"Use Full Editor"-button doesn't work.
29 replies to this topic
#1 e5frog OFFLINE
e5frog
    Moonsweeper
  • 416 posts
  • Good.
Posted Wed Sep 30, 2009 4:50 PM
I tried to edit a reply of mine and tried the "Use Full Editor"-button but nothing happens, it doesn't seem to be possible to remove an attachment in the other edit mode...
#2 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,745 posts
Posted Wed Sep 30, 2009 5:22 PM
Is anyone other than me able to successfully use the "Full Editor" when editing a post?
..Al
#3 chriswhit OFFLINE
chriswhit
    Moonsweeper
  • 415 posts
Posted Wed Sep 30, 2009 6:00 PM
  Albert said this might work in a post that answered a few of my questions  This was a bug in the forum software that has since been fixed. However, your browser may have cached the "broken" Javascript. You will need to clear your browser's cache and/or force a refresh of the page and that should remedy the issue.
#4 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 22,652 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Wed Sep 30, 2009 6:04 PM
I cleared my cache and hit Ctrl + F5, but it still doesn't work for me using Firefox.
#5 shadow460 OFFLINE
shadow460
    Gunslinger
  • 16,409 posts
  • *bink* Good Shot
Posted Wed Sep 30, 2009 6:11 PM
I tried and the full editor automatically showed up after clearing the browser cache.  That's odd, though, because on this post, the quick edit showed up and the full editor doesn't work.  Hmm...
Edited by shadow460, Wed Sep 30, 2009 6:12 PM.
#6 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,745 posts
Posted Wed Sep 30, 2009 6:23 PM
If it goes to the full editor immediately, that means the Javascript is not being processed on the page.  If the full-editor button isn't working (and you see the "quick" editor), the Javascript is working, but part of it is broken.  :)
Version 3.0.4 of the software should be out in a few days.  Invision did fix this issue with this new release, but I already applied the fix here.  So I'm at a loss as to why it's not working.  What makes it worse is it works absolutely fine for me.
I will investigate this soon--this is a pretty hectic week for me as I have a ton of work I am trying to catch up on.
..Al
#7 e5frog OFFLINE
e5frog
    Moonsweeper
  • 416 posts
  • Good.
Posted Thu Oct 1, 2009 5:19 AM
I restarted Mozilla FF, cleared the cache and reloaded Atariage.com, no difference. "Use Full Editor"-button still does nothing. I'm using Mozilla Firefox 3.5.3.
I tried Internet Explorer 8.0.6001.18702 and it doesn't work there either, it reports an error on the page after pressing the "Use Full Editor"-button.
This is the error, sorry, it's in Swedish but I think the error is probably understandable anyway:
Quote
Detaljerad information om felet på webbsidan
Användaragent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; AskTB5.2)
Tidsstämpling: Thu, 1 Oct 2009 11:16:44 UTC
Meddelande: Object required
Rad: 1105
Tecken: 1
Kod: 0
URI: http://www.atariage....e/1/ipb.lang.js
#8 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,745 posts
Posted Thu Oct 1, 2009 6:42 AM
Thanks for the additional information--going to try it with a few different browsers and see if I can get one of them to fail.  If I can, then it should be easier to track down.
..Al
#9 Trooper OFFLINE
Trooper
    Dragonstomper
  • 979 posts
Posted Thu Oct 1, 2009 6:55 AM
I've had the same problem using Google Chrome "solved" it by changing to the Lo-Fi version which gave me access to the full editor.
#10 carmel_andrews OFFLINE
carmel_andrews
  • 13,025 posts
Posted Tue Oct 6, 2009 6:43 PM
Just get 'error on page'...perhaps there's a 'posting' bug when using it for editing first post
#11 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,745 posts
Posted Tue Oct 6, 2009 6:45 PM
Can you give me more details?  Which specific post were you trying to edit?  What browser are you using?  Did you use the quick editor (the one that appears immediately after you click "Edit") or the full editor?
Thanks,
..Al
#12 carmel_andrews OFFLINE
carmel_andrews
  • 13,025 posts
Posted Tue Oct 6, 2009 7:13 PM
Thanks,
..Al
A little funny, a the older AA'er .....it should have been A little funny, for the older AA'er
mainly i.e version 8 and FF higher then 3 10...the edit feature has been removed anyway
#13 Tempest OFFLINE
Tempest
    Founder of the AA Inquisitorial Squad
  • 21,244 posts
  • Misusing AA resources since 2001
Posted Tue Oct 6, 2009 7:32 PM
Full editor works just fine for me.
Tempest
#14 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,745 posts
Posted Tue Oct 6, 2009 7:33 PM
It works fine for me also.  I'm not sure why it doesn't work for some people.  I will spend some time investigating soon.  A new version of the forum software was released this morning and I will be installing it in a few days.
..Al
#15 gamerz OFFLINE
gamerz
  • 1,338 posts
Posted Tue Oct 6, 2009 7:57 PM
Just to let you know, it doesnt work for me either.
#16 Chickybaby OFFLINE
Chickybaby
  • 6,156 posts
Posted Tue Oct 6, 2009 8:12 PM
I don't know what happens when a member tries to edit their post after the editing time period is over. Perhaps it was just too late to edit it?
I have to double click everything using IE 7 and it's a real annoyance.
#17 CPUWIZ OFFLINE
CPUWIZ
    Rarity 11
  • 27,016 posts
  • Cartridge Recycler
Posted Tue Oct 6, 2009 11:04 PM
Quit using Internet Exploder. :P
www.mozilla.org
#18 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,745 posts
Posted Wed Oct 7, 2009 7:33 AM
www.mozilla.org
I agree, but that's still pretty odd.  I haven't heard of anyone ever experiencing that particular issue (having to double-click all links).  I did look at Invision's bug database last night and couldn't find any mention of this.  I have IE7 installed in one of my Windows virtual machines and it seems to work fine in this regard.
..Al
#19 Chickybaby OFFLINE
Chickybaby
  • 6,156 posts
Posted Wed Oct 7, 2009 9:50 AM
http://www.atariage....-forum-trouble/
Can't use Mozilla/Firefox. Won't run on this version of Vista 64bit or isn't compatible with AOL DSL (that I don't have to monetraily pay for) and crashes everything. I love how people alwasy say to use something else but don't take into consideration that some people can't for whatever reason.
#20 vdub_bobby OFFLINE
vdub_bobby
  • 5,831 posts
  • Boom bam.
Posted Fri Oct 9, 2009 3:00 PM
Nor me.  Full Edit button does nothing.  I'm using Firefox 3.something with Windows XP.
#21 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,745 posts
Posted Fri Oct 9, 2009 3:01 PM
I'm going to update the forum software today.  If the Full Editor button still doesn't work for people after that, I'll raise holy hell about it.
..Al
#22 vdub_bobby OFFLINE
vdub_bobby
  • 5,831 posts
  • Boom bam.
Posted Fri Oct 16, 2009 12:24 PM
..Al
Works for me now. ;)  Thanks!
#23 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,745 posts
Posted Fri Oct 16, 2009 12:47 PM
Good, glad to hear that.  Anyone else still having this problem?
..Al
#24 aftermac ONLINE
aftermac
  • 2,347 posts
Posted Fri Oct 16, 2009 12:52 PM
..Al
I just tested it on the free games thread in the Marketplace and it works for me! Thanks, Al!
#25 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,745 posts
Posted Fri Oct 16, 2009 12:58 PM
Excellent, thanks.  :)
..Al
