Atari 800 Emulation in Windows 7/Vista
14 replies to this topic
#1 R.Cade OFFLINE
R.Cade
    Moonsweeper
  • 349 posts
Posted Sat Aug 8, 2009 9:11 AM
What are you guys using for modern OS's.   Atari800WinPlus 4.0 and 4.1 have screwed up colors in full-screen mode for me, and Atari800 SDL version complains about something video related.  Both work fine in Windows XP for me on the same PC.
#2 oky2000 OFFLINE
oky2000
  • 1,611 posts
Posted Wed Aug 12, 2009 5:28 PM
I use Win800plus 4.1, and 4.0 before, on Vista and it's fine with either, never had a problem with it (as far as that's possible on Microsoft bloatware ;) ). Maybe a graphics card driver update? Did you force XP drivers to install for Vista?
I have no interest in Win 7 so sorry can't help with that.
#3 Trooper OFFLINE
Trooper
    Dragonstomper
  • 979 posts
Posted Tue Sep 8, 2009 10:05 AM
Well I've had the same problem in W7 with screwed up colours in full screen mode. I have no solution but I have a workaround. Start A800WinPlus, Go into the taskmanager "processes" tab and shut down the "explorer" process, this will kill the "framework" of W7 and you can then turn off the taskmanager and alt-tab to the emulator and go into fullscreen mode. Works fine here. When you're done playing, bring up the taskmanager again and go to File/Run and put in explorer.exe presto, everything's back to normal.
#4 Avazee OFFLINE
Avazee
    Combat Commando
  • 5 posts
Posted Mon Oct 19, 2009 10:53 AM
I have the same problem, with Windows 7 and full-screen having distorted colors.  That workaround you mentioned is cool, but worrisome in that you have to kill the Windows 'kernel' process in order to get it working.  I hope someone fixes this issue!
#5 TwiliteZoner OFFLINE
TwiliteZoner
    Dragonstomper
  • 598 posts
Posted Thu Oct 22, 2009 9:42 AM
I was going to install 7 today. Have you tried the XP compatibility option?
#6 KiwiArcader OFFLINE
KiwiArcader
    Star Raider
  • 69 posts
Posted Thu Oct 22, 2009 12:15 PM
Same result. Even tried with a non-Aero enabled laptop and still no luck. Screen flashes at the edges and then a complete colour palette issue occurs. Bit of a pain if the author is no longer updating it as it is the best A800 emu I've come across to date.
#7 Daze OFFLINE
Daze
    Space Invader
  • 16 posts
Posted Sat May 1, 2010 3:37 PM
Same palette bug occurs with Atari800. Seems to be an SDL related full-screen bug with Windows 7. This also seems to occur with DOSBOX as well, which uses SDL too. Only option so far is to use Altirra which works fine in any display mode. Hopefully, SDL will be fixed at some point.
Hope that helps.
Edited by Daze, Sat May 1, 2010 3:42 PM.
#8 R.Cade OFFLINE
R.Cade
    Moonsweeper
  • 349 posts
Posted Fri May 28, 2010 1:17 PM
Yes, it does that in other emulators as well.  I just use Altirra now and no problems at all.  It's a nicer emulator, and still updated.
#9 Deteacher OFFLINE
Deteacher
  • 2,684 posts
Posted Sat Sep 18, 2010 3:26 PM
That's a pretty cool workaround.  The weird colors have been driving me batty and that works great.  I don't mind the extra step to turn explorer off and back on again.
Thanks for the tip!  :)  +1 Rep points for you!
Edited by Deteacher, Sat Sep 18, 2010 3:27 PM.
#10 wood_jl OFFLINE
wood_jl
  • 5,472 posts
Posted Sat Sep 18, 2010 4:00 PM
What are you guys doing about the aspect ratio, in full-screen mode?
One of the things that turns me off THE MOST about emulation - now that every blinkin' laptop and desktop monitor has gone "widescreen" is the damn emulated system screen is stretched in full screen on everything.  Damnit, I was some kind of sorry when everyone abandoned 4:3 displays.  If anything, I'd rather have "tall screen" for viewing more of a web page or PDF page.  I don't watch movies on my PC, nor do I intend to.
But I can't stand when it stretches things out to fill the screen.  I wish the emulators included an option to toggle on/off some vertical black bars on the sides, to emulate the proper (for classic systems) aspect ration on these friggin' wide screens.
#11 Trooper OFFLINE
Trooper
    Dragonstomper
  • 979 posts
Posted Mon Sep 20, 2010 7:27 AM
Glad to be able to help :)
#12 RKade OFFLINE
RKade
    Star Raider
  • 67 posts
Posted Fri Aug 19, 2011 4:36 PM
I signed into this site to say that I love everyone who suggested Altirra as I was banging my head against the wall for over a year... also, coincidentally, I've been calling myself RKade on forums for a decade now. That's all I wanted to say, I'm going back to fun.
#13 wood_jl OFFLINE
wood_jl
  • 5,472 posts
Posted Fri Aug 19, 2011 4:47 PM
Still wondering if people:
(1) Like playing in a little window (surrounded by a junky desktop) so they can see proper aspect ratio
or
(2) Play full-screen, with everything stretched and looking short/fat, in order to fill the widescreen (and you don't mind this)
or
(3) Is there an emulator that will "fullscreen" at the proper aspect ratio, by placing "black bars" (or whatever) at the sides of the widescreen, appropriately, to recreate the Atari's original aspect ratio.
Am I the only person who likes FULLSCREEN WITH PROPER ASPECT RATIO?  I never see anyone talk about it.  It's what the real Atari did.  It's what I'd like my emulator to do.  Damn "widescreen" PCs today have created this problem that doesn't seem to bother anybody else.   :? :? :? :? :? :?
#14 Kr0tki OFFLINE
Kr0tki
    Dragonstomper
  • 776 posts
Posted Sat Aug 20, 2011 3:44 AM
Well it bothers me, and it bothered so much that I've implemented a solution to the problem in Atari800 :-) Once you configure the aspect ratio of your monitor (Display settings->Video mode settings->Host display aspect ratio) and set the appriopriate method of screen stretching (Display settings->Video mode settings->Image aspect ratio set to Authentic), the display will have correct aspect ratio regardles of fullscreen resolution you choose.
Altirra has a similar option (View->Stretch Mode->Preserve Aspect Ratio).
#15 RKade OFFLINE
RKade
    Star Raider
  • 67 posts
Posted Sat Aug 20, 2011 5:44 PM
Altirra had that option as a default when I installed it.
