e1will Posted August 4, 2010 Author Share Posted August 4, 2010 Just a teaser pic of the title screen. Haven't got all the flicker issues worked out yet but I'm not conceding defeat just yet. --Will 1 Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 4, 2010 Share Posted August 4, 2010 Just a teaser pic of the title screen. Haven't got all the flicker issues worked out yet but I'm not conceding defeat just yet. --Will Lookin' good! Conceding defeat is not an option! Michael Quote Link to comment Share on other sites More sharing options...
Corby Posted August 9, 2010 Share Posted August 9, 2010 Just a teaser pic of the title screen. Haven't got all the flicker issues worked out yet but I'm not conceding defeat just yet. --Will Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted August 10, 2010 Share Posted August 10, 2010 I'm toying with the idea of writing a Super Pac-Man conversion for the 2600. Can someone with a Harmony cartridge or similar setup give this a test on real hardware and tell me how bad the flicker is? It looks OK in Stella if the phosphor effect is enabled (Alt-P) but it looks horrible if it isn't.I suggest using Stella in OpenGL mode with vsync enabled and phosphor mode turned off. On my system at least, this more accurately simulates what you'll see on a real system (a quite irritating flicker, in this case). The phosphor effect is really meant to make things nicer on a computer monitor, and it has no relation to how things look on a real system (ie, it makes things look better than they really are). You know that Stella's Phosphor Effect has an adjustment other than on/off, right? Check the docs; you can set it anywhere from 0 to 100%. There's gotta be a setting in that range that will come very close to duplicating the appearance of a real VCS on a CRT -- run side-by-side flicker tests with a cart and binary of a known flickery game such as Pac-Man or Lady Bug to find the best value. Quote Link to comment Share on other sites More sharing options...
e1will Posted August 10, 2010 Author Share Posted August 10, 2010 ou know that Stella's Phosphor Effect has an adjustment other than on/off, right? Check the docs; you can set it anywhere from 0 to 100%. There's gotta be a setting in that range that will come very close to duplicating the appearance of a real VCS on a CRT -- run side-by-side flicker tests with a cart and binary of a known flickery game such as Pac-Man or Lady Bug to find the best value. Yup. My problem is that this game has the same flicker (30Hz) as Asteroids and Yars' Revenge did, but seems to look worse, at least in emulation, no matter what settings I've tried. So right now I'm saving up for a Harmony cart, so I can see exactly what the deal is on real hardware. --Will Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 10, 2010 Share Posted August 10, 2010 ou know that Stella's Phosphor Effect has an adjustment other than on/off, right? Check the docs; you can set it anywhere from 0 to 100%. There's gotta be a setting in that range that will come very close to duplicating the appearance of a real VCS on a CRT -- run side-by-side flicker tests with a cart and binary of a known flickery game such as Pac-Man or Lady Bug to find the best value. Yup. My problem is that this game has the same flicker (30Hz) as Asteroids and Yars' Revenge did, but seems to look worse, at least in emulation, no matter what settings I've tried. So right now I'm saving up for a Harmony cart, so I can see exactly what the deal is on real hardware. --Will I usually start with a phosphor setting of 50%, then turn the phosphor effect off and on repeatedly to see how well the blended picture (phosphor on) matches the unblended picture (phosphor off). Then I try increasing the phosphor setting as needed until the blended and unblended pictures look as close to each other as possible. Unfortunately, the hues and luminances of the two colors being blended can affect the outcome, so a setting that works for one set of colors might not work as well for another set of colors, which means you need to find a good average. And then there's the fact that the flickering will probably look slightly different on a TV than on a computer monitor. Michael Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted August 10, 2010 Share Posted August 10, 2010 And then there's the fact that the flickering will probably look slightly different on a TV than on a computer monitor. What does flickering look like on the newer TV's (LCD, plasma's). I've only ever played a 2600 on a CRT, where the phosphor can blend. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 11, 2010 Share Posted August 11, 2010 And then there's the fact that the flickering will probably look slightly different on a TV than on a computer monitor. What does flickering look like on the newer TV's (LCD, plasma's). I've only ever played a 2600 on a CRT, where the phosphor can blend. I think it's going to depend on the TV. My Samsung 1080p HD LCD TV doesn't do flickering per se, because it converts the 2600's 240p screen into a 480i screen, displaying every two consecutive 240p frames interleaved with each other. As a result, flickering two solid colors together looks better than flickering two interleaved colors together. For example, on an old CRT TV, flickering two frames that alternate between red and blue lines as follows will produce the best effect: frame 1: red line blue line red line blue line etc. frame 2: blue line red line blue line