SpongeBob SquarePants: Jellyfishing
45 replies to this topic
#1 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,344 posts
Posted Wed Nov 19, 2008 7:04 PM
Thought I'd do a little test to see if I can get SpongeBob and three jellyfish on the screen with little flicker. I think I did OK, what do you think? The jellyfish can move independently, but I haven't programmed that far yet. I'll make missile0 a net holder and missile1 the net part of the net if I can. Also, the SpongeBob sprite needs work (I can't draw very good in Atari.)
#2 yuppicide OFFLINE
yuppicide
    I am the Black Knight. Give me your money!
  • 6,933 posts
Posted Thu Nov 20, 2008 3:40 AM
Flicker is not too crazy in Stella. You're right about the sprite. Looks nothing like Spongebob.
#3 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,603 posts
  • Braindead
Posted Thu Nov 20, 2008 6:35 PM
The flicker is not too bad in z26 and stella. The Jellyfish look nice but it's not easy to make a good looking Spongebob with the limited resolution of bB. Too bad the sprites can't be 9 pixels wide...
#4 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,697 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Thu Nov 20, 2008 7:03 PM
SpongeBob with his hands tied behind his back:
#5 jrok OFFLINE
jrok
  • 1,155 posts
Posted Thu Nov 20, 2008 7:11 PM
Here's my spongebob attempt... you'd be down a flicker, though.
Posted Image
  • Attached File  Sbob.bas   1.26KB   141 downloads
Edited by jrok, Thu Nov 20, 2008 7:15 PM.
#6 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,344 posts
Posted Thu Nov 20, 2008 7:25 PM
Nice! I need a side view, too.
Edited by atari2600land, Thu Nov 20, 2008 7:30 PM.
#7 Random Terrain OFFLINE
Random Terrain
  • 28,697 posts
    Replay Value
    Nonlinear
Posted Thu Nov 20, 2008 7:37 PM
Here's a simple side view with no mouth or eye:
#8 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,603 posts
  • Braindead
Posted Thu Nov 20, 2008 7:46 PM
Or what if you only use one arm and reflect the sprite when changing directions?
#9 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,344 posts
Posted Sat Nov 29, 2008 6:24 PM
I worked a whole bunch on the moving left/right and jumping code. Next, I need to figure out how to register a hit (once the jellyfish enters the net), and then when that's done, work on the jellyfish moving. I hope this will be a 4k game, but if I need to go above 4k, then i will.
#10 ginnidog OFFLINE
ginnidog
    Moonsweeper
  • 266 posts
Posted Sat Nov 29, 2008 8:22 PM
I`d love to see a SpongeBob title for the 2600...
keep up the good work
:D
#11 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,344 posts
Posted Sat Nov 29, 2008 10:27 PM
:D
Thanks! What would really be cool if I could change the score font to the SpongeBob font. I know how to do this, but I'd need someone to convert it into 8x8 sprites, if at all possible...
#12 ginnidog OFFLINE
ginnidog
    Moonsweeper
  • 266 posts
Posted Sat Nov 29, 2008 11:26 PM
Here is an 8 x 8 pixel done in MS Paint..
Hope it helps, or gives you an idea
Paulie ( GINNIDOG )
:D :D :D :D :D
#13 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,344 posts
Posted Sun Nov 30, 2008 12:04 AM
Score test with ginnidog's font. Thank you, ginnidog!
note: since the forums won't let you post asm files, just change the .txt to .asm with Notepad or something.
#14 ginnidog OFFLINE
ginnidog
    Moonsweeper
  • 266 posts
Posted Sun Nov 30, 2008 9:12 AM
Aeagis,
That is sooooooo cool........ my first ever contribution to a possible cart release...
mind if I draw a spoonge bob ?? just give the specs in `newbie virgin` terms..
Thanks so much...You made my day :D
Paulie ( GINNIDOG )
:D
PS: I also am a Lego model builder ( Amateur )
And I also collect sample license plates
HOpe it was okay to post these here..
