my first batariBasic game
10 replies to this topic
#1 elad OFFLINE
elad
    Combat Commando
  • 7 posts
Posted Wed Jun 24, 2009 10:13 PM
Hi everyone I've been working on my first game for the 2600 for a while now and I think its just about ready for a proper release.
The game is called GHOST MAZE and the aim of the game is to collect the four magical items hidden throughout the maze and return to the entrance,
along the way you may also find a sword and a sheild that will help you against the radioactive ghosts that gaurd the maze.
I would realy apreaciate any feedback you could give, any bug reports/ suggestions , ect.
Also if anyone has access to a rewritable cart I would love to know how it runs on the actual hardware, unfortuanatly I dont yet have the hardware to
test this for myself
Posted Image
Posted Image
Posted Image
edit: heres the new rom: Attached File  ghostmaze.bin   4KB   341 downloads
Attached File  ghostmazeold.bin   4KB   140 downloads
Edited by elad, Sat Jun 27, 2009 2:21 AM.
#2 yuppicide OFFLINE
yuppicide
    I am the Black Knight. Give me your money!
  • 6,933 posts
Posted Thu Jun 25, 2009 9:20 AM
I'll have to try it out when I get home from work later. I don't have a cartridge to put my stuff on either. One thing I do not to test if something is good is run the game in Stella. Then hit the ` key. This will bring up the debugger. You can then go frame by frame with the Frame+ button and see if your scanlines are getting a constant 262 (NTSC).
#3 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
  • Intellivision / Apple II
Posted Thu Jun 25, 2009 12:11 PM
Wow, the maze is big. I'll have to break out the ol' graph paper! I think it would be more fun if there were different types of enemies (or even color / speed) and some that would chase you from room to room. I'll play some more later and try to find the other objects. We can always use more Adventure games!
#4 Dan Iacovelli OFFLINE
Dan Iacovelli
  • 6,086 posts
Posted Thu Jun 25, 2009 1:43 PM
I could convert to wav format and then load it into my supercharger to see how it runs.
mostly all games made with bBasic can be ran on the system itself.
#5 elad OFFLINE
elad
    Combat Commando
  • 7 posts
Posted Fri Jun 26, 2009 2:17 AM
thanks for the feed back.
yuppicide i did not know about the debug screen although thats probably because i was still using v1.4.1.
the scan lines are staying at 262 so thats good however im from australia so will it make a difference running the game on a pal console?
Byte Knight there isnt room in the rom at the moment to add new enemies (0 bytes free) and I want to keep it inside 4k to make making my own carts easyer, however if the ghosts are to easy to avoid changing the left dificulty setting should make them move almost twice as fast.
#6 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Fri Jun 26, 2009 6:51 AM
You need to tell bB you're using PAL. For PAL you should be at 312 scanlines.
See here how to set PAL.
http://www.randomter...ommands.html#tv
#7 gambler172 OFFLINE
gambler172
  • 3,351 posts
  • none
Posted Fri Jun 26, 2009 1:32 PM
Hi Elad
Not bad for a first effort.
greetings Walter
#8 sandmountainslim OFFLINE
sandmountainslim
    Vicar of Fonz
  • 5,669 posts
  • Climber 5 Champion since Jan 2005
Posted Fri Jun 26, 2009 5:05 PM
Cool!
Is this a Pac-Man sequel?
It plays like a cross between pac and adventure.
Wp
#9 elad OFFLINE
elad
    Combat Commando
  • 7 posts
Posted Fri Jun 26, 2009 6:24 PM
cool thanks for the info ill be reading through that today. I also managed to save 196 bytes by removing pf_scroll from the includes file (thanks again to ipaler_26 for the tip) so I should be able to at least add one more type of enemy to help make things more interesting.
Cool!
Wp
its meant to be more of an adventure sequal than a pac man sequal but the ghost is moddeled on the pacman ghosts
#10 elad OFFLINE
elad
    Combat Commando
  • 7 posts
Posted Sat Jun 27, 2009 1:37 AM
alright i added a few dragons to the game they dont move any faster in the higher dificulty setting but they will kill you instantly, otherwise there just a different sprite for the ghost.
if you guys think the dragon makes this look a little to copywrite infringing let me know and ill change it to somthing a bit different.
the new rom is attached to the original post in this thread.
#11 sandmountainslim OFFLINE
sandmountainslim
    Vicar of Fonz
  • 5,669 posts
Posted Sat Jun 27, 2009 8:30 PM
Cool game.
The ghost got me to thinkin that someone should make a maze type game where you are Clyde or one of the other pac monsters and you are running around avoiding the cracked up Pac-Man, Ms Pac and Jr. Pac :)
That would be a great game.
Wp
