How can POKEY IRQ Timers mess up NMI timing?
210 replies to this topic
#176 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Sat Aug 22, 2009 8:18 PM
Well, the CIA on the C-64 holds NMI low indefinately, until it's status is cleared by the user program.
In Atari's case, you don't want that because DLI usage on a 1 per scanline basis is reasonably common. The other thing is that Antic's original design also needed to cater for System Reset which could occur anywhere.
I think it's already been established that it's (S-Reset's) NMI only occurs at a certain cycle on the scanline. It could be that Antic needs to do things that way - there's some breathing space between DList Instruction and PMG fetches and the screen/refresh DMA burst, which in many cases keeps it busy for most of the remainder of the scanline.
All that aside though, you'd think they would have tested for contention issues like we're having, and likely could have implemented the simple fix of extending /NMI by a couple of cycles.
#177 Bryan OFFLINE
Bryan
  • 10,926 posts
  • Cruise Elroy = 4DB7
Posted Sat Aug 22, 2009 8:33 PM
The funny thing is that it doesn't really matter how long NMI is, as long as it's cleared before the next one. Inverting NMI makes Chris' sound code work great, so that way NMI is asserted for all but 2 cycles of each line. With one chip it could be extended by resetting a counter that counts for 8 or 16 cycles (74LS190 type with TC routed into /CE, and /NMI into /PL), but the inversion method works too.
Atari may have been trying to leave as much room as possible on the NMI line for other devices to use it since they can't be stacked like IRQ requests (edge vs level triggering).
#178 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Sat Aug 22, 2009 8:44 PM
But, by inverting NMI, won't that delay them by 2 cycles?
Problem is - there's a fair bit of code that does near the limit of stuff before STA WSYNC and 2 cycles extra wait could be enough to cause it do the WSYNC too late and miss a scanline.
#179 Bryan OFFLINE
Bryan
  • 10,926 posts
Posted Sat Aug 22, 2009 9:07 PM
Yes, they'd be delayed 2 cycles but it's interesting that it worked.
#180 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Sat Aug 22, 2009 9:27 PM
Sounds fair that it does work... all that's happening is the 1->0 transitions are 2 cycles late.
Unsolicited NMIs on the XL/XE are just assumed to be VBlanks, I guess if one was to sneak through on powerup it might upset things a little.
But, since they rely on the transition and not the level, I doubt you'd be getting any dubious behaviour other than that 2 cycle delay.
#181 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Sat Aug 22, 2009 11:10 PM
Here's /NMI vs phase2 clock (ph2). The 6502 datasheet states that /NMI will be sampled during the ph2 interval (ph2 high). So, NMI properly falls and rises during the ph1 part of the clock.
The problem must be that the 6502 requires not only a falling edge (one high sample followed by one low sample of /NMI) but NMI must also remain low until the some part of the CPU's interrupt sequencer is ready (not tied up in the early stages of an IRQ). I bet other 6502-based computers have longer NMI assertions, or ones that must be cleared.
Perhaps, the C64 doesn't have the problem because the interrupt/NMI handling is at 1.023Mhz and in making a 1.79Mhz version the circuitry wasn't sped up to deal with it (or wasn't debugged at that speed).
#182 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Sat Aug 22, 2009 11:14 PM
When I hit warm reset, I get the same color pattern so previous INIT settings didn't have any impact in that case (this is reset when I'm not hitting the NMI cycle with the IRQ). And this is an Atari 800 so it's not a chip reset.
When you hit Reset, it doesn't much matter if it's a chip or soft Reset.
The OS warmstart clears all the Hardware Registers, so any previous syncing of Timers is lost.
But... that only becomes apparent to someone using Timers if you've taken measures to change their alignment in the first place. Like I theorized before, you should get the same Timer alignment on a given machine every time because the warmstart clear-register routine hits WSYNC as well as putting Pokey into Init, so it causes a "default" alignment that should be the same on any machine using the same Operating System revision.
I thought you were talking about INIT state having a memory of previous setting so even with one WARM RESET-- you have initialized it twice with same cycle position.
#183 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Sat Aug 22, 2009 11:26 PM
I don't think the clock speed on the 6502 would have bearing on NMI handling. But, the number of cycles NMI is held low might.
The C64's differing case seems to be that CIA NMIs at least are held low until cleared by the program. No idea what the Restore key NMI does, maybe it's a momentary thing too, like Atari ?
It's yet to be shown if in fact the C64 has the same issue when using CIA NMI vs IRQs, I guess I should try and test that out. At least it might help prove once and for all if the Atari's problem is Antic, or it's just a generic 6502 issue that can potentially crop up on any machine.
#184 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Sat Aug 22, 2009 11:31 PM
Yeah, but even if NMIs are held down low for long time the fact that both occurred on same cycle and IRQ getting serviced first would flip priorities at least and if IRQ cleared the NMI request the NMI would never occur.
#185 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Sat Aug 22, 2009 11:39 PM
I don't have source with me on this disk I'm traveling with, I'll post the source code when I get home but I am getting a case where 3 consecutive cycles where I set INIT produce the same color patterns meaning the phase didn't move at all. (This is on Atari 800).
I don't see why it would make any difference when doing this on 800 or 800xl.
What would be nice is if you could post a .xex or .atr of the test prog when you get home.
One difference on 800 vs 800XL is the CLD instruction is missing from NMI/IRQ handlers on 400/800 OSes.
