GroovyBee Posted January 25, 2014 Share Posted January 25, 2014 Although I haven't used DASM for a few years now its good to see it getting some love for bug fixes. Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 25, 2014 Share Posted January 25, 2014 You're welcome guys! I'm glad I managed to knock off some rough spots, and get Kylearan unstuck. @Andrew: I know this was a small, small thing compared to when you carried the dasm load. Thank you!!! Quote Link to comment Share on other sites More sharing options...
Rhialto Posted January 26, 2014 Share Posted January 26, 2014 (edited) First let me introduce myself: I am the Rhialto whose email got quoted some messages back. In the past I have made a number of feature additions to Dasm. I just registered here, mainly to join this thread. I think it's great that there is still some development in Dasm. Is there anyone who has write access to the dasm-dillon project on sourceforge to check these changes in? Or do we need (yet another) copy in a new location? #6 - fixed STRLISTSIZE as suggested. 64-bit compiles of dasm now appear to work correctly.(Andrew) I think this needs a few more small changes. STRLISTSIZE now occurs like this: asm.h://#define STRLISTSIZE 4 asm.h:#define STRLISTSIZE (sizeof(STRLIST)-4) main.c: sl = (STRLIST *)permalloc(STRLISTSIZE+1+strlen(buf)); ops.c: base = (STRLIST *)ckmalloc(sizeof(STRLIST)-STRLISTSIZE+strlen(str)+1); ops.c: sl = (STRLIST *)ckmalloc(sizeof(STRLIST)-STRLISTSIZE+1+(str-s1)); ops.c: newdir = (STRLIST *)permalloc(STRLISTSIZE + 1 + strlen(buf)); The ones in the middle with sizeof(STRLIST)-STRLISTSIZE are now wrong; that bit should just be STRLISTSIZE. That's in v_execmac(), so I expect problems if you're using a macro expansion. Oh, and when I looked at how this "STRLISTSIZE" got introduced and when it got used incorrectly in the first place, it seemed (from what limited past versions I could still find) that I might have been the person to introduce it, and use it incorrectly... oops! Edited January 26, 2014 by Rhialto 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 26, 2014 Share Posted January 26, 2014 Welcome Rhialto! Thanks for signing up and flagging the issue! I agree it would be great to have the updates pushed back into the official version. I've attached the updated code. Windows, Linux, and OS X x86 32-bit binaries are in the .zip file attached below. These builds should work on 64-bit systems. [REMOVED - see later post] Quote Link to comment Share on other sites More sharing options...
+batari Posted January 26, 2014 Share Posted January 26, 2014 I just tried it, and it's not suppressing output properly until the final pass as my build does. I don't know if you just suppressed errors, but I suppressed everything until the last pass - for example, "echo" is not useful except at the last pass as earlier output is incorrect or at least redundant. Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 26, 2014 Share Posted January 26, 2014 I applied your patches to the code (with some translation required for code changes between dasm versions in asmerr) and I just figured error-only suppression was what you had wanted when I was testing. Looking at the code with the expectation of output suppression, in your modified main.c you have an addmsg() function to build up the regular output message buffer, but it never gets called anywhere. Maybe this was an incomplete version of your patch? Quote Link to comment Share on other sites More sharing options...
+batari Posted January 26, 2014 Share Posted January 26, 2014 Yes, it does appear there is more. I also added stuff to ops.c and asm.h (but the only addiditon to asm.h was related to the branching fix which shouldn't be needed.) The only change to ops.c is to the echo buffer: v_echo(char *str, MNE *dummy) { SYMBOL *sym = eval(str, 0); SYMBOL *s; char buf[256]; for (s = sym; s; s = s->next) { if (!(s->flags & SYM_UNKNOWN)) { if (s->flags & (SYM_MACRO|SYM_STRING)) sprintf(buf,"%s", s->string); else sprintf(buf,"$%lx", s->value); if (FI_listfile) fprintf(FI_listfile, " %s", buf); //printf(" %s", buf); addmsg(" "); addmsg(buf); } } addmsg("\n"); // puts(""); if (FI_listfile) putc('\n', FI_listfile); }I think this is a worthwhile change as it makes the output a lot cleaner (and correct!) Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 26, 2014 Share Posted January 26, 2014 Ah, echo and error suppression. I see where you're coming from now. By "everything" I was thinking the verbose pass output as well, which I was a bit confused about. Here's the updated build which I believe is working as you expect. [REMOVED - see later post for updated version] Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted January 27, 2014 Share Posted January 27, 2014 Any one of you kids know, which "illegal" opcodes are supported by DASM, that work on the 7800? Is there a list somewhere? Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 27, 2014 Author Share Posted January 27, 2014 Is there anyone who has write access to the dasm-dillon project on sourceforge to check these changes in? Or do we need (yet another) copy in a new location? I think I do. I will have a look-see and report back. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 27, 2014 Author Share Posted January 27, 2014 Have tried this version. I suspect the output supression is being a bit enthusiastic. For example, I have a macro that reports when a page is crossed incorrectly, and throws an ERR The output is... ../dasm ./BoulderDash.asm -l../BoulderDash.txt -f3 -s../BoulderDash.sym -o../BoulderDash.binBANK_FIXED.asm (1240): error: ERR pseudo-op encountered. Problem is, the macro is this... MAC CHECKPAGE LIST OFF IF >. != >{1} ECHO "" ECHO "ERROR: different pages! (", {1}, ",", ., ")" ECHO "" ERR ENDIF LIST ON ENDM The ECHO should be output in this case. It is not. So, IMHO the supression of output to the final pass needs reworking. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 27, 2014 Share Posted January 27, 2014 Agreed. Suppressing ECHO is no good idea. Quote Link to comment Share on other sites More sharing options...
