Atari MEGA 1 RAM upgrade
13 replies to this topic
#1 candle OFFLINE
candle
  • 2,793 posts
Posted Thu Dec 31, 2009 11:47 AM
Hello everyone, Happy New Year ;)
I've bought myself Atari MEGA 1 recently, and decided to do something creative with it ;)
Here are the results:
Posted Image
For start, we need to desolder old RAM chips - its not an easy task, since all of them are SMT chips - You could probably cut them out, but this will be a point of no return ;)
I use HOT AIR SMD REWORK soldering station
Posted Image
After desoldering the chips, old solder remains on SMD pads, we need to get rid of it, because it will prevent us from soldering new chips properly
For this i recommend using solder wick
Soldering of new chips is not that hard as it might seem, just use fine tip solder iron, and precisly place the chip on pads before soldering it - there is verry little margin for error here
Posted Image
Throught the PCB we need to drill a hole (or use one of existing ones) and conduct the wire from pin #5 of first RAM chip (U40) to pin #64 of MMU (U30)
Posted Image
What we need to do now, is to connect all pin #5 of RAM chips together forming MA9 line that makes this upgrade complete
required chips can be found on 30 pin SIMM modules, the same as we use for 8bit Atari memory upgrades
Candle
#2 tjlazer OFFLINE
tjlazer
  • 2,143 posts
  • Retro Atari Addict
Posted Sat Jan 2, 2010 3:10 AM
Very nice work! If I lived close I would have you do an upgrade to my Mega 2. ;)
#3 candle OFFLINE
candle
  • 2,793 posts
Posted Sat Jan 2, 2010 7:27 AM
move then ;)
#4 Lynxman OFFLINE
Lynxman
    Moonsweeper
  • 429 posts
Posted Sun Jan 10, 2010 1:57 PM
This is very nice, i have done the same with 2 or 3 Mega 1. But there are some Mega 1 which are made with DIL-DRAM-chips...
You made very good pictures, no problem for other people to do the same. :thumbsup:
Do you use a 68 Ohm resistor? Atari uses this resistors in the MAD-lines to the memory chips.
And this chips can also be found at Lynxman. :cool: New, unused, best quality (Mitsubishi or Motorola 60/70ns) for 2 (8chips for only 2!) + shipping.
So there is no need to desolder the chips.
Was there ever a Mega 2 with SMD-memory-chips?
Lynxman
#5 candle OFFLINE
candle
  • 2,793 posts
Posted Sun Jan 10, 2010 2:43 PM
i haven't noticed any terminators on MA lines, perhaps i was not paying enought attention
never the less upgrade runs perfectly stable
#6 Lynxman OFFLINE
Lynxman
    Moonsweeper
  • 429 posts
Posted Tue Jan 12, 2010 4:01 PM
You can see this Resistors in your first pic. Starting with R52.
Anyway, your Mega is working.
#7 candle OFFLINE
candle
  • 2,793 posts
Posted Tue Jan 12, 2010 5:01 PM
and i can also see they are rated for 33R ;)
#8 Lynxman OFFLINE
Lynxman
    Moonsweeper
  • 429 posts
Posted Sat Jan 16, 2010 7:56 AM
OK, you are right. I think the 68R was used for /RAS and /CAS.
#9 qq1975b OFFLINE
qq1975b
    Space Invader
  • 13 posts
Posted Tue Feb 24, 2015 6:08 AM
So...was the 68R needed? or only replacing the DRAM chips and linking them as described is OK?
#10 guus.assmann OFFLINE
guus.assmann
    Moonsweeper
  • 370 posts
Posted Tue Feb 24, 2015 10:49 AM
For RA9 a 33 Ohm resistor is needed.
This will reduce spike signals when accessing the chips.
So less noise and more reliable operation.
BG/
Guus
#11 exxosuk OFFLINE
exxosuk
    Dragonstomper
  • 563 posts
Posted Tue Feb 24, 2015 12:25 PM
Nice work :)  I don't suppose you could post a high-res top view of the motherboard ?  I am working on some MEGA related problems and not seen the SMT RAM version of that board yet :)
#12 Tillek OFFLINE
Tillek
    Dragonstomper
  • 728 posts
Posted Wed Feb 25, 2015 2:59 AM
Just out of curiosity, did this take it to 4mb, or something else?
#13 qq1975b OFFLINE
qq1975b
    Space Invader
  • 13 posts
Posted Wed Feb 25, 2015 3:07 AM
4 MB
#14 santosp OFFLINE
santosp
    Dragonstomper
  • 795 posts
Posted Sat Jan 6, 2018 2:56 PM
Original TC514256AJ-10, which replaced with TMS44400DJ-70