red line etc. result: red line flickered with blue line blue line flickered with red line red line flickered with blue line blue line flickered with red line etc. But on my LCD TV, it looks like this: red line (from frame 1) blue line (from frame 2) blue line (from frame 1) red line (from frame 2) red line (from frame 1) blue line (from frame 2) blue line (from frame 1) red line (from frame 2) etc. On the other hand, I get a better result on my LCD TV by doing it this way: frame 1: red line red line red line red line etc. frame 2: blue line blue line blue line blue line etc. result: red line (from frame 1) blue line (from frame 2) red line (from frame 1) blue line (from frame 2) red line (from frame 1) blue line (from frame 2) red line (from frame 1) blue line (from frame 2) etc. But if I do that with an old CRT TV, it does this: result: red line flickered with blue line red line flickered with blue line red line flickered with blue line red line flickered with blue line etc. It might seem like this should be the same as flickering the alternating red and blue lines on a CRT TV, but the alternating lines make the flickering less apparent, whereas flickering solid colors makes the flickering more apparent. Michael Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted August 11, 2010 Share Posted August 11, 2010 So no end all be all solution, eh? I suppose playing with the colors to find the right blend is the only way like you suggested. Can you see HMOVE lines on a black background on your TV? I think I remember Batari saying in an old post that he could see them one of his TV's. I keep that in mind and try to use cycle 74 HMOVE's whenever I program, Or at least do as much as I can in Vblank. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 12, 2010 Share Posted August 12, 2010 Can you see HMOVE lines on a black background on your TV? I think I remember Batari saying in an old post that he could see them one of his TV's. I don't know that I've ever looked for them, but I wouldn't be surprised if they show up as "blacker than black," because the black borders above and below letterboxed pictures aren't as black as the non-picture or blanked areas to the left and right of a 4:3 screen. It's hard to get a really deep black on LCD TVs, from what I've read. Michael Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted August 12, 2010 Share Posted August 12, 2010 (edited) I've had different consoles produce different HMOVE lines. On some machines, the HMOVE lines completely disappear into a black background such as in Missile Command, while other consoles with the same game and TV will have a little bit of color or gray at the right end of each "black on black" HMOVE line. Edited August 12, 2010 by A.J. Franzman Quote Link to comment Share on other sites More sharing options...
+grafixbmp Posted August 25, 2010 Share Posted August 25, 2010 Here is a crazy idea. You are doing 12 rows of items/ghost. Could you swap each row? Like do 6 rows one frame and the other 6 the next frame? Then the ghosts would be done in between as long as when the ghost crossed a boundary, it lined up properly the next frame. The item/ghost interlacing sorta speak might help to keep from noticing the flicker too much. And I also wodered if the flicker would be easier on the eyes if the contrast were lowered by droping most all colors by 1 or 2 values. Might also help the take the blue of the maze down just a bit. You might consider extending each separation of zones by another scanline or 2 cause it looks like there is some space left at the bottom of the screen. Just spitballin here. Love what ya done so far. Keep at it. Quote Link to comment Share on other sites More sharing options...
e1will Posted August 25, 2010 Author Share Posted August 25, 2010 Here is a crazy idea. You are doing 12 rows of items/ghost. Could you swap each row? Like do 6 rows one frame and the other 6 the next frame? Interesting idea, I may try that. And I also wodered if the flicker would be easier on the eyes if the contrast were lowered by droping most all colors by 1 or 2 values. Might also help the take the blue of the maze down just a bit. Yep, right now with the binaries I'm playing with, all of the objects have a luminance of 6 or less. Seems to help a little. You might consider extending each separation of zones by another scanline or 2 cause it looks like there is some space left at the bottom of the screen. I still need to add the score and lives, so I probably won't have scanlines to spare. Just spitballin here. Love what ya done so far. Keep at it. Thanks. Right now I'm re-writing it to use two separate kernels depending on the setting of the TV Type switch. Color for "flickery" (similar to the kernel I posted earlier) and B/W for "blocky" (colored squares instead of fruits, but they don't flicker). In both cases I've decided to rework Pac-Man as a player sprite instead of the ball sprite, so up- and down-facing sprites can be easily supported. In "blocky" mode, that will essentially generate the same flicker as Ms. Pac-Man, which is (IMO) acceptable, especially since I'll be tweaking the ghost AI to avoid being on the same scanlines if they can. The Pac-Man sprite will not flicker at all in "blocky" mode. I'm thinking "flickery" mode might just be a "bonus" mode for people with emulators, since Stella can make it look pretty decent with the phosphor effect enabled. --Will Quote Link to comment Share on other sites More sharing options...
