VGA 15Khz capable LCD - US
8 replies to this topic
#1 remowilliams OFFLINE
remowilliams
  • 10,590 posts
Posted Tue Feb 2, 2010 10:26 PM
New TV arrived today - the Sharp Aquos LC32LE700UN. And much to my incredible surprise, besides having an amazing picture w/LED full panel lighting - the damn thing actually displays 50/60Hz 15Khz RGB video!! I couldn't believe it - I had just hooked the ST up as a lark, because just about everything has failed this test over the years.
And yes, it's not cheap being a top of the line LCD HDTV. I purchased it for HD current gen gaming, but was blown away that it can actually handle the low rate RGB. Now all I need to do is build a SCART > VGA adapter and I can connect all the SCART RBG capable consoles too. Woot! :D
#2 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,963 posts
Posted Tue Feb 2, 2010 10:30 PM
That should mean VBXE will work too.
Don't suppose it has a video out socket?
#3 remowilliams OFFLINE
remowilliams
  • 10,590 posts
Posted Tue Feb 2, 2010 10:35 PM
Yes it should I would think. When I get my VBXE (and get to installing it) I'll give that a go. There is no video out on the TV.
#4 nonner242 OFFLINE
nonner242
  • 3,664 posts
  • ALL your base ALL belong to us!!!!!!!!!!!!!!
Posted Tue Feb 2, 2010 10:44 PM
Thats cool!Posted Image
#5 atarian63 OFFLINE
atarian63
  • 4,244 posts
Posted Tue Feb 2, 2010 10:47 PM
Interesting, just looked up my 73" DLP and specs say it can also do 15khz, I'll have to try it. :thumbsup:
#6 atarian1 OFFLINE
atarian1
    Dragonstomper
  • 608 posts
Posted Tue Feb 2, 2010 11:41 PM
Wow. That sounds great! :)
How did you hook it up? Did you build a cable from the RGB monitor port to the VGA port? (ie connect red to red, green to green, horizontal sync to horizontal sync, etc)
I don't understand the SCART-VGA cable you are planning to build. Where does that fall in this maze of adapters? :P
#7 remowilliams OFFLINE
remowilliams
  • 10,590 posts
Posted Wed Feb 3, 2010 12:00 AM
Yes, I already had an ST DIN > female HD15 VGA adapter built for previous use. It is R/G/B H/V sync straight through from one end to the other. I used a 1040STf to test. I'll have to try other STs later. One other neat thing, I could do Falcon RGB/VGA on the same display now with this LCD.
The SCART-VGA cable should be the same straight through signal principle, as SCART RGB is 15Khz as well. I may have to mess around with the sync on the ST/MSTEs in that area though. But for other systems (Genesis/Saturn/Dreamcast, etc) that I have SCART RGB cables for it should be easy. Can't wait to see them on the TV in all that RGB glory! :)
Worth noting - the manual for the TV does not mention anything other than (S)VGA/(W/S/U)XGA signals as compatible, yet the old low rate RGB obviously does work. Perhaps there are other Sharp panels that can do so...
#8 kool kitty89 OFFLINE
kool kitty89
  • 2,449 posts
Posted Thu Feb 4, 2010 12:19 PM
SCART does transmit interlaced video as well, so if the VGA input for the TV isn't equipped to handel that (ie no deinterlacing for it) that wouldn't work, or may not work properly. Still this is great, and havign a lack of deinterlacing is a better tradeoff than deinterlacing for everything. (ie deinterlacing a progressive signal -albeit some HD sets can discriminate between 240p and 480i aparently)
#9 remowilliams OFFLINE
remowilliams
  • 10,590 posts
Posted Thu Feb 4, 2010 2:49 PM
Well the first snag is (in all my ST excitement :D) that I forgot that many of the SCART devices are using CSYNC which isn't going to work.
So either I do a sync strainer to get H/V out of it or I just hook them up to the component inputs (the Aquos has a terrific input selection) which looks beautiful. :cool:
