magic_gun Posted October 27, 2009 Share Posted October 27, 2009 (edited) hi friends, I had a dream a long time,a ATARI st computer conversion to pc and finally, me and my team to do so, and we wanted to share with you detailed pictures and my other projects for www.atariturkiye.com best regards gunhan.poyraz @ windowslive.com gunhan@atariturkiye.com www.atariturkiye.com for detailes gunhan.poyraz @ windowslive.com gunhan@atariturkiye.com Edited October 27, 2009 by magic_gun Quote Link to comment Share on other sites More sharing options...
Paolo Posted October 28, 2009 Share Posted October 28, 2009 Wait! You mean you *killed* an Atari Computer in order to Frankensteint it into a PC? AAAAAAaaaaahhhhhhhh!!!!! By the way, will you set up a smaller version with English text? Thank you for sharing. Quote Link to comment Share on other sites More sharing options...
Jet-X Posted October 28, 2009 Share Posted October 28, 2009 Hell I thought it'd be fun to shoehorn a MAME PC or other into a Mega ST case. Quote Link to comment Share on other sites More sharing options...
mimo Posted October 28, 2009 Share Posted October 28, 2009 (edited) how about an ST into an Amiga case:twisted: not mine, and it is an early work in progress, all the gaps will be filled Edited October 28, 2009 by mimo Quote Link to comment Share on other sites More sharing options...
Antnee Posted October 29, 2009 Share Posted October 29, 2009 Funny, because I was just thinking about finding a toasted ST and seeing if I could squeeze a laptop board in and get the KB working. Was actually thinking that the Falcon case might have been better as I could put a floppy/card-reader in without having to cut anything out. My plan was to put USB ports under the keyboard in place of the D15 ports, possibly where the analogue ports are too. Do I have the time at the moment though? I wish! Quote Link to comment Share on other sites More sharing options...
oky2000 Posted November 4, 2009 Share Posted November 4, 2009 Well it looks better than the other PC in an ST case mode which doesn't even have the proper ST keyboard. Quote Link to comment Share on other sites More sharing options...
S1500 Posted November 4, 2009 Share Posted November 4, 2009 I still someday want to make a standard PC case out of a TI-99/4A's Peripheral Expansion box, and recycle as many parts as possible. Quote Link to comment Share on other sites More sharing options...
oky2000 Posted November 5, 2009 Share Posted November 5, 2009 I still someday want to make a standard PC case out of a TI-99/4A's Peripheral Expansion box, and recycle as many parts as possible. I'm going the opposite way, I have a 5inch colour CRT tube I plan to make an Atari equivalent of the SX-64 out of one day with an XEGS system Quote Link to comment Share on other sites More sharing options...
+save2600 Posted November 5, 2009 Share Posted November 5, 2009 I still someday want to make a standard PC case out of a TI-99/4A's Peripheral Expansion box, and recycle as many parts as possible. Now that would be purty! Quote Link to comment Share on other sites More sharing options...
S1500 Posted November 5, 2009 Share Posted November 5, 2009 The problem I would run into is proper grounding and not short circuiting anything in said case. I'm no expert on grounding stuff. It has a full 2x 5.25 inch bay for putting in drives of my choice. The power cord connector is the same as it always has been on PCs. The card slots for the TI will need to be Dremel'd out as they aren't even close to a match for standard "PC" card slots. I wonder if I can just gut out the heavy transformer on the left side & stick in a modern day power supply. Switch out the noisy fan for a modern one. The power switch will have to be switched out for a soft switch. Added difficulty: The PEB is built like a Sherman tank. Ah fun fun fun. Sure, I won't be able to read TI-994/A disks anymore, but think of the retro factor! Quote Link to comment Share on other sites More sharing options...
+save2600 Posted November 5, 2009 Share Posted November 5, 2009 (edited) For sure! And grounding is simple. You can buzz it out with your DMM or know where the ground spots are (on a circuit board, usually the largest area(s) where you see the most tin. You could use CPU board risers to keep things from shorting out in between the case and the rest of any boards. Grounding termination is almost universally at the point where you'd mount the supporting screws to the case. Edited November 5, 2009 by save2600 Quote Link to comment Share on other sites More sharing options...
