Visual bB 1.0 - a new IDE for batari Basic
batari basic
684 replies to this topic
#101 yuppicide OFFLINE
yuppicide
    I am the Black Knight. Give me your money!
  • 6,933 posts
Posted Wed Nov 12, 2008 7:15 PM
I have never used the score editor, but I will confirm my screen looks like yours. The buttons in the wrong place and that text.
I just noticed that the score editor in Visual bB Build 536 is messed up. It works fine for me in Build 535, but in Build 536 it looks like on the picture below...
Does anyone else have the same problem?
#102 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Wed Nov 12, 2008 10:47 PM
Yeah I noticed that after I posted it. It will be fixed in later releases.
-Jeff
#103 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Thu Dec 18, 2008 4:01 PM
Here's the latest build with quite a few changes and a number of bug fixes based on feedback. New build posted to first post. The biggest changes are in the syntax checking. If you come across any problems there, the easiest thing to do is to disable it from the settings tab. Also please send me error reports so I can address them.
New
Improved Sprite/Playfield Drawing
-Drawing now works more like other graphic programs.
-Hold Down Control Key to erase
-Hold down Alt to Draw
-Hold down Shift to select an area to draw or erase
Improved Syntax Checking
-auto correct
-auto line indenting
-check for duplicate labels, variables, constants, functions
-checks for illegal syntax
-Intellisense suggests terms to use as you type
-makes sure end statements are never indented
-enforces proper use of logical and bit operators
-Added a warning tab to the information pane when pre-compilation errors are identified.
-Automatically corrects incorrect case errors
Improved color coding
Projects are now sorted alphabetically
Settings allow you to specify an alternate batch file to use when compiling
added ability to go to a specific line of code
Support for 10-25-2008 bB Compiler updates
-Supports Def
-Supports romsize 8kEB
-Supports Peephole Optimizer (-O) compiler option (enable from Settings Tab)
-Supports using macro, callmacro
Bugs
Score Editor buttons covering editor - fixed
Losing colors when vertically flipping sprites - fixed
Search Window rests on top of every open window - fixed
Find Replace periodically crashes - fixed
Set Color textbox shows up in the wrong location when working with large sprites/playfields - fixed
Added a bunch of bB terms that were not previously recognized - fixed
known Issues
If you use syntax checking, periodically warning messages are not cleared, error line columns will be off, or are just wrong. You can hit Refresh, or F5, to force a full check of an open code file to correct this.
-Jeff
Edited by jwierer, Fri Dec 19, 2008 9:24 AM.
#104 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 27,345 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Thu Dec 18, 2008 4:17 PM
Thanks. I'll update the Visual batari Basic Guide tonight.
In case anyone took a quick glance and missed it, the sprite and playfield editors are much easier to use now. You no longer have to use the space bar (but you still can if you want to). Just drawing without holding down any key is a simple toggle draw. If you want to draw without toggling, hold down the Ctrl key to erase or hold down the Alt key to draw. I think that was the last major complaint that people had. It's fixed now, so grab a copy of VbB and have some fun.
#105 ginnidog OFFLINE
ginnidog
    Moonsweeper
  • 266 posts
Posted Mon Dec 29, 2008 3:58 AM
ahhhhhhh... i`ll have to check this out, once i find the free time...
#106 jman1093 OFFLINE
jman1093
    Space Invader
  • 11 posts
Posted Sun Jan 4, 2009 2:25 PM
Quick Question:
Every time I try to compile something, visual bB says it compiled fine. But when I click run it says: "Could not locate File.bas.bin and could not recompile. Please check to make sure it was compiled correctly." Then, I check the folder that the BAS file is located in and the BIN file is nowhere to be found.
Thanks for the help
jman1093
Edited by jman1093, Sun Jan 4, 2009 2:44 PM.
#107 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Sun Jan 4, 2009 4:17 PM
Quick Question:
Thanks for the help
jman1093
It's most likely the bB Batch file your using. I believe that was the culprit for others. Search the forum for the updated 2600bas.bat that Random Terrain posted.
You can download all the fixes and updates to batariBasic here. It should include the latest 2600bas.bat. I would be interested if that didn't fix the problem.
-Jeff
Edited by jwierer, Sun Jan 4, 2009 4:21 PM.
#108 jman1093 OFFLINE
jman1093
    Space Invader
  • 11 posts
Posted Sun Jan 4, 2009 6:18 PM
Unfortunately, that didn't fix the problem. This isn't a huge problem for me though. I can write the program in visual bB then compile it from the command line then run it in Stella.
jman1093
#109 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Sun Jan 4, 2009 7:58 PM
jman1093
So you can compile it from the command line? That's odd, because vbB just takes the standard output from the command line. If it doesn't work there it should work from the command line either.