[It's been raining here in Tolland, MA and signal quality sucks-- finally got to log-in tonight; blackberry phones seem to be working fine though.]
#186 analmux OFFLINE
analmux
  • 2,392 posts
Posted Sun Aug 23, 2009 3:16 AM
OK, but then we can emulate the same effect on 800xl as on 800xl we can redefine IRQ handler.
Anyway, if it is just a 2-cycle difference (due to the extra CLD), it won't change the idea.
Maybe some shift in the results.
#187 Bryan OFFLINE
Bryan
  • 10,926 posts
Posted Sun Aug 23, 2009 12:06 PM
I'm going to test this circuit for stretching NMI. It only involves one chip and no extra parts.
EDIT: Results attached (stretched pulse on top). Works perfectly when playing sample.
Edited by Bryan, Sun Aug 23, 2009 1:05 PM.
#188 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Mon Aug 24, 2009 5:40 AM
I've just confirmed the behaviour using similar technique (enable SEROC IRQ at known times).
Burn 5 cycles after WSYNC then Store 8 to IRQEN. It blocks any DLI, except those types that are on single scanline modes.
To block single-scanline DLIs, strangely enough, you just need to burn 4 cycles after the DLI.
Might be just the way Antic does DLIs... if it's a single scanline mode line then it must start the NMI one cycle earlier.
I also tried the same technique but executing a 7-cycle 6502 Instruction... no problematic effects caused there at all.
Also tried varying the delay after WSYNC - no effect. It would seem that you need to store to IRQEN exactly on cycle 112 (or cycle 111 if dealing with single-line modes). But it could be that POKEY has some delay before triggering the IRQ once we've enabled it.
What mode/width are you using? WSYNC can be delayed by up to two cycles if playfield or refresh DMA extends to the end of a scanline. I've also suspected that you may encounter yet another cycle delay if the cycle immediately after STA WSYNC is contended, but unfortunately, I can't find my test app to confirm this.
Can we have some test code that shows best/worst case of WSYNC cycle delays? I have just been doing double WSYNCs when there is probability of DMA cycles to get exact positioning on the scanline.
#189 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Mon Aug 24, 2009 5:55 AM
The Antic Timings text document would help there.
Delays of WSync extending it beyond the normal restart should only occur in widescreen width or standard + scrolling.
DMA Contention immmediately following a WSync store? I think it doesn't matter - the 6502 should still fetch the first byte of the following instruction.
#190 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Mon Aug 24, 2009 8:06 AM
I was in normal 40 column graphics 0 text mode and my timer starting position was going off by one cycle and sometimes correct until I started doing two consecutive WSYNCs. Now it always starts at a constant position.
#191 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Mon Aug 24, 2009 8:18 AM
Well, when you have a badline, the number of cycles available drops considerably... also you have the DList Instruction at the very start of it.
There's also the consideration that if you store to WSync too late, it misses the boat and you end up a scanline later than you'd hoped for.
#192 Bryan OFFLINE
Bryan
  • 10,926 posts
Posted Mon Aug 24, 2009 8:29 AM
One thing I previously tried was connecting Antic's /NMI to its reset interrupt input. I was thinking that perhaps I could trick it into doubling up the NMI pulse, but of course it didn't work since reset is only sampled at certain intervals.
Anyway, I don't think we can count on anyone implementing a hardware fix. The best solution is a fool-proof set of interrupt timing routines.
#193 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Mon Aug 24, 2009 8:43 AM
Agreed... I can't see people doing a hardware fix for the sake of having maybe half a dozen games (that don't yet exist) work.
Plus there's always the possibility that it might break existing stuff that's out there.
#194 Bryan OFFLINE
Bryan
  • 10,926 posts
Posted Mon Aug 24, 2009 8:56 AM
I doubt it would break anything because as far as we know, the 6502 will always be oblivious to when the rising edge of /NMI happens and it would be very strange to rely on the /NMI dropping behavior for anything. Too bad Atari didn't catch this bug when they modified Antic with the extra refresh row for the XL machines.
Edited by Bryan, Mon Aug 24, 2009 9:06 AM.
#195 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Mon Aug 24, 2009 11:40 AM
Here's a fix that seems to work (swap 6502 with 65c02) with one jumper:
#196 Bryan OFFLINE
Bryan
  • 10,926 posts
Posted Fri Aug 28, 2009 9:09 AM
Well, I was reading the old 1976 datasheet on the 6502 and discovered this tidbit on page 51:
The /NMI signal must be low for at least two clock cycles for the interrupt to be recognized, whereupon new program count vectors are fetched. (shouldn't that be program counter?)
So, Atari followed the minimum requirement of the official spec and MOS didn't know about the bug.
#197 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Fri Aug 28, 2009 5:44 PM
Unknowingly they seem to have fixed it in some variations of the 6502.
#198 Bryan OFFLINE
Bryan
  • 10,926 posts
Posted Fri Aug 28, 2009 6:53 PM
Are you referring to your 65C02 test? The 65C02 is a totally reworked chip made years after the NMOS 6502 so that's not surprising.
#199 atariksi OFFLINE
atariksi
  • 5,337 posts
Posted Fri Aug 28, 2009 7:40 PM
I need to get my hands on some other variants of 6502 to try out...
#200 Rybags ONLINE
Rybags
    Gridrunner
  • 15,948 posts
Posted Fri Aug 28, 2009 8:10 PM
Do you have any Release Notes or other technical manuals for the 65C02 ? Maybe they have mention of it.
