like but the layout is the same. Each board will be essentially be an Atari 7800 mod. I am currently trying to figure out how I can have both S-Video and Composite outputs coming off the same board like 8-bit does.
#36 mimo OFFLINE
mimo
    Preppie!
  • 6,828 posts
Posted Tue Oct 2, 2007 12:14 PM
cool, i'll wait :D
#37 Prodos8 OFFLINE
Prodos8
  • 2,261 posts
Posted Tue Oct 2, 2007 12:19 PM
They're was a discussion a while back about s-video/composite mods on a ColecoVision. Strattsp was working on the problem and supposedly got it working but never really revealed how.
Here's a link to thread, maybe he could give you an idea:
http://www.atariage....howtopic=104185
#38 Longhorn Engineer OFFLINE
Longhorn Engineer
    Dragonstomper
  • 927 posts
Posted Tue Oct 2, 2007 12:22 PM
Yah I found that thread via google. I was looking at http://www.atarimaga...tlebrother.html since it has Composite and S-Video output. Looks like 2 resistors and a cap.
#39 Prodos8 OFFLINE
Prodos8
  • 2,261 posts
Posted Thu Oct 4, 2007 4:37 PM
For my 7800 s-video A/V mod I've prototyped a PCB layout. I'll probably will do a DIY etch on single sided copper clad board. The design is to fit a 2.5" x 2.5" board.
BTW this layout shold work for the 5200 & 2600 as well for s-video.
Edited by Prodos8, Thu Oct 4, 2007 5:25 PM.
#40 Longhorn Engineer OFFLINE
Longhorn Engineer
    Dragonstomper
  • 927 posts
Posted Thu Oct 4, 2007 6:16 PM
unfortunately it doesn't include the CD4050 that I have started using in my mod. I am going to aim for a single side solution like yours but it is proving difficult because of how the CD4050 is set up (inputs and outputs on the same side of the chip). Ideally I would like the wires that connect the board to the atari to be on one side of the board. Each wire should be color coded to ease anyone that would like to do a self install (also I don't want to label each wire). The outputs will be on the narrow end of the board and they will be either color coded as well.
I've put a good deal of thought into the design of the board (ease of install and the like) I just need the time to design the dam thing (tonight hopefully!).
I am going to try and get about 100 of them made in the beginning. If any of yall' know where I can get a small batch of the boards made for a reasonable price then I should be set. Boards will be single sided (one side solder, one side component) and needs a silk screen on the component side.
#41 Prodos8 OFFLINE
Prodos8
  • 2,261 posts
Posted Thu Oct 4, 2007 6:41 PM
Does the 4050 really increase quality to any degree? From what I've read you might as well leave it out as the resistors and caps are buffer enough. I'm not IEEE though so who am I to say.
For ease of install, you might want to look at single row headers and space them accordingly to allow direct plug in to the TIA/GTIA. Then put a socket on top for the chip to go in. Just my $0.02.
Futurlec.com can fab/desing pcb for a very reasonable price -- they are A1 solid by me.
Edited by Prodos8, Thu Oct 4, 2007 7:03 PM.
#42 Longhorn Engineer OFFLINE
Longhorn Engineer
    Dragonstomper
  • 927 posts
Posted Thu Oct 4, 2007 7:01 PM
The 4050 makes a difference when you move into LCD panels (from what I can gauge on my TV). On normal CRT TVs you can't really see a difference. I would rather include it in the mod just to be safe. Plus they don't cost a lot. I have an engineering mind so I don't see the $0.50 per board dent in the bottom line as a deterrent to get the best product made.
I was thinking about adding the headers much like 8-bits mods but theres a flaw in that not all TIA chips are removable. I want to make a universal mod that will work in any 2600/5200/7800. Plus its a pain in the ass to remove that chip in the 7800 version. Tacking 10 wires onto resistor leads should be pretty simple to do.
#43 Prodos8 OFFLINE
Prodos8
  • 2,261 posts
Posted Thu Oct 4, 2007 7:20 PM
I'll take your word for the LCD/Plasma/? TVs as I only have conventional CRTs. I'm quite happy (up to 36") with them btw.
Even with the stupid 4050 a single sided board must be possible.
#44 Longhorn Engineer OFFLINE
Longhorn Engineer
    Dragonstomper
  • 927 posts
Posted Thu Oct 4, 2007 7:27 PM
Yah I figured it out. Just have to use some jumper wire to cross over the component side of the board. It will be kinda redundant but it will make the board more orderly and easier to make.
#45 Jess Ragan OFFLINE
Jess Ragan
    Phanto of the Opera
  • 10,236 posts
Posted Thu Oct 4, 2007 7:29 PM
Can you make component video mods as well? That'd be sweeeeet.
#46 Prodos8 OFFLINE
Prodos8
  • 2,261 posts
Posted Thu Oct 4, 2007 7:36 PM
s-video = componet video. :ponder:
#47 Longhorn Engineer OFFLINE
Longhorn Engineer
    Dragonstomper
  • 927 posts
Posted Thu Oct 4, 2007 7:39 PM
You would have to convert from S-Video to Component as the TIA chip outputs Chrominance straight up. I would guess it would look worse then S-Video because of the conversion process.
#48 Longhorn Engineer OFFLINE
Longhorn Engineer
    Dragonstomper
  • 927 posts
Posted Sat Oct 6, 2007 3:31 AM
Ok I just finished the design of the pcb just need to test the mod on various Ataris before I get the pcbs made. :D
Finsihed the layout. Got everything to fit on a single layer PCB!
Edited by Longhorn Engineer, Sat Oct 6, 2007 9:06 PM.
#49 Prodos8 OFFLINE
Prodos8
  • 2,261 posts
Posted Mon Oct 8, 2007 3:45 PM
I re-did my layout and added the 4050. It still works on a one sided board. I'm gonna have my friend who works at TI make a couple for me. I'll test it out on my 7800 since it's still RF now.
#50 Longhorn Engineer OFFLINE
Longhorn Engineer
    Dragonstomper
  • 927 posts
Posted Mon Oct 8, 2007 5:35 PM
I stupidly designed the last pcb in a format that the company I am sending it to couldn't read it :dunce:
So heres V1.1
Final board size shrunk down to 55mm x 35mm. Sending it off to get some protos then I will order a 100 or so if they turn out right.
