How big can you make a sprite?
14 replies to this topic
#1 STGuy1040 OFFLINE
STGuy1040
  • 1,162 posts
Posted Sat Jan 31, 2009 11:42 PM
If I wanted to use a single sprite, with colors, how big can I make it? I tried making large sprites in bBatari Basic but only parts of them display.
#2 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,673 posts
  • Braindead
Posted Sat Jan 31, 2009 11:57 PM
You can make a sprite 8 pixels wide and (nearly) as high as you want. Are you using Visual bB?
#3 STGuy1040 OFFLINE
STGuy1040
  • 1,162 posts
Posted Sun Feb 1, 2009 10:11 PM
Yes, I am, I was half asleep when I wrote that. lol I meant to say Visual bBasic.
#4 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,814 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Sun Feb 1, 2009 11:51 PM
Say you want to make a large character for your game that is made of two sprites. Instead of working on 2 separate sprites and trying to picture how they would look next to each other, you can make a wider sprite using the editor, draw your big sprite, then highlight half of it, copy it, open a new editor, then paste it. Do the same for the other half and be sure to keep your huge sprite in case you ever want to work on it some more.
#5 jrok OFFLINE
jrok
  • 1,155 posts
Posted Mon Feb 2, 2009 5:52 PM
If I understand you correctly, you're asking how "wide" a sprite can be? The quick answer is that each of the hardware sprites can be 8 pixels wide (no limit on height).
If you are using Visual bB's nifty sprite editor, you probably noticed that the editor allows you to set the width anywhere from 1-24 px. But this is really only for "planning" purposes, since the max hardware resolution is 8 px. Using NUSIZ0 or NUSIZ1 to make the sprite double or quadruple wide will "stretch" the image (pixels are rendered at 2x or 4x wide), but won't allow for a higher resolution.
If you want to create the illusion of a higher-res sprite with bB, AFAIK you have to do one of the following:
1) Use both the player0 and player1 sprites to create each half of the image. You can then line the sprites up on the same vertical position, and have them move together, i.e.
player1x = player0x + 8 : player1y = player0y
2) Same as above, except use 30hz flicker, so that on the even frames a player sprite displays the left half of the "big sprite" and on odd frames it displays the right half. i.e.
frame1
   player0x = x
   gosub ShowLeftSide
   goto frame2
frame2
   player0x = x + 8
   gosub ShowRightSide
   goto frame1
The second method is *probably* preferably for in-game graphics, since method one would use up both sprite objects and leave you with just the ball if you are using multicolor sprites. I've been experimenting with some higher res graphics over at Homebrew Discussion if you want to check it out. Its basically "method 1" but if I was going to make a game out of it, I'd probably convert it to method two.
Cheers,
Jarod.
Edited by jrok, Mon Feb 2, 2009 9:44 PM.
#6 MausGames OFFLINE
MausGames
    Dragonstomper
  • 897 posts
Posted Mon Feb 2, 2009 8:23 PM
Actually, I think what he was asking has to do with the vbB sprite editor, but I'm not sure...could you be less obscure in what you are asking here STGuy?
#7 STGuy1040 OFFLINE
STGuy1040
  • 1,162 posts
Posted Tue Feb 3, 2009 4:35 PM
Yes, sorry; I was wondering what the maximum sprite size was for the bBasic sprite editor because I find it a bit confusing. My reason being; when using bBasic, it allows you to expand the sprite grid far beyond what the 2600 can display (from what I have found) but jrok pretty much answers the question by stating that each sprite can be 8 pixels wide and no limit on height, so it looks like bBasic gives more room for planning (like someone previously said) and I didn't realize this.
Edited by STGuy1040, Tue Feb 3, 2009 5:12 PM.
#8 MausGames OFFLINE
MausGames
    Dragonstomper
  • 897 posts
Posted Tue Feb 3, 2009 9:10 PM
Well obviously there is a finite height for the sprites, my guess it is either 256 pixels, or if there is no limit then the maximum size would be 4k worth, which would be pretty long
#9 MausGames OFFLINE
MausGames
    Dragonstomper
  • 897 posts
dp
Edited by MausGames, Tue Feb 3, 2009 9:11 PM.
#10 Random Terrain OFFLINE
Random Terrain
  • 28,814 posts
    Replay Value
    Nonlinear
Posted Tue Feb 3, 2009 9:36 PM
Yep, there seems to be a 256 height limit. I found that out when I was working on Tone Toy 2008.
#11 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Tue Feb 3, 2009 9:53 PM
In bB, the height of a sprite is stored in a single byte, so the largest height would be 255. This is far higher than what would actually get displayed on screen though, since the default playfield height is 88 lines and maximum would be about 120 lines.
#12 freshbrood OFFLINE
freshbrood
    Star Raider
  • 81 posts
Posted Fri May 6, 2016 3:18 PM
Does changing the default playfield block sizes, or overall screen size use up much more memory?
For example: If I want to squeeze every last single little bit out of my game, and ONLY make as many different unique sprites from player0 and player1 as possible, would using the default playfield size (88?) yield me more memory space?
Can I squeeze a bit more space by making the playfield size smaller? Is playfield size and playfield pixels/blocks the same thing?
And finally, I understand that using the multicolor player kernel causes the loss of the missile. Can this be toggled on and off? For example: a 6 colored player that becomes one solid color while firing a missile, then when the missile disappears, becomes 6 colors again?
If player graphics are always stored in the last bank (when using multiple banks), then couldn't you put a "player colors off/missiles on" sort of kernel in a different bank than the first kernel that causes the loss of the missile?
#13 Random Terrain OFFLINE
Random Terrain
  • 28,814 posts
    Replay Value
    Nonlinear
Posted Fri May 6, 2016 3:48 PM
This is all I know about using the missiles when they are lost:
atariage.com/forums/topic/250879-can-a-tall-rectangular-sprite-be-made-of-copies-of-one-row/?p=3479250
Somebody else will have to answer the other questions.
#14 freshbrood OFFLINE
freshbrood
    Star Raider
  • 81 posts
Posted Thu Jul 26, 2018 5:07 PM
I'm having trouble making a sprite higher than 35 lines. I'm using the set kernel_options player1colors playercolor pfcolors And for some odd reason, it will fail to compile when I draw a sprite higher than 35 lines. Is this a known issue? What am I doing wrong? It's even less when I try to add colors- it just won't compile unless I lower the number.
Also, if anyone cares to help, I am still quite lost over using pfres. When I do, I either get giant blocks, or small squares in no discernable order. I cannot draw a decent looking playfield using pfres. A simple sample tutorial or .bas would be much appreciated.
Edited by freshbrood, Thu Jul 26, 2018 5:19 PM.
#15 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,291 posts
Posted Fri Jul 27, 2018 1:10 PM
I'd double check Random Terrains kernel options chart.
http://www.randomter...l#kernelopchart
Looks like you forgot an "s" in playercolors
This works fine for me with two 36 pixel tall sprites.
Attached File  tallsprite.bas   1.97KB   14 downloads