+batari Posted January 27, 2014 Share Posted January 27, 2014 Clearly it needs work, but I think it's a good idea. For example: without echo suppression, you'd get this: @ $f100 : $0 @ $f200 : $2 @ $f300 : $4 @ $f400 : $6 @ $f500 : $8 @ $f600 : $a @ $f700 : $c @ $f800 : $c @ $ffc7 : $71 @ $fff4 : $71 RAM code size: $79 bytes *** Free $71 bytes *** @ $f100 : $0 @ $f200 : $2 @ $f300 : $4 @ $f400 : $6 @ $f500 : $8 @ $f600 : $a @ $f700 : $c @ $f800 : $c old value: $00e2 new value: $00e1 old value: $00ef new value: $00ee old value: $0079 new value: $0078 @ $ffc7 : $72 @ $fff4 : $72 RAM code size: $78 bytes *** Free $72 bytes *** @ $f100 : $0 @ $f200 : $2 @ $f300 : $4 @ $f400 : $6 @ $f500 : $8 @ $f600 : $a @ $f700 : $c @ $f800 : $c @ $ffc7 : $72 @ $fff4 : $72 RAM code size: $78 bytes *** Free $72 bytes ***There's no need for that redundant and incorrect output. What a properly-working assembler should display is this: @ $f100 : $0 @ $f200 : $2 @ $f300 : $4 @ $f400 : $6 @ $f500 : $8 @ $f600 : $a @ $f700 : $c @ $f800 : $c @ $ffc7 : $72 @ $fff4 : $72 RAM code size: $78 bytes *** Free $72 bytes ***I think that should be the goal. Obviously the method for doing that isn't working right yet. Quote Link to comment Share on other sites More sharing options...
+batari Posted January 27, 2014 Share Posted January 27, 2014 Yep, a preliminary glance at code shows that the message buffer is not being printed in some cases where it aborts due to errors. It's easy enough to fix, it's just a matter of finding all of the various ways that assembly can abort (there are various ways to abort and even scattered exit(1)'s in there.) Quote Link to comment Share on other sites More sharing options...
+batari Posted January 27, 2014 Share Posted January 27, 2014 Fixed. main.c attached (I can't build in Windows.) (I hope it doesn't clog up output with bogus label mismatches when errors occur, though. That may be a harder problem to fix.) dasmmain.zip 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 27, 2014 Share Posted January 27, 2014 Fixed. main.c attached [...] Here are the binaries with your updated main.c... [Removed. See later post for updated version] Comments and further complaints are welcome. We already have our hands in the source, so we might as well make sure everybody feels that we've achieved progress with the fixes. This might end with error-suppression (until last pass) and message-suppression (until last pass) being optional features, but I'm not sure we're at that point yet. 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 27, 2014 Author Share Posted January 27, 2014 I think I do. I will have a look-see and report back. I don't, but I have been in contact with Peter -- admin of the project. He is giving me admin access, so soon I will be able to update the project at sourceforge. 2 Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 27, 2014 Share Posted January 27, 2014 Any one of you kids know, which "illegal" opcodes are supported by DASM, that work on the 7800? Is there a list somewhere? I believe all of the illegal opcodes are supported by DASM, at least, with some mnemonic. It was suggested on the stella list that 2600 coders should stick to the opcodes marked as stable in the C64 docs. I think that likely applies to the 7800 too. Here's a C64 doc with an illegal opcode list. Unstable illegals are noted. 