Request for screen captures from NTSC Ataris
60 replies to this topic
#1 Kr0tki OFFLINE
Kr0tki
  • 1,091 posts
Posted Mon Apr 6, 2009 4:49 PM
Hello,
I'm trying to recreate the colours generated by NTSC Ataris, in order to improve the Atari800 emulator's video output quality; and I want to make it as accurate as possible. I am well aware of previous threads in this topic; I've even contributed to some of them. I'm also aware of a routine posted in this thread, that aims to recreate the NTSC colours. However that routine was based on only one NTSC screenshot, and that's not enough to consider it accurate. Additionally, the aforementioned screenshot contains a certain irregularity in its colours, and I'm not able to develop a mathematical basis for it.
So I'd like to ask those of you who own NTSC Ataris and have access to a video capture device, to make some screenshots for me :) I've attached a program (in BASIC and as a DOS file) that generates a 256-colour screen. Please make a screen-grab of that program running and post it here.
Now I've heard that modern PC video capture cards may not synchronise properly to Atari video output, and may produce unstable display. As long as some colour info is retained, such display would still be useful for me, so please post it anyway. Also provide some additional information if possible: computer model, whether it's GTIA or CTIA (yeah right), was it modified to S-VIDEO output, ClearPic or whatever.
Based on gathered screenshots, it might then be possible to develop an accurate colour generation.
#2 SeaGtGruff OFFLINE
SeaGtGruff
  • 5,558 posts
Posted Mon Apr 6, 2009 5:05 PM
I think I had provided the only NTSC screenshot in that thread. I know what you mean about the irregularity, because I'd tried to get the grainy color blocks down to solid colors in a graphics program (by averaging or blending the pixels in each color block), then read off the RGB and HSL/HSV values for the solid colors, but I could never get values that conformed to an obvious pattern-- e.g., the different shades for hue 1 would come out with a wide divergence in the HSL hue values, and this was in the central shades, so I don't think it was due to clipping.
That screenshot was from many years ago, using a VCR and Snappy capture device. I'll try recording a 256-color image to DVD and then transfer it to my computer.
Michael
#3 Kr0tki OFFLINE
Kr0tki
  • 1,091 posts
Posted Mon Apr 6, 2009 5:47 PM
Yep, it was you who provided the only NTSC screenshot I could find on the whole Internet :) I've tried to develop a pattern for each of the 16 luminances, and every time it was diffrerent. Moreso, hues 1 and 15 looked almost the same, and that contradicted (well it's subjective) the GTIA.PDF document, in which those 2 hues are called "Gold" and "Light-Orange". So an additional screen capture would be extra cool, thanks.
#4 poobah OFFLINE
poobah
  • 1,635 posts
Posted Mon Apr 6, 2009 6:08 PM
Hmmm.
Gonna be hard to do... Every camera has a different response curves (and lots of settings to muck about with), no guarantee that your display is going to accurate either (well, maybe you've got a mac with a colorometer)
Good luck with the project.
#5 Kr0tki OFFLINE
Kr0tki
  • 1,091 posts
Posted Mon Apr 6, 2009 6:35 PM
Camera? I was actually thinking about connecting Atari to a TV card in a PC; making a photo would indeed not be accurate enough. SeaGtGruff's method is also practical.
Edited by Kr0tki, Mon Apr 6, 2009 6:36 PM.
#6 HiassofT OFFLINE
HiassofT
  • 1,057 posts
Posted Mon Apr 6, 2009 7:22 PM
OK, here's a first try. I've only got a single, stock NTSC 800XL (I'm living in PAL world, too :-) and connected it via composite to my Hauppauge WinTV (BT878 chip).
BTW: the COLORS.COM didn't work for me (tried with MyDOS and MyPicoDos), after loading it displayed the color screen for a short time and then the display broke down - MPlayer and xawtv only showed a blue screen (I never had this before, and I use my WinTV card all the time when testing Atari stuff).
Anyways, here's the picture from COLORS.LST:
so long,
Hias
#7 Rybags ONLINE
Rybags
  • 15,627 posts
Posted Mon Apr 6, 2009 7:28 PM
Capture cards also have the problem that you can have custom settings for gamma, brightness, contrast and hue shift.
