+atari2600land Posted August 21, 2013 Author Share Posted August 21, 2013 OK, I typed in 64kSC instead of 64k and Visual bB is giving me a new complaint. player1: %00000000 %00001111 %00001111 %00001111 %00001111 %00001111 %00001110 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00001100 %00111100 %01111100 %11111100 %11111000 %11111000 %11111000 %11111000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11110000 %11111100 %11111110 %11111110 %11111110 %11110110 %11000110 %11000110 %11000110 %11000110 %11110110 %11110110 %11110110 %11000110 %10110111 %11110011 %11111011 %11111011 %11010000 %11010000 %11010000 %11010000 %11010000 %11110000 %11110000 %11110000 %11110000 %11110000 %10100000 end player1color: 240 240 ... It doesn't like the first "240," claiming it's a syntax error. plim44.bas Quote Link to comment Share on other sites More sharing options...
jwierer Posted August 22, 2013 Share Posted August 22, 2013 64kSC support is new, you'll have to add it to the vbB dictionary. Compiling from the command-line can sometimes give more information: You have a double "end" after this block of code if e>40 then player1: (990): Warning: size of subsequent pfcolor tables should match (1037): Warning: size of subsequent pfcolor tables should match (1070) Warning: long line (1097) Warning: long line (1339) Warning: long line (3647): Error: Unknown keyword: 240 ->probably because of the long lines or the pfcolors having different counts vs. number of pixels. -Jeff Quote Link to comment Share on other sites More sharing options...
RevEng Posted August 22, 2013 Share Posted August 22, 2013 The 240 error is for the reason I reported here. (the attached plim44.bas has the player1color: as part of an if...then) Quote Link to comment Share on other sites More sharing options...
iesposta Posted August 22, 2013 Share Posted August 22, 2013 I got around the limitation of using all the sprite / playfield data area, in DPC+, in my (5 playfields) Jumpman Donkey Kong (which i started way before Joe M.'s excellent assembly DK2600) in my blog, by using data statements in the banks and then using Bogax's code loops to pfpixel on / off the entire playfield. (Sorry no example code for DKbB2600.) To use data statements for sprites, you would have to use the player pointers and math to point to additional sprite data. I don't know how to do this, but it can be done. So when you've used up all the sprite / pf data area, you figure out a way to add more. Sorry I haven't really helped, but I hope I gave you some ideas! Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 22, 2013 Author Share Posted August 22, 2013 Finally! I think I have gotten it back to pre-64k status and it's 64k. It took a lot of testing, typing, screaming and yelling, but 4 hours later, it's finally done. Let me know if you see any bugs. Question: The only reason I used 64kSC is because I thought I had to. But I got it to compile just using set romsize 64k (with no SC at the end.) So would it be easier to make carts now that I'm not using a Superchip? plim47.bas.bin plim47.bas Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 23, 2013 Author Share Posted August 23, 2013 (edited) I found a bug. If I set the level at the beginning to the beginning, upon reaching level 6, I get garbage for the second digit of the right score. I don't know why this happens. The section for the line where this happens begins at line 3,750 if you want to take a look. If I set the level to 5 and play through level 5, it displays the correct number instead of garbage for level 6, which is really odd. plim50.bas Edited August 23, 2013 by atari2600land Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted October 31, 2013 Author Share Posted October 31, 2013 OK, so I'm back working on this again. Level 7 is a watermelon-collecting stage, and level 8 you throw the watermelons at the alien. If you get to 0 watermelons, you repeat level 7 over again until level 8 is completed. Right now, hitting the alien with the watermelon does nothing and if you run out of watermelons, level 7 repeats. In this version, you start with 2 watermelons and 2 seconds, so it would be easier for me to test level 8. I noticed a bug, though, and it has to do with the playerscores. Someone told me to enter the following code, and it works ok, except when you have more than 9. If you have, say, 10 and want to subtract, it goes from 10 to 1[garbage] instead of 09. How would I fix this? subtract_player1score asm sed ; set decimal mode end player1score=player1score-$01 asm cld ;clear decimal mode end return plim51.bas plim51.bas.bin Quote Link to comment Share on other sites More sharing options...
RevEng Posted October 31, 2013 Share Posted October 31, 2013 If you have, say, 10 and want to subtract, it goes from 10 to 1[garbage] instead of 09. How would I fix this? The numbers you use have to be BCD compliant. So instead of subtracting 10, you need to subtract $10. I just tested CurtisP's playerscores with adding and subtracting $10, and it works fine. Also worth mentioning that with my updated bB release you can issue "dec player1score=player1score-$10" to subtract in decimal mode without assembly wrappers. 1 Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted October 31, 2013 Author Share Posted October 31, 2013 OK, but I don't want to subtract ten, I want to subtract one when the score is 10. Is there an easy way to do this? Quote Link to comment Share on other sites More sharing options...
