The Official "Super Expansion Module" Thread
896 replies to this topic
#701 Pixelboy OFFLINE
Pixelboy
  • 7,459 posts
Posted Mon Apr 2, 2012 8:15 PM
The only risk in this case is if the software enable the RAM by mistake.
Could that happen with legacy ADAM software, or even with CV carts?
#702 opcode OFFLINE
opcode
  • 3,741 posts
  • Bringing new life to your ColecoVision!
Posted Mon Apr 2, 2012 8:21 PM
I am using I/O port 53h for RAM enable. That shouldn't be used by any CV game, as all the CV I/O is limited to 80h-FFh. As for the ADAM, I checked with the ADAMcon group, and according to them 50h-53h is the only I/O space not used by any known ADAM device.
But there is always some risk involved... though the risk is limited to those with an ADAM.
Edited by opcode, Mon Apr 2, 2012 8:23 PM.
#703 NIAD OFFLINE
NIAD
  • 5,648 posts
Posted Mon Apr 2, 2012 9:41 PM
Ever since I plugged in and turned on my fist ADAM Computer on X-Mas day '83, I've been running that "gauntlet of risk" quite successfully I might add.
#704 rga321 OFFLINE
rga321
    Star Raider
  • 99 posts
Posted Wed Apr 4, 2012 11:01 AM
I want to give Opcode a HUGE thank you for dedicating so much of his time and talents to these projects. They are both exciting for us all to follow along with and the anticipation of actually being able to play them is a GIANT bonus! :thumbsup: thanks Opcode
John M.
Edited by rga321, Wed Apr 4, 2012 11:01 AM.
#705 opcode OFFLINE
opcode
  • 3,741 posts
Posted Wed Apr 4, 2012 12:40 PM
Thanks, John.
Now... how about someone putting together a New England Classic Gaming gathering any day. :)
#706 rga321 OFFLINE
rga321
    Star Raider
  • 99 posts
Posted Wed Apr 4, 2012 12:47 PM
Sounds fun, maybe we can host it here? http://www.mohegansu...eway/index.html
#707 VectorGamer OFFLINE
VectorGamer
    Go Sleep In the Cold
  • 12,763 posts
  • \m/
Posted Wed Apr 4, 2012 3:10 PM
Thanks, John.
It's called Funspot - happens the first weekend of June every year. I'll be there this year if anyone wants to kill me...
#708 opcode OFFLINE
opcode
  • 3,741 posts
Posted Wed Apr 4, 2012 3:22 PM
Isn't Funspot open the whole year? What happens in the first weekend of June?
#709 128Kgames OFFLINE
128Kgames
    Dragonstomper
  • 622 posts
  • Victory is mine! I am the Worrior!
Posted Wed Apr 4, 2012 6:36 PM
Sweet! We need more East Coast shows!
#710 jblenkle OFFLINE
jblenkle
  • 3,913 posts
Posted Wed Apr 4, 2012 6:52 PM
OK, I have a question...if there eventually are two types of this device, I would prefer to hook it up to my ADAM....but...
I already have two devices plugged into my ADAM's side port via a special 3-connector cable - the Midi-Mite and a Speech Synthesizer. The cable though has room for one more device. Will the SGM plug into the remaining connector? Or will its design prevent this?
You can see my remaining "third" connector in the picture.
Yes, I thought of disabling the SGM RAM by default and enabling it by software after checking that no RAM was present. That would prevent bus contention by the RAMs, but stil wouldn't be enough. We would still have contention in the CV_memory_decoder_disable line.
Any way to have a switch to turn on/off? Or if you had the memory turned on and plugged it into the adam you would cause damage?
Placing a switch on both the RAM_enable and CV_mem_decoder_disable lines would work. However if the user turn the switch on by mistake and plug the SGM into an ADAM, that may cause damage to memories or something else.
I think it is too risky. Some may say that having two different colors can't guarantee that someone isn't going to plug the black version on an ADAM. That is true, but at least we can place a warning label in the case about that. It is less probable that someone is going to plug the black version on an ADAM by mistake if there is a warning label like "NEVER EVER USE WITH AN ADAM" than, let's say, use a black module with a switch on a CV then forget to turn the switch off and plug it on an ADAM.
#711 opcode OFFLINE
opcode
  • 3,741 posts
Posted Wed Apr 4, 2012 7:10 PM
I agree. Even if it was something smaller, I would attend for sure.
#712 AtariBrian ONLINE
AtariBrian
  • 3,035 posts
Posted Wed Apr 4, 2012 7:21 PM
cleveland in june :grin:
#713 opcode OFFLINE
opcode
  • 3,741 posts
I believe that with evg2000's suggestion I have pretty much figured out a way to have a single device for both CV and ADAM. It is now a matter of implementing and testing the solution with the rev C board. I am just waiting to discuss a few things with Luc this weekend regarding the controller port before finalizing the design.
About your 3-connectors cable, I believe the SGM should work fine as long as there aren't other devices using I/O ports 50h-53h, and supposing that the cable can properly supply the necessary current to power all 3 devices. A test can be arranged, in case you agree.
Edited by opcode, Wed Apr 4, 2012 7:28 PM.
#714 opcode OFFLINE
opcode
  • 3,741 posts
Posted Wed Apr 4, 2012 7:30 PM
Ohio is too far away from where I live.... :(
#715 VectorGamer OFFLINE
VectorGamer
  • 12,763 posts
  • \m/
Posted Wed Apr 4, 2012 7:53 PM
The annual Funspot arcade tournament. Gamers can play in the tournament all weekend and there can be an "after hours" in a hotel room with beers and console gaming.