I think an "ideal" situation might be where we could sample the actual hue phase shift with a 'scope or some other fast measurement method. Luma is simple enough, since you can generate a static voltage that lasts near enough to 50 milliseconds.
Then again, is the relationship between actual perceived brightness and the voltage on the luma signal exactly linear?
#8 Allas OFFLINE
Allas
  • 1,103 posts
Posted Mon Apr 6, 2009 7:53 PM
Other way, I modified the bottom knob of my Ataris to get the most near to screenshots I seen on PC.
#9 Kr0tki OFFLINE
Kr0tki
  • 1,091 posts
Posted Tue Apr 7, 2009 3:38 AM
Strange. I've tested it under Atari800. I've got the program from the emulator's source package, I'd believe it to be error-free. Anyway, thanks for the screenshot.
Does you eye perceive brightness linearly? :) Well, I've found an article from which I don't understand too much, but it states that:
- CRT displays don't display luminance linearly; they have a gamma of approx. 2.5;
- NTSC cameras are designed to assume the above, and use gamma correction of 1/2.2 to correct the CRT's gamma.
So I think the answer should be "no". But anyway I'd like to leave the gamma setting user-configurable. Problem solved :D
Edited by Kr0tki, Tue Apr 7, 2009 4:01 AM.
#10 Larry OFFLINE
Larry
  • 3,962 posts
Posted Tue Apr 7, 2009 4:35 AM
Here's a capture from my ATI PC video card -- my A8 display.
-Larry
#11 AB Positive OFFLINE
AB Positive
    Moonsweeper
  • 375 posts
Posted Tue Apr 7, 2009 8:23 AM
All I have is RF connection to a regular TV but if a pic from that setup would help I'd be happy to take a few screenies. I have a SIO2PC cable to load the program.
-AB
#12 HiassofT OFFLINE
HiassofT
  • 1,057 posts
Posted Tue Apr 7, 2009 2:55 PM
Here's another capture of my NTSC 800XL, this time I used a Fast AV Master card (brightness, contrast, color set to 50%, color phase set to 0%). Interesting sidenote: COLORS.COM worked with this card.
so long,
Hias
BTW: the video output of this 800XL is really crap compared to my other PAL 800XLs with the SuperVideo mod - I think I'll have to do the mod to the NTSC 800XL as soon as possible.
#13 Allas OFFLINE
Allas
  • 1,103 posts
Posted Tue Apr 7, 2009 3:19 PM
so long,
Hias
Could you send a screenshot capture from your Supervideo XL?
#14 Cybernoid OFFLINE
Cybernoid
    Dragonstomper
  • 889 posts
  • Luck can't last a lifetime unless you die young.
Posted Tue Apr 7, 2009 3:38 PM
All pics are from my old school Hauppaugge WinTV capture card via composite.
From 800XL #1 | From 800XL #2 | From 130XE #1 | From 130XE #2 (has clear-pic video mod)
#15 HiassofT OFFLINE
HiassofT
  • 1,057 posts
Posted Tue Apr 7, 2009 5:11 PM
Here are some more screenshots, done with my Fast AV Master. BTW: I just noticed that they contain some JPEG artifacts, this card seems to do always JPEG compression (it also grabs movies in MJPEG only).
Stock NTSC 800XL, no SuperVideo mod:
My main PAL 800XL:
Another PAL 800XL:
My PAL 600XL:
so long,
Hias
Edited by HiassofT, Tue Apr 7, 2009 5:13 PM.
#16 SeaGtGruff OFFLINE
SeaGtGruff
  • 5,558 posts
Posted Tue Apr 7, 2009 5:51 PM
It's interesting that the PAL screenshots show definite (i.e., large) hue jumps at certain spots, like from red to purple, or from blue to green-- whereas the NTSC screenshots tend to have more gradual transitions.
Michael
#17 Rybags ONLINE
Rybags
  • 15,627 posts
Posted Tue Apr 7, 2009 7:54 PM
NTSC has much better colour graduation... the especially annoying thing with PAL is Colour 4 which many games assume to be a nice Red but on PAL you get an annoying purple.