johnny_boy Posted August 25, 2010 Share Posted August 25, 2010 Very clever! If this solution is actually doable, it could manage to satisfy both the emulation and real hardware camps. This is shaping up to be a smashing release! Quote Link to comment Share on other sites More sharing options...
e1will Posted August 25, 2010 Author Share Posted August 25, 2010 ...and I'm not 100% sure, but I think I can get it so that both the blocky and flickery versions have solid (non-flickering) pink doors. I've already got the maze solid. Getting rid of the ball sprite frees up a lot of cycles. --Will Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 25, 2010 Share Posted August 25, 2010 Getting rid of the ball sprite frees up a lot of cycles. Have you considered using DPC+? Stella supports it as long as you're not doing any ARM subroutines. Quote Link to comment Share on other sites More sharing options...
e1will Posted August 25, 2010 Author Share Posted August 25, 2010 Getting rid of the ball sprite frees up a lot of cycles. Have you considered using DPC+? Stella supports it as long as you're not doing any ARM subroutines. DPC+ is definitely on my radar. And it would definitely help the cycle issue if I wanted to keep the ball sprite in play. As it stands I'm looking at using the ball sprite only for the title screen, since Pac'll only need to go left and right there. In the game proper, I think I'm going to have to use a player sprite, so I can use up and down sprites, as well as to not force the adjacent playfield (maze + door) pixels to be yellow. I'm trying to think, would DPC+ let me implement cd-w's idea of the venetian blind effect on the whole screen (in the flickery mode)? I'd love to try out the venetian blind effect, but I'm struggling to figure out how to achieve it since I'd need to call RESP0 and RESP1 each line; I can't get away with just HMOVEing P0 and P1 since the fruits/keys (frame 1) are going to potentially be horizontally far away from the ghosts (frame 2). --Will Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 25, 2010 Share Posted August 25, 2010 I don't know if it would directly help with the venetian blind. The main thing is it will help reduce cycle time usage in the kernel, especially if you're able to use Fast Fetch mode. Quote Link to comment Share on other sites More sharing options...
+grafixbmp Posted August 25, 2010 Share Posted August 25, 2010 Yea! I think it is up to 29 TIA register updates over 2 scanlines. But you have to prearrange your data for it. Quote Link to comment Share on other sites More sharing options...
e1will Posted August 31, 2010 Author Share Posted August 31, 2010 I just received my Harmony in the mail, and wow, is that flicker horrible! I'm definitely going to go with the blocky-for-real-hardware, flickery-for-emulators approach on this one. --Will Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 31, 2010 Share Posted August 31, 2010 I just received my Harmony in the mail, and wow, is that flicker horrible! What kind of TV do you have? Quote Link to comment Share on other sites More sharing options...
e1will Posted August 31, 2010 Author Share Posted August 31, 2010 I just received my Harmony in the mail, and wow, is that flicker horrible! What kind of TV do you have? NTSC CRT, about 36 inches wide. --Will Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 31, 2010 Share Posted August 31, 2010 I just received my Harmony in the mail, and wow, is that flicker horrible! What kind of TV do you have? NTSC CRT, about 36 inches wide. So nothing special. Looks like you are more sensitive to flicker (just like me) than the average people. Quote Link to comment Share on other sites More sharing options...
roryjr Posted December 13, 2014 Share Posted December 13, 2014 Can you please bring this back? Please?! My version only moves left and right. I may not have the latest. Quote Link to comment Share on other sites More sharing options...
+save2600 Posted February 17, 2015 Share Posted February 17, 2015 Would love to see this finished too. 1 Quote Link to comment Share on other sites More sharing options...
