XF551 PAL
23 replies to this topic
#1 Philsan OFFLINE
Philsan
  • 3,779 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Wed Oct 31, 2007 8:54 AM
I post this topic because at long last Iíve solved the problem and I want save time to people that in the future may have the same troubles (sorry for my English).
The solution is in the last line.
I have connected a new Atari XF551 disk drive from USA to a PAL Atari 130XE.
The drive boots slowly (the sound is "beep - brrrrr - beep - brrrrr" instead of "beep beep beep beep") and sometimes with boot errors.
After having changed different PAL computers, SIO cables, floppy disks, PSUs, the problem remains.
Thanks to MEtalGuy66, I have discovered that the two SIO connectors at the back of the XF551 drives are soldered in place by the actual conductive leads and nothing else.
As a result of plugging and un-plugging cables over time, and since the conductive leads are only soldered to one side of the board, the solder joints crack and become unreliable.
My drive was supposed to be new but anyway Iíve sent the mainboard to MEtalGuy66 who has checked it and removed Atari poor solder and soldered the SIO connectors.
A perfect work, both aesthetically and functionally, but my problem still remains.
Then I have installed an Hyper XF eprom (also burned by MEtalGuy66) and the drive works (apart the fact that itís unable to format in DSDD with AtariDOS XE); this rom image works perfectly both in Europe and America.
A supposed to be PAL eprom didnít work (after 10 seconds the drive mechanic starts doing some horrible noises); Iíve found that it was an NTSC rom patched for a 3.5 drive!
Finally Iíve received from JR> a real PAL rom image (I attach it), classics has quickly burned it for me and now my XF551 works perfectly!
So, if you want to use an American XF551 drive with a PAL Atari, you have to change the original NTSC rom with an eprom containing the attached PAL image (or, if you prefer, an Hyper XF image).
#2 olavese@online.no OFFLINE
olavese@online.no
    Dragonstomper
  • 505 posts
Posted Wed Oct 31, 2007 11:21 AM
Sure it couldn't be fixed with the speed potmeter? I remember having 1050's from US and they did not have same speed as PAL ones. Just tune it (I use DOS 2.6f) and all was well. Don't know if the XF551 has the same potmeter, but if it does, you could try
#3 reliant73 OFFLINE
reliant73
    Space Invader
  • 37 posts
  • Happily restoring my 130XE
Posted Thu Aug 29, 2013 2:32 PM
I post this topic because at long last I’ve solved the problem and I want save time to people that in the future may have the same troubles (sorry for my English).
My drive was supposed to be new but anyway I’ve sent the mainboard to MEtalGuy66 who has checked it and removed Atari poor solder and soldered the SIO connectors.
Then I have installed an Hyper XF eprom (also burned by MEtalGuy66) and the drive works (apart the fact that it’s unable to format in DSDD with AtariDOS XE); this rom image works perfectly both in Europe and America.
A supposed to be PAL eprom didn’t work (after 10 seconds the drive mechanic starts doing some horrible noises); I’ve found that it was an NTSC rom patched for a 3.5 drive!
Finally I’ve received from JR> a real PAL rom image (I attach it), classics has quickly burned it for me and now my XF551 works perfectly!
Hi Guys,
I know this is an old post but hopefully someone might be able to help me.
I have this exact same problem as Philsan. Unfortunately I am not a tech guru (can do basic stuff) so I am not sure how to go about getting an eprom with the PAL image let alone installing it. I am also in New Zealand which probably doesn't help. Would anyone be able to help me out with doing this? Or give me step by step instructions?
Cheers
Rel
#4 SoulBuster OFFLINE
SoulBuster
  • 2,419 posts
Posted Thu Aug 29, 2013 2:49 PM
Here is a link to a thread I started that changes the 5 1/4 floppy to a 3 1/2. Even though you are not asking for this exactly, it does tackle the change out of the ROM. It may be helpful.
http://atariage.com/...51#entry2666885
#5 reliant73 OFFLINE
reliant73
    Space Invader
  • 37 posts
Posted Thu Aug 29, 2013 2:56 PM
Thanks SoulBuster that is useful as I now know where the EPROM is when I need to switch it out. The problem is I have no way of getting a chip or programming it with the Pal image that Philsan has above. I am hoping that someone might be able to do this for me :) I would be willing to pay any cost associated with it too :)
Rel
#6 Philsan OFFLINE
Philsan
  • 3,779 posts
Posted Thu Aug 29, 2013 2:58 PM
Hi Guys,
Cheers
Rel
Just ask to AtariAge user classics (http://www.atarimax.com/) to burn and send to you the eprom; you only need to exchange it (it is not soldered).
