johnon Posted March 17, 2010 Share Posted March 17, 2010 My command line is telling me that DASM is x86 only and isn't compatible with x64. Is there a workaround of some sort or an x64 compatible compiler? Thanks in advance and apologies if it's been covered. I did some searching and couldn't find anything. Quote Link to comment Share on other sites More sharing options...
+batari Posted March 17, 2010 Share Posted March 17, 2010 You must have an old DOS-only version. Any current version you get should be Win32 and work fine under x64. Quote Link to comment Share on other sites More sharing options...
johnon Posted March 17, 2010 Author Share Posted March 17, 2010 Thanks for the response. That must be the problem. ^^ Quote Link to comment Share on other sites More sharing options...
johnon Posted March 17, 2010 Author Share Posted March 17, 2010 Okay, after double-checking, I downloaded the latest version available at atariage.com/DASM/ and it still doesn't work. I have Win 7 64-bit and it simply does not want to work. Quote Link to comment Share on other sites More sharing options...
+batari Posted March 17, 2010 Share Posted March 17, 2010 That is not the latest version. The latest may be found here: http://sourceforge.net/projects/dasm-dillon/ 1 Quote Link to comment Share on other sites More sharing options...
johnon Posted March 17, 2010 Author Share Posted March 17, 2010 Ah. Thanks, I was unaware. ^^ Quote Link to comment Share on other sites More sharing options...
+xucaen Posted January 1, 2015 Share Posted January 1, 2015 Someone at atariage should update their's. grr arg. Quote Link to comment Share on other sites More sharing options...