Retro Rogue Posted November 5, 2009 Share Posted November 5, 2009 (edited) I still someday want to make a standard PC case out of a TI-99/4A's Peripheral Expansion box, and recycle as many parts as possible. I'm going the opposite way, I have a 5inch colour CRT tube I plan to make an Atari equivalent of the SX-64 out of one day with an XEGS system You're talking about the Atari 65XEP. Edited November 5, 2009 by wgungfu Quote Link to comment Share on other sites More sharing options...
magic_gun Posted November 30, 2009 Author Share Posted November 30, 2009 Our latest hardware atari 1040 st Thank you for the interest; RETRO_Atari 1040 ST With ATARI wireless mouse ( orginally microsoft laser mini mouse in atari mouse case) CUTE......and Powerfull computer specs.. zotac 630i _MINI INTEL D 660 P4 Please check cpu on the net_ http://www.smartoffice.gr/cpu_intel_pd660.htm 3,6GHz d660 cpu Power Mode O_Clock 4,79GHz 2 GB RAM INTERNAL PSU 450W Ge-Force 7100 6 ch hd SOUND 320 IDE WIRELESS INTERNET.802.11g max 54Mbps WIRELESS MOUSE (two button) ORIGINAL ATARI. ST STYLE FREE 4 USB PORT colling methode : air and liquid ( izo-alcholl), Internal temperature of 72 degrees after 2 hours from play the game (call of duty) Please Check all photo our web site retro mod section http://www.atariturkiye.com _______________________________________________________________________________________________________________ Thank you for your request and questions, Below you will find some explanation **** We have got a Microsoft Open Licence Program (MOLP) There isnt any licence issue for this PC Otherwise We advice to "PARDUS 2009" OS We have got a Gnu_Open source_ Please Check on the net. http://www.pardus.org.tr/ we thing so Visiual option is better than Windows 7 ***** You can play All Doom series,Call Of Duty,etc. Please Check mainboard. ATARI ST _Retro_ is a "size big" for games. This unit is for professional PC user. We can create also for games _lower version_ AMIGA retro. ****** Also we get a lot of MIDI port and software questions. You can use all EMU program with this unit. Of course It is a PC. But,attention! There is no MIDI port on this device You can use "Sound Blaster External" unit For MIDI option. I have no experiment about "Atari Notator" or others. Thank you very much. atariturkiye team.. Quote Link to comment Share on other sites More sharing options...
Thorsten Günther Posted November 30, 2009 Share Posted November 30, 2009 Our latest hardware atari 1040 st How did you attach the ST keyboard to the PC mainboard - I have not yet found a ready-to-use conversion kit or the like. Was it your own invention? I was thinking of a ST case mod like this myself, but asI was unable to keep the case outside unmodified, I postponed it. Thorsten Quote Link to comment Share on other sites More sharing options...
magic_gun Posted November 30, 2009 Author Share Posted November 30, 2009 ST to PC keyboard , this project involved the conversion up to us and finally we did it was the subject We did not find any ready way There are two ways that we believe . a) the original keyboard cut and cut to fit into the matrix pc ... b) st keyboard signals with a mc pc to convert to the format understood http://www.atariturkiye.com/modifiyeler-retro-mod/49-atari-st-modifiye.html and both solutions produced I am here to help friends who want to for technical info gunhan@atariturkiye.com for sales conversion kits kerem@atariturkiye.com best regards Quote Link to comment Share on other sites More sharing options...
blackpanther Posted November 30, 2009 Share Posted November 30, 2009 What was the offers you received? http://cgi.ebay.co.uk/Atari-1040-ST-With-ATARI-wireless-mouse-RETRO_W0QQitemZ180436121108QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a02d4b614#ht_1817wt_1165 Quote Link to comment Share on other sites More sharing options...
Fletch Posted December 1, 2009 Share Posted December 1, 2009 What was the offers you received? http://cgi.ebay.co.uk/Atari-1040-ST-With-ATARI-wireless-mouse-RETRO_W0QQitemZ180436121108QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a02d4b614#ht_1817wt_1165 $5000? Are you friggin insane? Who the frick is going to touch that? What a world. Quote Link to comment Share on other sites More sharing options...
magic_gun Posted December 1, 2009 Author Share Posted December 1, 2009 What was the offers you received? http://cgi.ebay.co.uk/Atari-1040-ST-With-ATARI-wireless-mouse-RETRO_W0QQitemZ180436121108QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a02d4b614#ht_1817wt_1165 $5000? Are you friggin insane? Who the frick is going to touch that? What a world. Thank you for the interest; SELLING PRICE WILL BE 100% OF DONATION ( UNICEF etc. ) Quote Link to comment Share on other sites More sharing options...
Fletch Posted December 1, 2009 Share Posted December 1, 2009 Well, that is nice. Good luck. What was the offers you received? http://cgi.ebay.co.uk/Atari-1040-ST-With-ATARI-wireless-mouse-RETRO_W0QQitemZ180436121108QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a02d4b614#ht_1817wt_1165 $5000? Are you friggin insane? Who the frick is going to touch that? What a world. Thank you for the interest; SELLING PRICE WILL BE 100% OF DONATION ( UNICEF etc. ) Quote Link to comment Share on other sites More sharing options...