-Jeff
#110 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Tue Jan 13, 2009 11:52 AM
Know what I was thinking would be a nice feature to VbB? Ability to generate high resolution cartridge labels.
Sort of like that online cartridge label generator..
#111 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Tue Jan 13, 2009 12:46 PM
Quick Question:
Thanks for the help
jman1093
By any chance is the .bin file created in the same folder as the source (.bas) file? I recently discovered a case where that can happen.
-Jeff
#112 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Tue Jan 13, 2009 12:48 PM
Is the source for the online cartridge label generator available? If so it's possible, but I wouldn't want to recreate it myself.
-Jeff
#113 Dan Iacovelli OFFLINE
Dan Iacovelli
  • 5,824 posts
Posted Tue Jan 13, 2009 3:19 PM
-Jeff
I think there is a link in the 2600 section to make labels: http://www.atariage....howtopic=111225
Edited by Dan Iacovelli, Tue Jan 13, 2009 3:20 PM.
#114 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Tue Jan 13, 2009 5:40 PM
Linking to his site might be a good idea so you're still giving him traffic. I was just thinking of some kind of all in one solution where I never had to leave VbB.
#115 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Tue Jan 13, 2009 6:11 PM
If you just want to embed the website you can just add a link to the getting started area. Unzip this archive Attached File  addLink.zip   292bytes   202 downloads and double click the addlink.reg file. There isn't much room for additional links, but one should be ok.
-Jeff
#116 jrok OFFLINE
jrok
  • 1,149 posts
Posted Mon Jan 26, 2009 11:02 AM
Hi,
I've been using VisbB for about a month now, and its really a great IDE. I'm finding it makes bB development a breeze. Thanks for all your hard work on this!
I have one feature request, and it may seem like a sort of bizarre one. In the Sprite Editor, we are given the option of creating sprites that are larger than 8px wide. I assume that option exists for those of us who are using two or more adjacent hardware or virtual players to create larger, more detailed sprites for title screens or even in-game elements. I've done this a few times, and its quite a painstaking process. The way I've been doing it, I have to copy and paste the sprite data into my program, than go line by line deleted the appropriate sprite bits from each player instance. For a large single sprite, this isn't a huge hassle. But for multi-frame animations it becomes incredibly labor-intensive, and if you decide to make any changes to individual frames, you pretty much have to edit the original "large" SPR file and manually split it all over again.
Would it be possible to develop a Sprite Action that took such 9+ wide sprite and autmatically split it into consecutive "sub-sprites" at 8px intervals? Basically, if we have a 32 pixel wide Sprite saved as "Big Spaceship", and click "Split", VisbB would generate, save and open four 8px wide SPR files called "Big Spaceship_A" "Big Spaceship_B" "Big Spaceship_C" and "Big Spaceship_D," which we could then insert into our programs?
Anyway, thanks again for great toolset.
Cheers,
Jarod
Edited by jrok, Mon Jan 26, 2009 11:09 AM.
#117 Random Terrain OFFLINE
Random Terrain
  • 27,345 posts
    Replay Value
    Nonlinear
Posted Mon Jan 26, 2009 11:12 AM
Hi,
Would it be possible to develop a Sprite Action that took such 9+ wide sprite and autmatically split it into consecutive "sub-sprites" at 8px intervals? Basically, if we have a 32 pixel wide Sprite saved as "Big Spaceship", and click "Split", VisbB would generate, save and open four 8px wide SPR files called "Big Spaceship(A)" ""Big Spaceship(B)" "Big Spaceship©" and "Big Spaceship(D)," which we could then insert into our programs?
Cheers,
Jarod
I know it's not what you're asking, but remember that you can highlight a section of a sprite, copy it, create a new sprite of the size you want in another sprite editor, paste the sprite data, then save it. You wouldn't have to delete data line by line.
#118 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Tue Jan 27, 2009 1:19 AM
This would be the easiest way.
-Jeff
#119 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Mon Feb 2, 2009 10:51 PM
I still for the life of me cannot figure out how to use the Sprite Animator. I load up build 544, goto View, Sprite Animator, I click, right click, ALT click, CTRL click.. nothing does anything!
I don't have any sprites currently and need to draw some.
I loaded up a game that has sprites and went to sprite animator no luck.
Also, pressing UP gives me an error:
"FormSpriteAnimator
Unhandles exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue. if you click Quit, the application will close immediately.
InvalidArgument=Value of '-2' is not valid for 'index'.
Parameter Name: index."
When I click details here's what shows up:
"See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: InvalidArgument=Value of '-2' is not valid for 'index'.
