Pyromaniac605 Posted March 5, 2010 Share Posted March 5, 2010 I've posted this before but whatever my Colecovision will only play games using Expansion Module #2 just help i dont want any bullshit answers like the powerswitch or the Power Brick if that were the case the fucking Module wouldn't work so i just want a straight up fix. And sorry if this is a bit angry but im getting really impatient. -Darren- Quote Link to comment Share on other sites More sharing options...
Shannon Posted March 5, 2010 Share Posted March 5, 2010 Most likely it's a chip on the controller port that is sensitive to static electricity. Can you start games with a controller plugged in port 2? Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 5, 2010 Author Share Posted March 5, 2010 (edited) Port 2 only? i'll try Edit:Didn't work Edited March 5, 2010 by Pyromaniac605 Quote Link to comment Share on other sites More sharing options...
Albert Posted March 5, 2010 Share Posted March 5, 2010 I have edited the title of this topic--no reason to use profanity and please use more meaningful titles in the future. ..Al Quote Link to comment Share on other sites More sharing options...
+5-11under Posted March 5, 2010 Share Posted March 5, 2010 (edited) I have edited the title of this topic--no reason to use profanity and please use more meaningful titles in the future. ..Al ... and people might be more inclined to help... if possible, you should check the +12V, +5V, and -5V supplies on the board. It could be the TMS9928A (the chip with the heat sink), but it could also be a severe video memory problem, or something else. What are the symptoms? 5-11under edit: I was assuming you were getting a black screen... but as I said, what are the symptoms? Does anything show up on the screen, with the power on, and no cart or expansion module plugged in? Edited March 5, 2010 by 5-11under Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 6, 2010 Author Share Posted March 6, 2010 (edited) The only way i can get anything other than a black screen was using the expansion module exept for once when i got a blue screen with a scrambled mess but that was only once and sorry about the previous title. -Darren- Edit: I read somewhere about a 12 second delay until it boots so does that mean the difficulty select screen or the actual game after you select a difficulty? And also when I start it its just a black screen but if i fick the switch around a bit its starts huming. Edited March 6, 2010 by Pyromaniac605 Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 9, 2010 Author Share Posted March 9, 2010 *bump* Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 13, 2010 Author Share Posted March 13, 2010 Anyone!? -Darren- Quote Link to comment Share on other sites More sharing options...
Mark_Coleco Posted March 13, 2010 Share Posted March 13, 2010 Well with no cartridge in the unit, you should get a "turn off unit before inserting a cartridge" screen. So unplug your two controllers and don't put a cart in and then turn on the power, what happens? Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 13, 2010 Author Share Posted March 13, 2010 Nothing still a black screen. -Darren- Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 13, 2010 Author Share Posted March 13, 2010 Just tried my other colecovision and i still get the black screen but it is a bit fuzzy not just a flat black screen is that a good sign? -Darren- Quote Link to comment Share on other sites More sharing options...
Mark_Coleco Posted March 13, 2010 Share Posted March 13, 2010 (edited) Just tried my other colecovision and i still get the black screen but it is a bit fuzzy not just a flat black screen is that a good sign? -Darren- Did you use the same Power Supply for both units? IF so have you tested the power supply with a multi-tester to see if all holes put out the correct voltage? (VOLTAGE), I dont have that information in front of me at the moment, any else know what they are suppose to be? +12V, +5V, and -5V? What are you using to hook it up to the TV? Stay Calm Edited March 13, 2010 by Mark_Coleco Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 13, 2010 Author Share Posted March 13, 2010 Just tried my other colecovision and i still get the black screen but it is a bit fuzzy not just a flat black screen is that a good sign? -Darren- Did you use the same Power Supply for both units? IF so have you tested the power supply with a multi-tester to see if all holes put out the correct voltage? (VOLTAGE), I dont have that information in front of me at the moment, any else know what they are suppose to be? +12V, +5V, and -5V? What are you using to hook it up to the TV? Stay Calm Yes the same one but there is no way it is the power supply because the atari module works fine and also the voltages would be different here im pretty sure. -Darren- Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 13, 2010 Author Share Posted March 13, 2010 And im using the RF lead. -Darren- Quote Link to comment Share on other sites More sharing options...
coleconut Posted March 13, 2010 Share Posted March 13, 2010 Just tried my other colecovision and i still get the black screen but it is a bit fuzzy not just a flat black screen is that a good sign? -Darren- Did you use the same Power Supply for both units? IF so have you tested the power supply with a multi-tester to see if all holes put out the correct voltage? (VOLTAGE), I dont have that information in front of me at the moment, any else know what they are suppose to be? +12V, +5V, and -5V? What are you using to hook it up to the TV? Stay Calm Yes the same one but there is no way it is the power supply because the atari module works fine and also the voltages would be different here im pretty sure. -Darren- Input voltage would be different of course but the output would be the same. Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 13, 2010 Author Share Posted March 13, 2010 Yeah but there is no way its the power supply because as ive said about 3 times before the atari module still work perfectly. -Darren- Quote Link to comment Share on other sites More sharing options...
