shadow460 Posted August 3, 2008 Share Posted August 3, 2008 (edited) I just picked up a SCPH-1001. Sadly, I didn't notice the lid was jamming before I paid my money, or I'd have left it. We all know the drill, it's been overheated and several parts are damaged from that. The opening mechanism and the CD drive are both shot. Anyway, the CD drive in my 7000 series Playstation is the same shape...at least on the top. Sure it's on the other side of the unit but the shapes match. That leads me to believe the drives are interchangeable. It still leaves me with the original problem, though: inadequate cooling. I was thinking of mounting some small DC fans in the power supply compartment to remove heat from the system. They could use the existing openings to move air in and out. Is there a source for CD drives? How about higher quality drives than what Sony used? Will the 1000 series PS1 retain its outstanding audio CD playback with a new drive installed? EDIT: Found that new drives are about $16. Then I may have to check/grease the rails and buy fans to reduce heat. I may take a crack at repairing the old one following some instructions I found online. The laser is out of alignment in kind of an odd way, even according to the guide. Instead of traveling straight up, it travels toward the left frnt corner of the unit (when viewed from the front). Most worn lasers light a beam toward the left rear corner. It shouldn't be too hard to pull it apart, but I'm wondering if I should do it here or after hours at my job where I've got a decent workspace. Edited August 3, 2008 by shadow460 Quote Link to comment Share on other sites More sharing options...
tremoloman2006 Posted August 8, 2008 Share Posted August 8, 2008 I just picked up a SCPH-1001. Sadly, I didn't notice the lid was jamming before I paid my money, or I'd have left it. We all know the drill, it's been overheated and several parts are damaged from that. The opening mechanism and the CD drive are both shot. Anyway, the CD drive in my 7000 series Playstation is the same shape...at least on the top. Sure it's on the other side of the unit but the shapes match. That leads me to believe the drives are interchangeable. It still leaves me with the original problem, though: inadequate cooling. I was thinking of mounting some small DC fans in the power supply compartment to remove heat from the system. They could use the existing openings to move air in and out. Is there a source for CD drives? How about higher quality drives than what Sony used? Will the 1000 series PS1 retain its outstanding audio CD playback with a new drive installed? EDIT: Found that new drives are about $16. Then I may have to check/grease the rails and buy fans to reduce heat. I may take a crack at repairing the old one following some instructions I found online. The laser is out of alignment in kind of an odd way, even according to the guide. Instead of traveling straight up, it travels toward the left frnt corner of the unit (when viewed from the front). Most worn lasers light a beam toward the left rear corner. It shouldn't be too hard to pull it apart, but I'm wondering if I should do it here or after hours at my job where I've got a decent workspace. I recently found this website which carries a good supply of parts! http://store.richspsxparts.com/ Quote Link to comment Share on other sites More sharing options...
atreyu187 Posted September 2, 2008 Share Posted September 2, 2008 Have the same PSX and a bad laser. Let me know if they are interchangeable as the newer lasers were not made of plastic. Quote Link to comment Share on other sites More sharing options...
shadow460 Posted September 3, 2008 Author Share Posted September 3, 2008 I'll have to try it, but for now I've been kickin' some RPG's on the PS2. Backwards compatibility does have it's moments. Quote Link to comment Share on other sites More sharing options...
STICH666 Posted January 29, 2009 Share Posted January 29, 2009 Did it work? Quote Link to comment Share on other sites More sharing options...
