mimo Posted September 24, 2009 Share Posted September 24, 2009 Dug out my XF551 today, it has died in storage over the last 3 months:sad: Symptoms are: brief flash from the drive LED when turned on, Computer will not recognize that there is a drive connected. I have used my 1050 with the same computer/discs/sio cable/psu this afternoon and all is fine with that set up, so those possibles can be ruled out. Any ideas where a novice should start to look for the fault? (I have basic tools, multimeter, soldering iron, hammer etc) Cheers Quote Link to comment Share on other sites More sharing options...
+Stephen Posted September 24, 2009 Share Posted September 24, 2009 Dug out my XF551 today, it has died in storage over the last 3 months:sad: Symptoms are: brief flash from the drive LED when turned on, Computer will not recognize that there is a drive connected. I have used my 1050 with the same computer/discs/sio cable/psu this afternoon and all is fine with that set up, so those possibles can be ruled out. Any ideas where a novice should start to look for the fault? (I have basic tools, multimeter, soldering iron, hammer etc) Cheers Check the solder connections between the SIO connector and bottom of the PCB. These are almost guaranteed to break on every XF551. Stephen Anderson 1 Quote Link to comment Share on other sites More sharing options...
mimo Posted September 24, 2009 Author Share Posted September 24, 2009 Dug out my XF551 today, it has died in storage over the last 3 months:sad: Symptoms are: brief flash from the drive LED when turned on, Computer will not recognize that there is a drive connected. I have used my 1050 with the same computer/discs/sio cable/psu this afternoon and all is fine with that set up, so those possibles can be ruled out. Any ideas where a novice should start to look for the fault? (I have basic tools, multimeter, soldering iron, hammer etc) Cheers Check the solder connections between the SIO connector and bottom of the PCB. These are almost guaranteed to break on every XF551. Stephen Anderson Thanks for the quick reply, warming up the iron now:) Quote Link to comment Share on other sites More sharing options...
mimo Posted September 24, 2009 Author Share Posted September 24, 2009 Re-soldered and fixed. Wish all repairs could be that easy Thanks Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted September 26, 2009 Share Posted September 26, 2009 I always start with the hammer... not 100% successful mind Quote Link to comment Share on other sites More sharing options...
