reflowing solder joints
frank_c
Heat gun process works better with SMD chips and such. The Colecovision, etc. uses TTH (through the hole) soldering techniques and a soldering iron one by one is the way I've done it for 30 years. There are irons tips shaped like hammerhead sharks (long rectangular) tips that do a nice job with the varying pins all at once, but I've never used one. And honestly, I'd be more afraid heating up rows of pins at a time on this old stuff. For chips, set your iron to 15 watts and reflow one at a time. For components, 30 watts works out real well. You can purchase a dual setting iron for $10-$15 from Rat Shack.
Edited by save2600
We had a conversation about flowing solder on a ColecoVision board before. I said this earlier and I'll do it again for emphasis... flowing solder on the CV board is a stone cold bitch because the solder is practically fossilized onto the board. I don't know if the motherboard is pretreated with a coat of silicone or what, but you're going to find it extremely hard to get that solder a movin'.
Generally speaking, the hardware is a headache of Xbox 360 proportions. The system is hard to open, the power switch will give you constant problems, and if you accidentally pop off a component (like, say, the extremely vulnerable controller ports), you can pretty much kiss the whole thing goodbye. I tried installing a new controller port in my CV but discovered while trying to unlock Pac-Man Plus on Opcode's excellent Pac-Man Collection that it didn't work properly. Feh! It's definitely not a console that was designed for the long haul.
Even if old solder is difficult to reflow, simply apply new solder over the top of the protruding pins on the back side of the PCB. It all accomplishes the same thing.
Right on. It's the flux or resin that you're probably seeing Jess. Some manufacturers went ape spit with that shit. I'm awaiting a Colecovision too. Can't wait to see what that puppies insides look like icon_ponder.gif
Edited by save2600
I recently purchased a Weller WESD51 soldering station, works really well. Since this unit is set by temp, what would be a good temp setting for chips and components when working on this older stuff?
George
Here's a real great guide for this sort of thing. Nice purchase btw! That's on my list as well as one of those large clamp-able magnifier/lamp doo-jobbers. lol
http://www.elexp.com/t_solder.htm
Edited by save2600
Conformal coating..
On the subject of 'conformal coating' and having just restored a Colecovision yesterday, I did not see any signs of that protectant crap on either side of the board (whew!), but did see some sloppy resin good near the on/off switch which is typical. Forgot how tiny a CV CPU board is and how light the system is overall. lol
  • 2 weeks later...
My cv was an earlier model, and it definitely had a thin layer of the stuff. Nowhere near as thick as what you might see in an automotive ecm or whatnot.