RevEng Posted October 31, 2013 Share Posted October 31, 2013 Ah, I see the problem. bB optimizes "player1score = player1score - 1" into "DEC player1score", which is an assembly command that doesn't work in decimal mode. If you change your line to "player1score = player1score - $1", bB won't optimize it and it will work with decimal mode. (or you can use a later bB and the "dec" command, which doesn't do that optimization for this very reason) Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted October 31, 2013 Author Share Posted October 31, 2013 I need to use a 64k bB or else my game won't work. There's too many graphics. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted October 31, 2013 Author Share Posted October 31, 2013 (edited) Aha! I slimmed it down to 32k! Now you (or I) can use it on Harmony again! There is a slight graphical change I had to make regarding level 4's background. It now looks like this. And I think the change to 32k is for the better because the storyline I had planned is almost going to wrap up. There is a final fight between the aliens and Frank and it happens in level 8 in bank 7. Bank 8 has 393 bytes left even though there's hardly anything written in it. plim52.bas plim52.bas.bin Edited October 31, 2013 by atari2600land 1 Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted November 1, 2013 Author Share Posted November 1, 2013 The problem came up again in bank 6. Luckily I had enough space to put in the following solution: y=player0score if player0score=$8f then player0score=$89 : y=89 if player0score=$7f then player0score=$79 : y=79 if player0score=$6f then player0score=$69 : y=69 if player0score=$5f then player0score=$59 : y=59 if player0score=$4f then player0score=$49 : y=49 if player0score=$3f then player0score=$39 : y=39 if player0score=$2f then player0score=$29 : y=29 if player0score=$1f then player0score=$19 : y=19 if player0score=$0f then player0score=$09 : y=9 NOTHING ELSE WORKED. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted November 2, 2013 Author Share Posted November 2, 2013 I worked on this some more. I actually put something on the TV screen in the intro before the static so he's actually watching something. I also worked a little bit on level 6, adding sfx, as well as a little bit of other stuff. plim54.bas.bin Quote Link to comment Share on other sites More sharing options...
PFL Posted November 2, 2013 Share Posted November 2, 2013 This looks really interesting. Did you ever manage to fit in all the elements you first described in your first post? Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted November 2, 2013 Author Share Posted November 2, 2013 For a complete rundown of what levels are in the game, you can visit my Plim page: http://www.atari2600land.com/plim/ So yes, I did and added quite a number of other stuff. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted November 3, 2013 Author Share Posted November 3, 2013 This version starts at the watermelon fight. You get 30 watermelons for this special testing version. The final game and number of watermelons depends on how many you collect in the forest. I want your input on two things. #1 - How hard/easy is it to hit the alien? I'd like a certain number of times you need to hit him, but I don't know what that number is. #2 - After you hit the alien once, he beams you up into the spaceship for the final fight with the alien king. For the alien spaceship, I imagined a big fighting arena with a window that looks out over space. How good did I draw the spaceship's inside? plim55.bas.bin Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted November 4, 2013 Author Share Posted November 4, 2013 OK, this version starts at the final fight. I've begun work on the final fight against the alien king. When you jump on his head, he flashes, mumbles some alien swearing then disappears. What he says, though, is the same thing every time even though I'm using rand. rem : d{0}= alien king's head jumped on, start alien talk if d{0} then e=e+1 : AUDC0=1 : AUDV0=5 : AUDF0=g if e>0 then g=rand/8 That's the code. Why is it that I'm using rand, yet it does the same "talk" every time? If you want to help, the final fight code begins at line 4,875. (BTW: The reason he disappears is because he's about to throw watermelons at you and then he'll reappear in a random spot, but I haven't got that far yet.) plim56.bas.bin plim56.bas Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted November 5, 2013 Author Share Posted November 5, 2013 Goodie, I found a new bug. If you die in level 2 and restart the game, level 1's player1score is all messed up (see picture.) Odd thing is, it ISN'T messed up if you start the game the first time. I'm still having trouble with the alien bug in the last level. plim57.bas.bin plim57.bas Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted December 23, 2013 Author Share Posted December 23, 2013 The score problems seem to have gone away for the moment. I guess because I used a different "font," but I don't see how that would make it better, though. I'm back working on this. Let me know if you find any bugs. plim58begin.bas.bin Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted December 24, 2013 Author Share Posted December 24, 2013 Question. What is the "coin" in Mario Bros. and how do I make it be in my Plim game? I'd like to include stars in the background to simulate zooming through space on the last level, and I thought flickering stars would do that best. Looking at a Mario Bros. screenshot, it looks like it is a missile of the player that Mario Bros. is. And looking at this screenshot, the missile takes the colors of Mario. So why can't I be able to take missile 1 and have its colors be the hair of Frank and have that be flickering stars going by? Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted June 12, 2014 Author Share Posted June 12, 2014 I've just decided to have Plim be 32k. For some reason I decided to work on it again. I found a bug though in level 1 involving the end of it. There are two versions I've uploaded here. plim60.bas.bin is at the end of the game. The final fight. I need some feedback as to its difficulty. Too hard? Too easy? Also, plim60begin.bas.bin starts you at the very beginning of the game so you can have the full plim experience before you get to the final fight. Right now if you beat the alien king on the final fight, it just loops back, but I plan on programming in a final cut scene to end the story. I will not make that version public. You'll have to get Plim and beat it yourself to see the final ending. But first I have to think one up, or I could just say "to be continued" and make a Plim 2? plim60.bas.bin plim60begin.bas.bin Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted June 12, 2014 Author Share Posted June 12, 2014 OK, I fixed the bug in level 1, but then I went a few bytes over bank 1's limit. So then I had to fix that. So I did. I now will have 6 bytes left if I use the goto command to get to the part I'm working on, 24 bytes if I don't use it (which I ultimately will be doing. After all, you don't want a game where you start at the end!) Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 13, 2014 Share Posted June 13, 2014 Plim, Plim, PlimWhat's she gonna do about PlimShe's gonna have to do without PlimOr do without me, me, meNo one gets to get it for freeIt's me or it's Plimyoutube.com/watch?v=cYMAcV4S2Fghttps://www.youtube.com/watch?v=cYMAcV4S2Fg Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted July 9, 2014 Author Share Posted July 9, 2014 Still plugging away. I made it so that you can shoot anywhere in level 1, just not on the ground. To do this, I had to make level 1 look, well, plain. I also added a Game Over screen. 2 Quote Link to comment Share on other sites More sharing options...