Similar with Colour 10, on PAL it's green with a hint of blue but on NTSC it's predominantly blue.
Going by these shots though, PAL seems to have a nicer luma spread.
#18 Allas OFFLINE
Allas
  • 1,103 posts
Posted Tue Apr 7, 2009 9:24 PM
Thanks for the screenshots, I take in consideration the next time i do some software for Atari. It's great to have the register PAL on Atari.
#19 SeaGtGruff OFFLINE
SeaGtGruff
  • 5,558 posts
Posted Tue Apr 7, 2009 9:40 PM
I don't know about the luma spread on a TV screen. When I view the 2600's or 7800's NTSC color palette on a TV, the colors seem pretty bright. If I record it to a DVD, and play it back on the TV, it still seems bright. But if I view the DVD on my computer, the picture is hopelessly darkened, and no amount of fiddling with gamma corrections or brightness and contrast seems to give an adequate reproduction of what the TV shows.
The screenshot I posted a while back-- in the other thread that's referred to in the first post-- was made many years ago from a 130XE connected to a VCR, which was connected to a Snappy, which was plugged into my computer. I had adjusted the brightness and contrast quite a bit in the Snappy software to try to get a decent luma spread, ranging from a pretty dark black to a pretty bright white. And back when the Atari 8-bit was my only computer (well, other than a VIC-20), I always displayed the 256-color palette and then adjusted my TV set's brightness, contrast, color saturation, and tint to get the best-looking colors.
Michael
#20 Rybags ONLINE
Rybags
  • 15,627 posts
Posted Tue Apr 7, 2009 10:17 PM
There's guidelines around somewhere...
pretty sure with TVs, the assumption is that black equals a value of about 16, and maximum white 240 (of a 0-255 scale).
#21 Cybernoid OFFLINE
Cybernoid
    Dragonstomper
  • 889 posts
Posted Tue Apr 7, 2009 11:49 PM
Actually, if you are talking about the 8-bit codes in Rec. 601, then black is at 16 and white is at 235. The color difference components range from 16 to 240. Luma component has a range/excursion of ~220 and chroma components ~225.
Wow, very limited information at Wikipedia... http://en.wikipedia.org/wiki/CCIR_601
For NTSC analog video, black should be at ~ 53 4/7 mV, White at ~714 2/7 mV, Blanking at 0 mV, and Sync at -285 5/7 mV. I guess that means since we have 16 luma values available on the Atari, they should be ~(660 5/7)/16 mV apart.
Edited by Cybernoid, Wed Apr 8, 2009 12:08 AM.
#22 Kr0tki OFFLINE
Kr0tki
  • 1,091 posts
Posted Wed Apr 8, 2009 8:15 AM
Thanks, but I doubt that a photo would preserve colours with needed accuracy.
Michael
Yes, it looks strange. Hias, do the PAL colours really look like that on a real TV?
Anyway, thanks for the screenshots. I'll analyse them when I get home.
#23 AB Positive OFFLINE
AB Positive
    Moonsweeper
  • 375 posts
Posted Wed Apr 8, 2009 8:29 AM
I didn't think it would help but I thought I'd offer. Thankfully some folk have TV capture cards :D
#24 Rybags ONLINE
Rybags
  • 15,627 posts
Posted Wed Apr 8, 2009 8:37 AM
In my experience they're usually less saturated than that, and the colours blend into each other a bit more smoothly.
But of course it can vary hugely dependant on settings, whether you have video mods and which output you're using.
I'll have to try my 400 out... it's got the nicest colour representation of my machines, although maybe not the sharpest picture.
Edited by Rybags, Wed Apr 8, 2009 8:37 AM.
#25 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Thu Apr 9, 2009 2:05 AM
I saw some picture of Atari 2600 Palette on the internet resolved into RGBs. It looks same as Atari 800 palette (not including GTIA modes).
A better approach (although more complex) would be to know the schematic of how the colors are outputted and model them using the behavior of the circuit.