Mark_Coleco Posted March 13, 2010 Share Posted March 13, 2010 If you don't test it you won't know. The Atari unit may require less power...? If its not the power supply then its the power switch or the VDP. But you said both CV's act similar. I don't know, wish someone would know show up here. Maybe ask someone on the board to fix your CV's, there's a few guys here who repair them. Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 14, 2010 Author Share Posted March 14, 2010 It couldnt be the power switch either because it is turning on fine and i have two power boxes ill try the other one. -Darren- Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 14, 2010 Author Share Posted March 14, 2010 They other power box doesnt change anything. -Darren- Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 20, 2010 Author Share Posted March 20, 2010 Anyone there is no way this is a rare problem because both of mine have it and if it is a common problem which ot obviously is then there must be a fix and a want to know what it is ASAP. -Darren- Quote Link to comment Share on other sites More sharing options...
Mark_Coleco Posted March 20, 2010 Share Posted March 20, 2010 try another tv Quote Link to comment Share on other sites More sharing options...
coleconut Posted March 20, 2010 Share Posted March 20, 2010 (edited) Anyone there is no way this is a rare problem because both of mine have it and if it is a common problem which ot obviously is then there must be a fix and a want to know what it is ASAP. -Darren- I've had easily a hundred colecovisions pass thru my hands and not seen this one. Is the TV an older crt type screen? Have you tried both channel 3 and 4 on the TV, there is a switch to change channels on the console at the back. Have you got one of those direct connect RCA-to-coax thingies or are you using one of those crappo switch boxes? Dont even bother using a game cart, try to at least get the "insert game" screen. With volume up do you get any noise or screen activity by jiggling the on/off switch, the power connection at the console, the rf cable, the channel switch? If you shake the console a little, does anything clunk around inside. I ask because another guy in this forum had an ADAM computer that wouldnt show anything on the screen. I had him open er up - against his better judgement - but when he did some random piece of something fell out - and now it works fine. The reset switch isnt locked is it,does it move freely and I'll ask the obvious - you have tried multiple resets right? Did these machines ever work for you and this is a recent phenomenon or is this your first effort? Dunno what else to ask at this point..... Edited March 20, 2010 by coleconut Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 22, 2010 Author Share Posted March 22, 2010 Anyone there is no way this is a rare problem because both of mine have it and if it is a common problem which ot obviously is then there must be a fix and a want to know what it is ASAP. -Darren- I've had easily a hundred colecovisions pass thru my hands and not seen this one. Is the TV an older crt type screen? Have you tried both channel 3 and 4 on the TV, there is a switch to change channels on the console at the back. Have you got one of those direct connect RCA-to-coax thingies or are you using one of those crappo switch boxes? Dont even bother using a game cart, try to at least get the "insert game" screen. With volume up do you get any noise or screen activity by jiggling the on/off switch, the power connection at the console, the rf cable, the channel switch? If you shake the console a little, does anything clunk around inside. I ask because another guy in this forum had an ADAM computer that wouldnt show anything on the screen. I had him open er up - against his better judgement - but when he did some random piece of something fell out - and now it works fine. The reset switch isnt locked is it,does it move freely and I'll ask the obvious - you have tried multiple resets right? Did these machines ever work for you and this is a recent phenomenon or is this your first effort? Dunno what else to ask at this point..... It is a CRT. No matter what channel i select my TV picks it up as Channel 1. Direct RCA cable no box or coaxial apadter. I'll work on it. If i switch the console on and of a few time rapidly it starts to make a sort of humming sound. Nothing moves around and i can confirm there is nothing loose because i have taken one of them apart. I have tried multiple resets but that didn't help. They worked previously after i got them out of my wardrobe i set them up and they worked ok for a day or two but then it just suddenly stoped working. -Darren- (hope that answers all your questions ) Quote Link to comment Share on other sites More sharing options...
Pyromaniac605 Posted March 26, 2010 Author Share Posted March 26, 2010 Come on please there is absolutly no way this is uncommon! -Darren- Quote Link to comment Share on other sites More sharing options...
Hitachi Posted June 20, 2010 Share Posted June 20, 2010 Hello, This is my first post. My inclination is that if you aren't using a coaxial adapter, you might have problems, because the cable from the colecovision sends both video and sound(right?). I would think that the TV wouldn't be able to process the audio and video together. You might try using a coax adapter or switch box. I understand your frustration, as my CV is not working either (one of the main reasons i joined the site). Hope that might help... Quote Link to comment Share on other sites More sharing options...