#716 opcode OFFLINE
opcode
  • 3,741 posts
Posted Wed Apr 4, 2012 8:06 PM
Sounds like fun. Too bad that I am returning to the US on June 1st, so the chances I can go are near zero. :(
#717 jblenkle OFFLINE
jblenkle
  • 3,913 posts
Posted Wed Apr 4, 2012 8:57 PM
Well, being that I'm hardware ignorant, I don't know what I/O ports the midi and speech synthesizer use. But although they are all plugged in to the same cable, they do not function at the same time although I imagine they both draw power. Although this cable is a recent purchase for me (within the last two years), it is the same type someone made back in the 80s so you could have the convenience of not having to plug and unplug multiple devices into the side port and could just leave them all plugged in at once. My desk where my ADAM is doesn't have a lot of room on the side, so it makes things a heck of a lot easier.
It's not a real big issue for me, especially if there is a work-around so there will only be one model of the SGM. My ADAM and CV sit within two feet of one another, but I use the ADAM a lot more than the ColecoVision.
Edited by jblenkle, Wed Apr 4, 2012 8:58 PM.
#718 NIAD OFFLINE
NIAD
  • 5,648 posts
Posted Wed Apr 4, 2012 8:59 PM
The only question here is whether there will be enough power provided by the Expansion Bus to supply all three devices at the same time. If you have an ADAM AutoDialer, you can plug that in to the last/open connector on that Multi-Unit Ribbon Adapter (is that the Eve Electronics version?) and test to see how that work. I would assume that the power requirements for the S.G.M. would be more than the ADAM AutoDialer.... especially with an added Game/Joystick Port like Opcode is thinking of adding.
#719 NIAD OFFLINE
NIAD
  • 5,648 posts
Posted Wed Apr 4, 2012 9:02 PM
You need to sell me you Eve SS-CC (Speech Syn/Clock Calendar) Unit to free up some room there. :-D
Pretty sure that the Port Address that Opcode will be using has never been used by any other ADAM hardware device, so you should be fine.
Edited by NIAD, Wed Apr 4, 2012 9:03 PM.
#720 jblenkle OFFLINE
jblenkle
  • 3,913 posts
Posted Wed Apr 4, 2012 11:01 PM
Ha! I'm still kicking myself for selling my original one back in the late 80s....
#721 jblenkle OFFLINE
jblenkle
  • 3,913 posts
Posted Wed Apr 4, 2012 11:10 PM
No, this isn't the Eve Multi Ribbon Adapter...is that who made it? Couldn't remember. This is one I had custom made by someone on the ADAM Mailing LIst. Can't remember who made it for me, but as I said...the way my ADAM is situated on my one desk, the side port is very hard to get to. There's only about a four-inch clearance so it's easier just to leave my midi-mite and speech synthesizer plugged in rather than trying to constantly plug and unplug devices.
I don't have an ADAM Auto Dialer, but it strikes me back in the day that there were some devices you couldn't plug into the ribbon cable because of the way they were constructed. THey actually need the card edge sticking out so it can be plugged into the female plug on the ribbon adapter.
In fact, I think the ribbon adapter can only be used for non-Coleco made items. The 2600 module certainly won't plug into it and if memory serves me, the auto dialer wouldn't either.
#722 opcode OFFLINE
opcode
  • 3,741 posts
Posted Thu Apr 5, 2012 2:13 PM
Ok, so I would like to give an update where the SGM stands today, and other Opcode related projects for the year.
First the SGM: We have the case project done, we are ready to order the mold, unless we decide to include a controller port (more about that next).
We have the Rev B board ordered, Rev C designed (with the ADAM compatibility stuff in), and I have the option to produce Rev D, in case I decide to include the controller port. Now, I am going to spend the weekend discussing that with Luc, so let's see.
Packaging: we have the logos and name plate done, Dale is now working on the manual, so we are doing steady progress.
I hope to start beta in June, and I was thinking that it may be possible to go into manufacturing by August after all. But that is going to depend on if we don't find any major problems during beta.
About games:
I will resume DKA in June. Assuming 3 more months of development with a couple of extra months of beta, we should be all set to start selling in December.
3rd Party:
Rollerball (the SGM game) will be delivered next week. After that I hope to deliver 2 new Pixelboy SGM games (1 is actually done) and fix a 3rd one by June. Then I have 2 more Pixelboy games to deliver and possibly a 3rd one to fix or add some stuff before the year is over. So that would be a total of 6 SGM games this year.
Opcode Club:
Hopefully we will start in June. Waiting for word from my editor....
So far so good...
#723 Pixelboy OFFLINE
Pixelboy
  • 7,459 posts
Posted Thu Apr 5, 2012 2:30 PM
3rd Party:
Just in case anyone is wondering, I believe he's talking about The Black Onyx. :)
#724 opcode OFFLINE
opcode
  • 3,741 posts
Posted Fri Apr 6, 2012 8:22 PM
Got the first SGM manual proof from Dale today. Looks super cool, I think a lot of you will pleasantly surprised. It is still missing some of the illustrations, though. Those will be included once I have decide if the controller port is a go or not.
Now to the game catalog...
#725 Raccoon Lad OFFLINE
Raccoon Lad
    Moonsweeper
  • 473 posts
  • I Like Pixels
Posted Sat Apr 7, 2012 12:13 AM
Hopefully changing the game to give you more experience points from killing monsters.
I played a ways into the SG-1000 translation a while back, and ended up being able to buy all the best weapons/armor for my party, but getting totally destroyed in the later dungeons.