1 Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted January 27, 2014 Share Posted January 27, 2014 Any one of you kids know, which "illegal" opcodes are supported by DASM, that work on the 7800? Is there a list somewhere? I've edited the following list from DASM's mne6502.c file. It shows all the supported 6502 mnemonics in alphabetical order, followed by the hex machine codes. I edited out the addressing mode indicators to keep this simple (it's just a QAD edit), but at least it shows which abbreviations 6502 accepts for the "illegal" opcodes, which is nice to know since many of the documents about these codes use different abbreviations from each other. adc - 0x69, 0x65, 0x75, 0x6D, 0x7D, 0x79, 0x61, 0x71 anc - 0x0b and - 0x29, 0x25, 0x35, 0x2D, 0x3D, 0x39, 0x21, 0x31 ane - 0x8b arr - 0x6b asl - 0x0A, 0x06, 0x16, 0x0E, 0x1E asr - 0x4b bcc - 0x90 bcs - 0xB0 beq - 0xF0 bit - 0x24, 0x2C bmi - 0x30 bne - 0xD0 bpl - 0x10 brk - 0x00 bvc - 0x50 bvs - 0x70 clc - 0x18 cld - 0xD8 cli - 0x58 clv - 0xB8 cmp - 0xC9, 0xC5, 0xD5, 0xCD, 0xDD, 0xD9, 0xC1, 0xD1 cpx - 0xE0, 0xE4, 0xEC cpy - 0xC0, 0xC4, 0xCC dcp - 0xc7, 0xd7, 0xcf, 0xdf, 0xdb, 0xc3, 0xd3 dec - 0xC6, 0xD6, 0xCE, 0xDE dex - 0xCA dey - 0x88 eor - 0x49, 0x45, 0x55, 0x4D, 0x5D, 0x59, 0x41,0x51 inc - 0xE6, 0xF6, 0xEE, 0xFE inx - 0xE8 iny - 0xC8 isb - 0xe7, 0xf7, 0xef, 0xff, 0xfb, 0xe3, 0xf3 jmp - 0x4C, 0x6C jsr - 0x20 las - 0xbb lax - 0xa7, 0xb7, 0xaf, 0xbf, 0xa3, 0xb3 lda - 0xA9, 0xA5, 0xB5, 0xAD, 0xBD, 0xB9, 0xA1, 0xB1 ldx - 0xA2, 0xA6, 0xB6, 0xAE, 0xBE ldy - 0xA0, 0xA4, 0xB4, 0xAC, 0xBC lsr - 0x4A, 0x46, 0x56, 0x4E, 0x5E lxa - 0xab nop - 0xEA, 0x80, 0x04, 0x14, 0x0c, 0x1c ora - 0x09, 0x05, 0x15, 0x0D, 0x1D, 0x19, 0x01, 0x11 pha - 0x48 php - 0x08 pla - 0x68 plp - 0x28 rla - 0x27, 0x37, 0x2f, 0x3f, 0x3b, 0x23, 0x33 rol - 0x2A, 0x26, 0x36, 0x2E, 0x3E ror - 0x6A, 0x66, 0x76, 0x6E, 0x7E rra - 0x67, 0x77, 0x6f, 0x7f, 0x7b, 0x63, 0x73 rti - 0x40 rts - 0x60 sax - 0x87, 0x97, 0x8f, 0x83 sbc - 0xE9, 0xE5, 0xF5, 0xED, 0xFD, 0xF9, 0xE1, 0xF1 sbx - 0xcb sec - 0x38 sed - 0xF8 sei - 0x78 sha - 0x9f, 0x93 shs - 0x9b shx - 0x9e shy - 0x9c slo - 0x07, 0x17, 0x0f, 0x1f, 0x1b, 0x03, 0x13 sre - 0x47, 0x57, 0x4f, 0x5f, 0x5b, 0x43, 0x53 sta - 0x85, 0x95, 0x8D, 0x9D, 0x99, 0x81, 0x91 stx - 0x86, 0x96, 0x8E sty - 0x84, 0x94, 0x8C tax - 0xAA tay - 0xA8 tsx - 0xBA txa - 0x8A txs - 0x9A tya - 0x98 mne6502_c.txt 2 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 28, 2014 Share Posted January 28, 2014 At least 0x8b and 0xab are considered unstable and should not be used. Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 29, 2014 Share Posted January 29, 2014 Are people good with the last, echo patched version? I don't have aspirations to maintain the code on an ongoing basis, so it would be better to sort out any issues now. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 29, 2014 Share Posted January 29, 2014 Works for me, but I haven' tested very extensively. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 30, 2014 Author Share Posted January 30, 2014 Seems OK to me on preliminary usage. Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 30, 2014 Share Posted January 30, 2014 Thanks for the feedback, guys! Understood it's early days still. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted February 1, 2014 Author Share Posted February 1, 2014 Possible bug: DASM allows bit abs,x This is not a legal instruction! Would be nice to fix, as it took me a while to realise why my code didn't work Cheers A Quote Link to comment Share on other sites More sharing options...
