Wrathchild Posted April 8, 2014 Share Posted April 8, 2014 How are people 'preparing' graphics/sprites for inclusion in their sources when targeting the VBXE? If you are editing a bitmap with sprite tiles then is this best pre-processed in some way? I've seen MADS macros in the past that use the ability to load bytes from a file (given and offset and length) and these then use their own calculations to adjust the offset for the y-increments. The resulting data can then be output to another file that can then be included in main source. Or is it easier if the original bitmap simply loaded into the VBXE's memory and then the blit function is then able to copy the sprites out directly? Does the A8 or the VBXE do the offset calc's in this respect? Any tips on masking? Does this depend on the VBXE output is overlaying the A8's background or a background also rendered by the VBXE? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 8, 2014 Author Share Posted April 8, 2014 (edited) Gimp can output graphics as raw data, omitting the palette and header from 8-bit BMP, I think I used that for Moon Cresta. Masking - the nature of the blit is that you're dealing with a byte per pixel except in the hires mode, so pixel masking isn't required. Then you just use the blit mode where only nonzero data is actually written so anything that needs to show through the transparent area is preserved. With Moon Cresta, only the sprites + bullets are VBXE generated, the star bg is Antic F with attribute map giving the colours. The erase phase for the sprites is to simply wipe them entirely. Works in this instance since they're the only thing VBXE displays but of course a different course of action would be needed in the case of something that required save/restore operations. Re calculations - Pacmanplus wrote the original on 7800 to only use 256 pixels across which easily translates into narrow mode for VBXE/Antic. IIRC there is a bit of manual calculation going on with the VBXE conversion but it's only simple bitshifts. Since VBXE has plenty of RAM (albeit easily used up quickly) if you really wanted you could do a 320 pixel game and have 512 byte stepping between scanlines which would ease the pain of address calculations. All depends how many objects you're moving around. Edited April 8, 2014 by Rybags Quote Link to comment Share on other sites More sharing options...
Aking Posted April 8, 2014 Share Posted April 8, 2014 Gimp can output graphics as raw data, omitting the palette and header from 8-bit BMP, I think I used that for Moon Cresta. Masking - the nature of the blit is that you're dealing with a byte per pixel except in the hires mode, so pixel masking isn't required. Then you just use the blit mode where only nonzero data is actually written so anything that needs to show through the transparent area is preserved. With Moon Cresta, only the sprites + bullets are VBXE generated, the star bg is Antic F with attribute map giving the colours. The erase phase for the sprites is to simply wipe them entirely. Works in this instance since they're the only thing VBXE displays but of course a different course of action would be needed in the case of something that required save/restore operations. Re calculations - Pacmanplus wrote the original on 7800 to only use 256 pixels across which easily translates into narrow mode for VBXE/Antic. IIRC there is a bit of manual calculation going on with the VBXE conversion but it's only simple bitshifts. Since VBXE has plenty of RAM (albeit easily used up quickly) if you really wanted you could do a 320 pixel game and have 512 byte stepping between scanlines which would ease the pain of address calculations. All depends how many objects you're moving around. @rybags have you checked the incompatibility between last version of moon cresta vbxe and ultimate 1 mb resulting in corrupted starfield ? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 8, 2014 Author Share Posted April 8, 2014 No... my system has Ultimate 1 Meg also. I've not looked at the game for some time. There have been problems with the starfield along the way, I had thought they'd been ironed out. Quote Link to comment Share on other sites More sharing options...
Aking Posted April 8, 2014 Share Posted April 8, 2014 No... my system has Ultimate 1 Meg also. I've not looked at the game for some time. There have been problems with the starfield along the way, I had thought they'd been ironed out. previous build had less colors, but a perfect starfield Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted May 29, 2015 Share Posted May 29, 2015 Apologies if this is already covered: If someone has VBXE installed what memory addresses would a "normal" non-VBXE boot game need to avoid to prevent conflicts? Quote Link to comment Share on other sites More sharing options...
Joey Z Posted May 29, 2015 Share Posted May 29, 2015 don't mess with D6XX and for normal GTIA/ANTIC you should use the first set of addresses within the address blocks for those chips I think. 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 30, 2015 Author Share Posted May 30, 2015 There's D7xx install as well. Programs shouldn't mess with those addresses anyway, there's no need on standard hardware and those addresses are also used by some other expansions like hard drives. GTIA addresses - any write to addresses $D080-$D0FF causes a soft-reset of VBXE, ie all screen overlays disabled, disable VBXE Ram overlay to Antic/6502. Allows for normal machine restoration when the OS warmstart routine is called either by user pressing Reset or if called by software. Antic addresses - same as a normal machine. 1 Quote Link to comment Share on other sites More sharing options...
OrionOregon105 Posted March 25, 2020 Share Posted March 25, 2020 that file "showpic.bas" doesn't work in Altirra 3.10+ did someone corrected that??????????????????????????????????? Quote Link to comment Share on other sites More sharing options...