Parameter name: index
at System.Windows.Forms.ListBox.ObjectCollection.get_Item(Int32 index)
at VisualbB.FormSpriteAnimator.button_UP_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
VisualbB
Assembly Version: 1.0.0.544
Win32 Version: 1.0.0.544
CodeBase: file:///C:/Atari/VisualbB.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box."
Edited by yuppicide, Mon Feb 2, 2009 10:57 PM.
#120 Random Terrain OFFLINE
Random Terrain
  • 27,345 posts
    Replay Value
    Nonlinear
Posted Mon Feb 2, 2009 10:59 PM
Assuming you have a project open that contains some sprites, there should be a list of sprites in the Sprite Animator. Clicking on a sprite once highlights it and shows the image. Once a sprite is highlighted, you can then click on the check box and a check will appear. Does it look similar to image on the following page when you open it:
http://www.randomter...#spriteanimator
#121 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Tue Feb 3, 2009 12:10 AM
It's only useful if you already have projects open with sprites already.
That's your problem. Create some first and then come back to the animator.
If you opened the project after you opened the sprite animator window it's not going to know about them. Load up a project with sprites, then open the animator.
That's a bug. I need to disable the buttons if you have no sprites. I guess I never thought of the case that somebody would want to animate sprites that didn't exist ;)
-Jeff
Edited by jwierer, Tue Feb 3, 2009 12:27 AM.
#122 Random Terrain OFFLINE
Random Terrain
  • 27,345 posts
    Replay Value
    Nonlinear
Posted Tue Feb 3, 2009 12:15 AM
yuppicide, take a look at this:
http://www.randomter...atinganimations
Creating Animations
If you want to work on an animation and you've never done it before, here's one way to do it. Create a sprite in the Sprite Editor and save it. Then use Save As to save a copy of it. Open that copy and as you work on that 'frame' of your animation, you can click on the tab for it to make sure it's active and 'flip' between the two sprite editors by using the left/right arrow keys on your keyboard. You can flip back and forth, work on the image some more, flip back and forth and so on until you get it looking perfect. Make sure you save the sprite, then use Save As to save a copy of that sprite. Open that copy and work on it, click on a tab and flip between all three using the left/right cursor keys to see how your animation is progressing. You can keep on with this process until you have perfected your animation. Just remember to save the latest version of all of your 'frames' and you'll be ready to use the Sprite Animator.
#123 Tempy OFFLINE
Tempy
    Space Invader
  • 29 posts
Posted Sat Feb 7, 2009 5:36 PM
I was having the same issue Kamaria and jbs30000 were having: bin file not being found and couldn't recompile.
Hitting compile didn't give any errors, but neither did it finish! In the messages window it would say "Compiling N:\Emu\Atari2600\bAtari\Projects\Test\default.bas", but nothing else. I figured 2600basic.exe was having issues executing for some reason. bB.asm was 0 bytes, and I couldn't delete it or the bas file; they were still being used by some program - Took me a while to find it in the windows task manager, since it wasn't something obvious like 2600basic.exe, but rather ntvdm.exe and conime.exe. Wait, conime? Ding ding ding!
I went to my windows (vista) regional setting and changed the Unicode language from Japanese to English (US) and Visual bB worked!
I've compiled bB stuff before using macros in UltraEdit, so what was going on? One of the odd things I had when setting the Unicode language to Japanese was that backslashes in paths would appear as Yen symbols. Though there didn't seem to be any programs which had issues with that. I'm guessing that Visual bB is sending filename parameters to 2600basic/dasm in some different way which makes compiling never finish.
Maybe jbs30000 was also using an Asian language Unicode setting?
Edit: Maybe related? http://support.micro...kb/903204/en-us
Edited by Tempy, Sat Feb 7, 2009 5:49 PM.
#124 jwierer OFFLINE
jwierer
    Dragonstomper
  • 893 posts
Posted Sat Feb 7, 2009 9:23 PM
The problem that jbs3000 was having was DASM was reporting an error which vbB was picking up and skipping the file copy part. I have a private build that works if you're interested I can PM you a copy. It doesn't use XMLSerializer so I don't think that kb article applies.
-Jeff
#125 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Sun Feb 8, 2009 2:46 AM
You wrote to create a sprite in the sprite editor and save it. How do I do that? I go in to the Sprite Animator and everywhere I click does nothing to draw for me.
So, now I am reading you wrote "create in the sprite editor" -- what is "the sprite editor"? VBB has no sprite editor that comes with it that I can see. Only sprite animator.
So, I loaded up a game that has Player1 defined. Then fired up Sprite Animator. Still not working or showing me anything.
Edited by yuppicide, Sun Feb 8, 2009 2:47 AM.
Also tagged with one or more of these keywords: batari basic
