Internal ANTIC and GTIA schematics
183 replies to this topic
#176 Stephen OFFLINE
Stephen
  • 7,463 posts
  • A8 Gear Head
Posted Tue Nov 16, 2010 7:07 AM
Back to the decapping...
Yep, it's about time. ANTIC revision E:
Sweet! This would make a killer wall sized poster.
#177 ijor OFFLINE
ijor
  • 2,166 posts
Posted Tue Nov 16, 2010 7:22 AM
I bet the large block on the left is the charcode/bitmap data buffer.
It is. Note how much of the die surface it takes, something like a 4th or so.
Any idea what the total component count would be? Somewhere around 3-5,000 ?
I'd estimate a slightly higher number, but don't know for sure yet.
Cool picture, but I'd prefer schematics.
Hi fox. Yep, me too. That's the goal now.
#178 candle OFFLINE
candle
  • 2,793 posts
Posted Wed Nov 17, 2010 4:17 AM
any chances on bigger one?
its a bit too small to make something out of it
#179 ijor OFFLINE
ijor
  • 2,166 posts
Posted Wed Nov 17, 2010 6:19 AM
Hi candle.
any chances on bigger one? its a bit too small to make something out of it
This is just a low-res whole die picture, it is not for reading the fine print. The whole set of images is too big for posting here. I need to find the best way/place for download.
#180 candle OFFLINE
candle
  • 2,793 posts
Posted Wed Nov 17, 2010 6:53 AM
how much of space do You need?
#181 ijor OFFLINE
ijor
  • 2,166 posts
Posted Wed Nov 17, 2010 7:36 AM
I'm already checking a couple of options. If you more ideas, or if you have a specific query in the meantime, please let's continue this by PM.
#182 ijor OFFLINE
ijor
  • 2,166 posts
Posted Wed Nov 17, 2010 8:22 AM
I remember Bryan was curious about possible hidden messages or marks in the die. This is the only thing I could see so far:
I assume that DE are probably somebody's initials? Any ideas who he could be? Remember, this is the latter revision E (XL) die.
Edited by ijor, Wed Nov 17, 2010 8:23 AM.
#183 Bryan OFFLINE
Bryan
  • 10,926 posts
  • Cruise Elroy = 4DB7
Posted Wed Nov 17, 2010 8:39 AM
Interesting. Now we need an early Antic to compare against!
#184 GarthW OFFLINE
GarthW
    Combat Commando
  • 5 posts
Posted Sat May 31, 2014 1:54 PM
about heating up..
I remember Garth Wilson (6502.org) talking about his former boss and design flaw in circiuit that leaded to thermal instability
problem was timing was verry difrent from nominal and whole thing didn't work too long
boards were already produced, and it was eiter trash whole production run to the dumpster, or provide quick fix.
So his boss took 7805 regulator, shorted its output to ground and glue it to the failing device
7805 has thermal shutdown protection that was kicking in every time the regulator heated up itself, thus providing stable temperature to failing circuit - it was stable enought to save the company from financial problems at cost of increased current feeded into the circuiit
this was some time ago, and can't find the orginal text i'm talking about, not sure for the names, but quite sure for the principle
I'm a few years late, but I just found this.  I think you may be mixing up a couple of stories, one of mine with perhaps one of someone else's.  The closest one of mine is that we were using a switching regulator IC, successfully at first, but perhaps a year into production on the PCB, Maxim increased the switching slew rate on the IC and it started making a lot of electrical noise that got into the aircraft radios.  The solution was to manually scab on a couple of extra capacitors, one directly to IC pins on the bottom of the board, and another directly to pins on the top of the IC, as close to the body as possible, and with the absolute shortest lead length on the capacitors as possible.  (This was 20 years ago, and thru-hole.)  We also added capacitors in a couple of other places, and ferrite beads over three wires.  That took care of the noise.  Dr. Howard Johnson, industry guru of high-speed digital design, says he wishes manufacturers would guarantee a minimum rise time also, not just a maximum, for reasons like this.
As for a 7805, the only product we ever put one in had no heating issues of any kind, at any time.
http://WilsonMinesCo.com/
Lots of 6502 resources
Edited by GarthW, Sat May 31, 2014 1:57 PM.