#7 reliant73 OFFLINE
reliant73
    Space Invader
  • 37 posts
Posted Thu Aug 29, 2013 3:00 PM
Awesome thanks Philsan :) Such a quick response too :)
#8 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 883 posts
Posted Fri Aug 30, 2013 6:22 AM
The "ntsc" rom is actually a stuffup (feature) of the xf551. The timing loop to recieve serial data on the drive needs 1 extra cycle to be added which is what the "pal" version does. However you will find the pal version will also work with ntsc consols. There is another error in the rom to do with setting up for formating a disk. It however isnt serious so is not a big issue.
James
#9 MEtalGuy66 OFFLINE
MEtalGuy66
  • 2,774 posts
  • If it aint broke, fix it anyway!
Posted Fri Aug 30, 2013 10:42 AM
There is about a 50/50% chance that that rom will be soldered in.. In which case, a competant experienced person needs to desolder it, or you WILL (not might) f@ck up the PCB.. Those PCBs are the absolute crappiest quality atari ever used on anything. A little too much heat, or even too much time applying heat to one of those joints, and the pad will literally just fall off the board. They SUCK..
Best to open the drive, and check if the ROM is in a socket before you go any further. If the rom is not socketed, youd be best to go ahead and ship the unit to a guy who can do the desoldering/socket installation and burn the eprom all in one shot. He can also check for issues with the SIO connectors and resolder/reenforce them as necessary.
oh and BTW.. The ROm you want is the HyperXF-A.. not that crappy factory PAL rom.. Who the hell uses AtariDOS XE? Noone.. The HyperXF gives you true Ultraspeed operation, compatable with the vast majority of DOSes and Apps that support ultraspeed on the 1050.. It also fixes all the crap problems that occur (requiring you to press reset) when you remove a floppy and insert one of a different density than the first.. HyperXF handles this seamlessly. And there is a ton of other added features that I wont go into here.. It is a WAAAAAAY better ROM in every possible scenario than Atari's factory ROM.
Edited by MEtalGuy66, Fri Aug 30, 2013 10:56 AM.
#10 ricortes OFFLINE
ricortes
    Dragonstomper
  • 631 posts
Posted Fri Aug 30, 2013 11:33 AM
+1 to Metal's comments. If it was me, I would just use snips to cut all the legs off the ROM so the individual pins could be pulled easier then the whole IC. False economy to try and save a ~$1 EPROM and ruin a $200 drive.
#11 reliant73 OFFLINE
reliant73
    Space Invader
  • 37 posts
Posted Fri Aug 30, 2013 4:20 PM
Hi All,
Thanks MetalGuy66 :)  I craked open the case this morning and luckily it is the socket version (see photo)
XF551
So I'm pleased about that as I didn't fancy shipping it overseas to have it done, it would have been expensive from NZ :)  I have found an ebay action that sells them but just want to check that this is correct before I do.
Here is the listing:
http://rover.ebay.co...130973128302%26
If it isn't the correct one do you know where I can source one from?
In regard to the SIO ConnectorsI might see if I can find someone local who could do it as that's a good idea too from what I have read.
Once again thanks for all your help with this I really appreciated it.
Cheers
Rel
Edited by reliant73, Fri Aug 30, 2013 4:28 PM.
#12 MEtalGuy66 OFFLINE
MEtalGuy66
  • 2,774 posts
Posted Fri Aug 30, 2013 5:27 PM
Yeah. That seller is TJLazer on this forum. When you buy it, just specify which rom version you want.
There are two different HyperXF roms.. The A version is for the 5.25" mech. The B version is for the 3.5" mech.
