Atari 400/800 SALT DIAGNOSTIC CARTRIDGE Rev.2.05
11 replies to this topic
#1 Sean39 OFFLINE
Sean39
    Moonsweeper
  • 352 posts
  • Atari 800, 130XE , and Intellivision ECS systems
Posted Mon Feb 25, 2008 8:38 PM
Hi everyone
Does anyone have a book or the information how to use this cartridge. It a Stand Alone Diagnostic Cartridge Rev. 2.05.....
It runs test on how your computer is performing. Well does anyone have a book on this cartridge????
sean39
#2 Lord Thag OFFLINE
Lord Thag
  • 3,524 posts
  • We put our faith in Blast Hardcheese
Posted Mon Feb 25, 2008 8:45 PM
I'd like to know too. I picked one up at NWCGE for free. I know you can hit different keys to get various RAM, Sound and Video tests, but that's about it.
#3 doctorclu OFFLINE
doctorclu
    ***Moon Patrol 5200*** *Moon Master2015* *Blue Max:Class 4*
  • 7,676 posts
  • *Star Raiders 2* **Captain -CL 2**
Posted Mon Feb 25, 2008 10:03 PM
I need the rom image. I have the module in the 850 case. :D
#4 Sean39 OFFLINE
Sean39
    Moonsweeper
  • 352 posts
Posted Mon Feb 25, 2008 10:17 PM
i HAVE THE 850 ALSO ,BUT WHAT DOES THAT HAVE TO DO WITH THE aTARI 400/800 salt diagnostic cartridge rev.205???????
SEAN
#5 warerat OFFLINE
warerat
    Moonsweeper
  • 414 posts
Posted Mon Feb 25, 2008 11:59 PM
SEAN
He doesn't mean "the" 850. He means the external hardware housed in an 850 case that is used for certain tests with the SALT cart.
http://www.atarimuse...0/atari850.html
#6 doctorclu OFFLINE
doctorclu
  • 7,676 posts
Posted Tue Feb 26, 2008 8:01 AM
Sorry for the confusion and thanks Warerat for clearing that up. Yeh, in my tinkering with eprom burners I need to pick up a 8-bit Atari cart for this purpose.
Be interesting to see what it says about a stock Atari 800 and a Atari 800 with XE mod. :D
#7 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 883 posts
Posted Wed Feb 27, 2008 5:21 AM
That external device is rather interesting, it has an SIO plug, 4 joystick ports and 2 power connectors. Looks like it could test everything including power used.
I have one here but have never fired it up so don't know if it works or not
James
#8 Guitarman OFFLINE
Guitarman
  • 1,429 posts
  • Atari Is Golden
Posted Thu Feb 28, 2008 5:35 PM
James
If you are using a SALT cart with the external test hardware, the joystick port connection have to be connected reverse from the joystick ports on the computer, ie, 1to4, 2to3, 3to2, 4to1. On an XL, you can go 1to2, 2to1. There are certain tests in the SALT cart that will not work without the external test box. The box uses a 2600 style PSU. The other power connectors is for a 800 PSU passthrough and normally doesn't get used. The SIO connector does test the SIO line. There is 1 switch to turn it on and off. The other switch will mute the audio output to the speaker/TV during the audio tests for undisturbed multi-pass burn-in testing.
Edited by Guitarman, Thu Feb 28, 2008 5:36 PM.
#9 Sean39 OFFLINE
Sean39
    Moonsweeper
  • 352 posts
Posted Thu Feb 28, 2008 6:10 PM
Hi Thanks
I sure could use that information,and I have almost located everything I need to run all the test.......
sean39
#10 Guitarman OFFLINE
Guitarman
  • 1,429 posts
  • Atari Is Golden
Posted Fri Feb 29, 2008 3:27 AM
Hi Thanks
sean39
What's needed:
SALT Cartridge
External Hardware Test Interface
2600 Power Supply
9pin Female to 9pin Female Joystick Port Cables (2-4, depending on what system's being tested)
SIO Cable
Also, the SALT user guide is part of the 600XL Technical Reference Manual.
Edited by Guitarman, Fri Feb 29, 2008 3:29 AM.
#11 re-atari OFFLINE
re-atari
    Moonsweeper
  • 387 posts
Posted Sat Mar 1, 2008 5:43 AM
For those interested, our German friends at ABBUC had a thread last year about this piece of diagnostic equipment. Check it out at:
http://www.abbuc.de/...m...opic&t=2936
Be prepared the text is (of course) in German, but general interest may be served by the presence of photo's of both PCB's with readable (though nowadays obsolete) partnrs :cool:
re-atari
#12 Defender II OFFLINE
Defender II
  • 1,169 posts
Posted Thu Mar 6, 2008 8:09 PM
Hi Thanks
sean39
What's needed:
SALT Cartridge
2600 Power Supply
SIO Cable
I think there is also a SIO loopback test, Which requires a cable end with pins jumpered.
I have one and will have to look up the connections and post them later. :cool:
You also need a power cable jumper to go from the tester to the 800/400. You plug your 800/400 power into the tester.
Edited by Defender II, Thu Mar 6, 2008 8:12 PM.
