Juno First - Final Version (Atari 2600)
cd-w
I also encountered a bug. Not sure how exactly when it happens, but I think it's got to do with running out of time, maybe hitting the last enemy just before dying. After that, There's no enemies but something still shoots at you. Also the score table messes up. Didn't think of taking a screenshot :[ Maybe it's fixed because I can't replicate it in this version.
Let me know if it happens again - the game logic is now very complex, so there are likely to be some odd bugs lurking in there.
I also noticed that stray bullets stay when wave is cleared. Dunno if it was intentional, but I think it's a good thing. Also noticed that fuel is completely restored when dying. Thumbs up for that.
This is intentional - it felt odd for the bullets to simply disappear. The fuel is completely restored now as the alien spawning is no longer linked to the fuel timer (I don't know why I didn't think of this earlier!).
As to the waves, you got it, dude. This is exactly what the game needed. Play is much more fluid and frantic. NO FOOLING AROUND ANYMORE! The only thing I would change is to not include the satellite in the equation. Like in the first wave, it feels weird to have to pick up the astronaut for the next group to appear. But maybe that's just me.
Thanks - it definitely does seem to play much better, and it saves me a load of work trying to tune the levels. It is a bit difficult to not count the satellite, so I will probably just leave it as is.
I'm playing some more in a bit, but I can see this is going to be one of the finest shooters for the VCS. I don't even feel like comparing it to the arcade. Awesome job here.
Glad you like it, and thanks again for your suggestions.
Chris
Ah, I see what you did there. It's a combination of timed intervals and # of enemies remaining. If the player is fast enough, he gets rewarded by having only so many enemies at once, and the next wave is bumped, so the time saved is not wasted. If you're too slow, the next wave will appear before you're done with the previous one. This will clutter the screen with enemies/bombs, and all groups will appear within the time limit, so it's still possible to clear the wave. This are the little things that make a good game great.
I would like to test on hardware, but I don't have an eprom for this big boy.
--Made to wave nine, no problems that I can see so far.
Edited by cosmosiss
* The ship has moved forward by 8 lines - this should make it harder for aliens to sneak up behind you.
It's much better now, thanks!
EDIT: Although with the new changes to alien spawning, I find myself backtracking a lot less anyhow.
Edited by Hornpipe2
Hi Chris
Works nice on real hardware.Checked it on my Cuttle cart2 and with an atarivox.
geetings Walter
Hi Walter,
Thanks for testing it on your CC2. Also, thanks for all your encouragement - it really helps during the last phase of the project!
Chris
BTW, I can't really tell but do you perform collision checking just on the ship or also to the exhaust? Ideally you'd only check it against the ship. Then it would be less likely to get cheap shotted from behind.
Ship only. I remember him making the change sometime after v. 10.
Edited by Nathan Strum
  1. The aliens now move backwards in hyperspace, like in the arcade version.
  2. The wave number is now shown for the BEST/LAST scores.
  3. The previous initials are now the default for name entry.
  4. The astronaut appears instantly to prevent the "astronaut bug".
  5. Spheres appear earlier on waves 2 & 4.
I managed to find one extra byte of RAM to hold this timer and have now implemented a first pass at this approach. The downside is that it makes the game relentless with no gaps at all (except when you die), but this might not be a bad thing? Let me know how this version compares to the previous, and if it is an improvement?
A definite improvement on all counts! The astronaut bug fix is confirmed. The pacing with the new timer is much better - no more waiting!
I take that back.
I just tested it in the latest version, and while the reverse-thrust works as it should, the forward-thrust causes you to explode if it hits an alien. :(
I will look into this - I had to change the collision detection when I moved the ship forward and it seems that I got my calculations wrong.
Chris
Nice work on this game so far. Plays really well and alot of fun.
I'd like to suggest polishing up the ship though. It looks very flat and static during play.
Since the playfield is an over-head 3/4 view, I think the ship's sprite should have some fore-shortening when moving forward and backward for some improved realism.
Chris, I know that you may want to keep the ship as is since nobody else has mentioned this.
If you like, I have a hack of the graphics in the game as an example of what I'm talking about that I can post here since it's alot easier and faster for me to do than to make a GIF version. that ok with ya?
Edited by espire8
Interesting idea, though I'm not sure I have enough space left to fit in the extra frames. Feel free to post your hack here as I would like to see what you have done (and get opinions from others).
Chris
Edited by cd-w
The sprites are based on the arcade game, which doesn't change when moving left-right.
Yeah, the coinop is like 2.1D. Like the way the laser shots go straight out instead of moving in a diagonal towards the horizon. It's all the way it's supposed to be. Really just a vertical defender with some scaling added. But I love it.
I have a question about lateral movement. It's hard to tell, but does the coinop Juno First shift the sprites sideways when you move your guy left and right or is this an optical illusion because of the vertical perspective lines? It appears that it shifts it a little bit, at least when the sprites get close to your sprite, otherwise the perspective lines moving would not mesh with the sprite movement.
Edited by mos6507