#13 reliant73 OFFLINE
reliant73
    Space Invader
  • 37 posts
Posted Fri Aug 30, 2013 5:34 PM
Cool, Done :-)
Thanks
Again
#14 walter_J64bit OFFLINE
walter_J64bit
  • 5,183 posts
Posted Sat Aug 31, 2013 4:39 AM
DOS XE and HyperXF is not a good mix you only use A810 and A1050 formats, DOS XE doesn't like the high speed that HyperXF has.
Edited by walter_J64bit, Sat Aug 31, 2013 4:40 AM.
#15 reliant73 OFFLINE
reliant73
    Space Invader
  • 37 posts
Posted Wed Sep 11, 2013 7:04 PM
Hi All,
Just a quick update. I got my chip today and installed it. I now have a fully working XF551 running the HyperXF-A  yay :) Thanks to everyone who helped me out in this post and TJLazer for sending the chip.
Cheers!
Rel
#16 reliant73 OFFLINE
reliant73
    Space Invader
  • 37 posts
Posted Wed Sep 11, 2013 8:21 PM
Oh and one more thing. If I was to buy a US 1050 would I need to mod it in a similar way to work on my PAL 800XL and 130XE? Would the Happy Mod be the solution?
#17 Lastic OFFLINE
Lastic
    Chopper Commander
  • 103 posts
Posted Tue Aug 7, 2018 12:54 PM
So I picked up a US XF551 to use here in sunny Europe with my PAL 130XE not realizing there was a difference in the ROM and the current 120VAC US power supply.
Can I upgrade it to a HyperXF PAL ROM ? ROM is socked so that part is easy.
Which power-supply should I get to use here in the EU ? NES Power supply is a no-go ?
#18 1050 OFFLINE
1050
  • 1,052 posts
Posted Tue Aug 7, 2018 5:18 PM
Yes you can upgrade to Hyper XF551 rom.
No no to the NES.
You need 9 Volts AC at 3 amps, or a travel converter
to knock down your 240 to 120 and use the power supply
that came with it? Travel converter should weigh about
the same as US power supply to ensure it's big enough
to handle the task.
#19 Nezgar ONLINE
Nezgar
  • 1,461 posts
Posted Wed Aug 8, 2018 12:49 AM
No no to the NES.
NES power supply is 9-11VAC, and depending on amps it should work (1.0A is not enough). I have read others have used it with success. Stock power supply is 3.4A, so even if it works, beware a lower amp PSU could burn out over time.
SNES power supply is DC, will not work with 1050. It has a different connector anyway.
#20 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 742 posts
Posted Thu Aug 9, 2018 5:52 AM
I would suggest to buy a new, 220/230 volts compatible power supply instead of a 230 => 115 volt converter. You can get a good replacement power supply at Amazon, search for "Rockpower 9V AC". You will find a 2.1A AC power supply for around 18 Euros. When using Amazon UK you can order it with the UK plug instead of the Euro standard plug.
2.1A is absolutely enough for any 1050 with or without expansions, you don´t need really 3A.
#21 Stephen OFFLINE
Stephen
  • 7,375 posts
  • A8 Gear Head
Posted Thu Aug 9, 2018 9:53 AM
Not sure about the 1Amp issue.  There was just a recent thread on here about a 1050 failing format but otherwise mostly working.  Turned out to be a weak power supply.
#22 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 5,968 posts
Posted Thu Aug 9, 2018 5:53 PM
I think you miss read... he is suggesting 2.1 amp not 1 amp... unless I've miss read... with as bleary as my vision is being atm It could be me...  I wonder who is Ms. Read anyway :)
#23 Stephen OFFLINE
Stephen
  • 7,375 posts
  • A8 Gear Head
Posted Thu Aug 9, 2018 6:35 PM
My apologies - it seems I really DO need new glasses.  I hate the ones I have had since last year - I'll never get progressive lenses again.
#24 Kyle22 OFFLINE
Kyle22
  • 3,753 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Fri Aug 10, 2018 8:04 PM
I can't say for sure, because I have never tried them. If they are as good as the adverts say, then I would like to try them.
