Cycle counting-- page boundary on indirect access?
7 replies to this topic
#1 Propane13 OFFLINE
Propane13
  • 1,649 posts
Posted Wed Jul 22, 2009 5:15 AM
Hello!
So, I have a bug that I've been trying to squish, but I don't really understand where the bug lies.
I have a loop, and that loop on occasion takes too many cycles.
But on occasion, I mean in one special situation for one single frame, I end up at 77 cycles.
My loop has 2 items in it that according to the cycle counting guide could be variable.
Item 1 is the end of the loop of course:
DEY
DEX
BPL PFScanline4Loop
The instance seems to happen the last time through, when the branch is NOT taken.
From what I read, I believe that the only time that this page-boundary issue occurs is when the branch is taken, and the branch crosses a page boundary.
So, if my interpretation is right, that means that PFScanline4Loop starts at say, $FEF0 and the end of the loop is at $FF10, so when the branch is taken, the branch crosses the $FF00 page, adding an extra cycle. Is that the correct interpretation? If so, not taking the branch would have no effect, correct?
That leads me to the only other variable parameter in the loop
At 2 places, I have the following code:
LDA (P1Color),Y
STA COLUP1
LDA (P1GfxPtr),Y
STA GRP1
I am thinking that for the one instance where there's a problem, one (or both) of these fetches are crossing a page boundary.
The problem is... I have absolutely no idea what this means.
P1GfxPtr and P1Color are in zero-page. So, there's no need to worry about a page boundary there.
Of course they point to a physical location.
Let's say that location is $FEF0.
Does that mean that if we add Y to it, and Y is 17, I'll have an issue because then the added result crosses a page boundary and results at $FF01?
Just making sure my interpretation is correct here.
Thanks!
-John
-John
#2 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Wed Jul 22, 2009 5:28 AM
Branch not taken always = 2 cycles. Page crossing only comes into effect for branches that are taken.
Indirect addressing r (nn,X) isn't affected by Page boundaries. In fact, Indirect,X will just wrap around from $FF to $00 as 16 bit processing of the operand doesn't take place.
ed - fixed... (nn),Y is affected by page boundaries.
Edited by Rybags, Wed Jul 22, 2009 6:28 AM.
#3 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,821 posts
  • Busy bee!
Posted Wed Jul 22, 2009 5:57 AM
Correct!
Not quite correct. If the branch is not taken then the cycle time is down to 2 cycles. For a branch :-
2 cycles - Not taken
3 cycles - Taken
4 cycles - Taken over a page boundary.
Correct!
When using indirect indexed its easier to think of it causing an extra carry inside the CPU. In your example when you add 17 to LSB of the source address $F0 then the answer is $101. This generates an "address carry" (for want of better words) which can only be resolved by adding another cycle to the instruction time.
EDIT: If theres no carry generated the extra cycle isn't needed.
Edited by GroovyBee, Wed Jul 22, 2009 5:59 AM.
#4 SeaGtGruff OFFLINE
SeaGtGruff
  • 5,566 posts
Posted Wed Jul 22, 2009 2:07 PM
When I add cycle counts next to my code, I like to put one asterisk to indicate the possible addition of another cycle, and two asterisks for the possible addition of two cycles. I usually show a minimum of three columns-- the number of cycles for the current instruction, the total number of cycles for the current line, and the color clock for the current line (total cycles times 3). I also like to indicate the "entry" cycle for the beginning of a loop, and an exit cycle for a subroutine (so if I say "JSR something," and the timing is important, I'll know that I need to enter the subroutine at a certain cycle, and that I'll be at a certain cycle when it comes back).
LDA #0	 ; +02  ; ??  ; ???
   STA WSYNC  ; +03  ; 00  ; 000
   STA VBLANK ; +03  ; 03  ; 009
   LDX #192   ; +02  ; 05  ; 015
loop		  ; enter : 05
   INC COLOR  ; +05  ; 10  ; 030
   LDA COLOR  ; +03  ; 13  ; 039
   STA COLUBK ; +03  ; 16  ; 049
   DEX		; +02  ; 02  ; 006
   BNE loop   ; +02**; 04**; 012**
   LDA #2	 ; +02  ; 06  ; 018
   STA VBLANK ; +03  ; 09  ; 027
I find that the asterisks help if I run into timing glitches and need to quickly zero in on the portion of the code that might be taking a little longer than I was expecting. And, yes, obviously the entry cycle for a loop might not be exactly the same when the program first falls into the loop versus when it goes back to the loop, so I might say something like "enter : 67 or before," or maybe even something like "enter : 45 to 67" if the loop requires that the program not enter before a certain time. And if the entry cycle is variable, I usually count the cycles *inside* the loop based on what they are the second time through, or maybe give multiple sets of cycle counts if necessary. Of course, cycle-counting is usually only needed when the timing is critical and needs to be pretty damn specific, so most of the time it turns out that only one set of cycle counts are needed for a loop.
Michael
#5 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,857 posts
Posted Wed Jul 22, 2009 11:53 PM
It's rarely a problem. In some cases, a 4-cycle branch can be useful (since the 6502 lacks a 4-cycle JMP). If you are only skipping a byte ahead (jumping over a single-byte instruction), you can use a CMP # opcode to do it in 2 cycles (or NOP # if you don't want to mess up flag status).
Something that may be useful to you is to set up a macro to test your code in any cycle-critical loops or routines.
MAC CHECKPAGE;thx TZ
	  IF >. != >{1}
		 ECHO ""
		 ECHO "ERROR: different pages! (", {1}, ",", ., ")"
		 ECHO ""
		 ERR
	  ENDIF
   ENDM
To call it, just place it where you have your starting point and give the name of the destination. i.e...
ldx #$04
Waste19cycles:
	  dex
	  bne Waste19cycles
	  CHECKPAGE Waste19cycles
An error will be reported during assembly if the pages differ for the loop.
Edited by Nukey Shay, Thu Aug 13, 2009 9:22 AM.
#6 Robert M OFFLINE
Robert M
  • 1,488 posts
  • Rootbeer!
Posted Thu Aug 13, 2009 8:49 AM
If it is only happening on the last iteration of the loop, are you decrementing Y to -1 and X to 0 so the last pass through the loop Y = $FF which is causing a page boundary crossing?
#7 Dionoid OFFLINE
Dionoid
    Chopper Commander
  • 127 posts
Posted Wed Nov 28, 2018 4:54 PM
	  IF >. != >{1}
		 ECHO ""
		 ECHO ""
		 ERR
	  ENDIF
   ENDM
Note that the CHECKPAGE macro has an off-by-one error as it compares with the page of the current program position instead of "current program position - 1".
This should fix it:
    MAC CHECK_PAGE
.PREV_POS   SET . -1
        IF >.PREV_POS != >{1}
            ECHO ""
            ECHO "ERROR: different pages! (", {1}, ",", .PREV_POS, ")"
            ECHO ""
            ERR
        ENDIF
    ENDM
Edited by Dionoid, Wed Nov 28, 2018 4:55 PM.
#8 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,938 posts
  • Always left from right here!
Posted Thu Nov 29, 2018 12:59 AM
IIRC it depends if you use the macro to check for backward or forward addresses and therefore the macro is a compromise.
Probably two different macros would be better...
Edited by Thomas Jentzsch, Thu Nov 29, 2018 1:00 AM.
