Track & Field PAL60 hack?
7 replies to this topic
#1 Retrofan OFFLINE
Retrofan
    Chopper Commander
  • 192 posts
Posted Wed Aug 20, 2008 7:00 AM
Is there a PAL60 hack (corrected colors) of Track & Field?
#2 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,889 posts
Posted Wed Aug 20, 2008 1:56 PM
Partial conversion disassembly...
I've noted where color tables exist for the player sprites, but I still need to sort out (any) delimiters.
Edited by Nukey Shay, Wed Aug 20, 2008 3:31 PM.
#3 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,889 posts
Posted Wed Aug 20, 2008 3:31 PM
Completed. I also seperated the player colors from all others (and from each other). Not sure what "face" was, tho (the javalin?). A color shift might crop up in events of those types...I suck royally at this game.
Keep in mind that the color chosen for legs/torso, etc is shared with onscreen obstacles at the same scanline heights...such as hurdles...because they are made out of missile sprites.
Binary+Disassembly:
#4 Retrofan OFFLINE
Retrofan
    Chopper Commander
  • 192 posts
Posted Wed Aug 20, 2008 5:57 PM
Thank you very much, i'll test it.
#5 Retrofan OFFLINE
Retrofan
    Chopper Commander
  • 192 posts
Posted Wed Aug 20, 2008 6:05 PM
It looks very nice in PAL, thanx!
#6 Omegamatrix OFFLINE
Omegamatrix
  • 6,233 posts
Posted Wed Aug 20, 2008 6:09 PM
I watched the intro, and a bit of the dash and I thought the colors look good, Nukey. You did a good job and quick! I thought he was asking for a full PAL conversion at first. Anyhow great job. :D
#7 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,889 posts
Posted Wed Aug 20, 2008 6:27 PM
It was trivial to convert the colors in this game after it was disassembled, as everything is loaded either in immediate mode (i.e. #$xx color values existing right near the "COLU" store instructions), or using only 2 indirect pointers (most largish games have more). One thing I wasn't sure about was the javelin and hammer events, since they use independant objects. Give a yell if either of them are discolored when thrown and I'll continue searching.
#8 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,889 posts
Posted Wed Aug 20, 2008 10:27 PM
Found an easy way to increase speed (cheat)...
LB3B2:
	   lda	#$B7				   ;2
	   sta	$82					;3
	   sta	$84					;3
	   lda	LB7CD,Y				;4
	   sta	$81					;3
	   lda	LB7D5,Y				;4
	   sta	$83					;3
	   lda	$8D					;3
	   jsr	LBC2D				  ;6
	   tay						   ;2
	   lda	($83),Y				;5
	   clc						   ;2
	   ldy	$8E					;3
	   adc	($81),Y				;5
	   adc	$C4,X				  ;4
	   sta	$C4,X				  ;4
	   lda	$C2,X				  ;4
;;	   adc	#$00				   ;2
	   adc	#$01				   ;2 <- faster speed
Turns out that the javelin (FACE) color and disc color are correct in the conversion 8)
Note about the above...
The speed increase bumps up the default speed automatically for BOTH players on every frame (so you'd want to run it with a slowdown in effect...say, -r10 for Z26). Pity that the game doesn't allow more than 99.99 meters for distance, since they are BCD counters that roll over :(
< threw a javelin 290+ meters