:D
#15 gambler172 OFFLINE
gambler172
  • 3,236 posts
  • none
Posted Sun Nov 30, 2008 10:43 AM
Hi Chris
Wow,looks good.I love Spongebob.
greetings Walter
#16 Atari Dogs OFFLINE
Atari Dogs
  • 1,653 posts
Posted Sun Nov 30, 2008 3:15 PM
Cool. Put me down for one when you are done. What about making a two player option and having Patrick too? Don't forget a cool title screen.
Edited by Atari Dogs, Sun Nov 30, 2008 3:29 PM.
#17 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,603 posts
  • Braindead
Posted Sun Nov 30, 2008 4:08 PM
The game looks nice so far. I also think it would be nice to have a two player option with Patrick so how about using the Multisprite Kernel for it?
#18 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,344 posts
Posted Sun Nov 30, 2008 4:46 PM
As for Patrick as player 2 and multisprite:
It would be a whole lot easier if bB would let you do something like:
if collision(player2,player0)
Also, I fear it would use up too much space between the drawscreens for having all five sprites moving independently, plus a little complex coding for jumping and collision detection. I wasn't really prepared to have a second human-controlled player on the screen. Plus, the maximum score both players could have would be 99, and I was thinking that scores could be well above that. I'll see what I can do, but for now, here's another update.
If you catch a jellyfish, the score increases and another jellyfish enters the screen to replace it. It's a little too easy right now, so i was wondering whether it should be a timed game, have SpongeBob be stung by the jellyfish if he touches one and doesn't catch it, or something else.
#19 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,603 posts
  • Braindead
Posted Sun Nov 30, 2008 5:57 PM
If you don't want to add a 2 player mode how about letting the player select if he plays with spongebob or patrick before the game starts, like in your old spongebob game?
I also think the net should be set higher, at the moment it's right in spongebob's face. :D
If you set it higher you could also make it so when the net (missile) touches a jellyfish you get a point and if the player touches the jellyfish you lose a life...
The game plays already not bad, looking forward to see what you can do with this one!
#20 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,344 posts
Posted Sun Nov 30, 2008 6:06 PM
If I flicker SpongeBob and Patrick in multisprite and have the jellyfish be players 1-5, then I should be able to do a 2-player mode, but then Patrick and SpongeBob could only be one color. Should I do the trade-off?
Edited by atari2600land, Sun Nov 30, 2008 6:07 PM.
#21 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Sun Nov 30, 2008 6:16 PM
I would like to see this tap into a little mp3 player built into the cartridge case, it plays "kc and the sunshine band" song that goes "do a little dance, make a little love, get down tonight" as Spongebob and Patrick finally explore their love for one another.
Oh wait, wrong game.. in all seriousness I think it would be cool if you could pick one character or the other when you play and they both have different abilities.. such as one jumps higher.
#22 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,603 posts
  • Braindead
Posted Sun Nov 30, 2008 6:21 PM
Hmm... i'd say it's worth a try! But i guess then you would have to call the game"SpongeBob and Patrick go Jellyfishing nude". :D
#23 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,344 posts
Posted Sun Nov 30, 2008 6:42 PM
I just thought of something. Since I'm using the ball and missile0 as the net, and the multisprite kernel sets the ball height and missile heights to 1, I am unable to make the net, so it'll have to be one player.
#24 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,344 posts
Posted Sun Nov 30, 2008 9:39 PM
Here's a little sound effect. The more jellyfish that are near you, the louder the buzzing is. Does anyone have a good idea about how to do collision detection for stinging (death?) Since I'm using flickering, i don't really have a good idea on how to do it.
#25 jrok OFFLINE
jrok
  • 1,155 posts
Posted Mon Dec 1, 2008 9:50 AM
Well, I just played for thirty seconds and died about a dozen times, so I think collision detection is working pretty well the way you have it now. :)
Nice game, BTW!
Jarod.
